[fdo-commits] r653 - in
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest: . Common
svn_fdo at osgeo.org
Fri Jan 19 13:54:04 EST 2007
Author: brentrobinson
Date: 2007-01-19 13:54:03 -0500 (Fri, 19 Jan 2007)
New Revision: 653
Added:
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_err1_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_def1_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt
Handle unique constraints referencing base properties.
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp 2007-01-19 18:54:03 UTC (rev 653)
@@ -888,14 +888,14 @@
false,
DB_NAME_SUFFIX
// Compare output files with expected results.
FdoStringP provider = UnitTestUtil::GetEnviron("provider");
UnitTestUtil::CheckOutput(
- (const char*) FdoStringP::Format( L"apply_schema_overrides_err1%ls_master.txt", (FdoString*) provider ),
+ "apply_schema_overrides_err1_master.txt",
UnitTestUtil::GetOutputFileName( L"apply_schema_overrides_err1.txt" )
catch ( FdoException* e )
@@ -4266,6 +4266,21 @@
FdoPropertiesP(pFeatClass->GetProperties())->Add( pGeomProp3 );
+ if ( idx == 9 ) {
+ FdoPtr<FdoReadOnlyPropertyDefinitionCollection> pBaseProps = pBaseClass->GetBaseProperties();
+ FdoPtr<FdoUniqueConstraint> constr = FdoUniqueConstraint::Create();
+ FdoDataPropertiesP(constr->GetProperties())->Add( pProp );
+ FdoPropertyP pBaseProp = pBaseProps->GetItem( L"DataC" );
+ FdoDataPropertiesP(constr->GetProperties())->Add( (FdoDataPropertyDefinition*)(pBaseProp.p) );
+ FdoPtr<FdoUniqueConstraintCollection>(pFeatClass->GetUniqueConstraints())->Add( constr );
+ constr = FdoUniqueConstraint::Create();
+ pBaseProp = pBaseProps->GetItem( L"DataH" );
pFeatClass->SetGeometryProperty( pGeomProp );
pBaseClass = pFeatClass;
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt 2007-01-19 18:54:03 UTC (rev 653)
@@ -62,10 +62,10 @@
</xsl:copy>
</xsl:template>
<xsl:template match="lp:property[@name='GEOMETRY' and $providerName='SqlServer']"/>
-<xsl:template match="lp:sequence|lp:sequenceSynonym"/>
+<xsl:template match="lp:sequence[not($providerName = 'Oracle')]|lp:sequenceSynonym[not($providerName = 'Oracle')]"/>
<xsl:template match="lp:column[@name = 'CLASSNAME' or @name = 'SCHEMANAME']"/>
<xsl:template match="lp:column[$providerName = 'SqlServer' and @name = 'GEOMETRY1' and local-name(..) = 'table']"/>
-<xsl:template match="lp:column[@dataType and not($providerName='Oracle' or @name = 'CLASSNAME' or @name = 'SCHEMANAME') and not($providerName = 'SqlServer' and @name = 'GEOMETRY1' and local-name(..) = 'table')]">
+<xsl:template match="lp:column[@dataType and not(@name = 'CLASSNAME' or @name = 'SCHEMANAME') and not($providerName = 'SqlServer' and @name = 'GEOMETRY1' and local-name(..) = 'table')]">
<xsl:variable name="colName" select="@name"/>
<xsl:choose>
<xsl:when test="local-name(..) = 'property'">
@@ -93,6 +93,20 @@
<xsl:value-of select="@description"/>
</xsl:attribute>
<xsl:choose>
+ <xsl:when test="$providerName = 'Oracle'">
+ <xsl:attribute name="dataType">
+ <xsl:value-of select="@dataType"/>
+ </xsl:attribute>
+ <xsl:attribute name="length">
+ <xsl:value-of select="@length"/>
+ </xsl:attribute>
+ <xsl:attribute name="scale">
+ <xsl:value-of select="@scale"/>
+ </xsl:attribute>
+ <xsl:attribute name="nullable">
+ <xsl:value-of select="@nullable"/>
+ </xsl:attribute>
+ </xsl:when>
<xsl:when test="$propNode/@xsi:type='Data'">
<xsl:choose>
<xsl:when test="$propNode/@dataType = 'string'" >
@@ -288,8 +302,8 @@
</xsl:template>
<xsl:template match="@idColumn">
<xsl:attribute name="idColumn">
- <xsl:call-template name="tolower">
- <xsl:with-param name="inString" select="."/>
+ <xsl:call-template name="bendColumnName">
+ <xsl:with-param name="inName" select="."/>
</xsl:call-template>
</xsl:attribute>
</xsl:template>
@@ -320,7 +334,7 @@
</xsl:choose>
</xsl:template>
<xsl:template match="@pkeyName"/>
-<xsl:template match="@tablespace"/>
+<xsl:template match="@tablespace[not($providerName = 'Oracle')]"/>
<xsl:template match="@*|node()">
<xsl:copy>
<xsl:apply-templates select="@*|node()"/>
@@ -330,7 +344,14 @@
<xsl:param name="inName"/>
<xsl:choose>
<xsl:when test="$providerName='Oracle'">
- <xsl:value-of select="$inName"/>
+ <xsl:choose>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OVCL1'">OVCLASSC111_OPC_TABLE1_OVCL1</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OPID1'">OVCLASSC111_OPC_TABLE1_OPID1</xsl:when>
+ <xsl:when test="$inName='OVCLASSH_FTABLED_OVCLASSH_FEA1'">OVCLASSH_FTABLED_OVCLASSH_F1</xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="$inName"/>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
@@ -354,11 +375,12 @@
<xsl:when test="$inName='NGPREFIX012345_PREFIXA_OPB'">testverylongprefix012345_prefixa_opb</xsl:when>
<xsl:when test="$inName='STVERYLONGPREFIX012345_OPA'">testverylongprefix012345_opa</xsl:when>
<xsl:when test="$inName='STVERYLONGPREFIX012345_OPB'">testverylongprefix012345_opb</xsl:when>
- <xsl:when test="$inName='OVCLASSH_FTABLED_OVCLASSH_FEA1'">ovclassh_ftabled_ovclassh_featid</xsl:when>
- <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OVCL1'">ovclassc111_opc_table_hd_ovclassc111_featid</xsl:when>
- <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OPID'">ovclassc111_opc_table_hd_opid1</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE1_OVCL1'">ovclassc111_opc_table_hd_ovclassc111_featid</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE1_OPID1'">ovclassc111_opc_table_hd_opid1</xsl:when>
+ <xsl:when test="$inName='OVCLASSH_FTABLED_OVCLASSH_F1'">ovclassh_ftabled_ovclassh_featid</xsl:when>
<xsl:when test="$inName='GEOMETRY1' and $providerName='SqlServer'">geometry</xsl:when>
<xsl:otherwise>
<xsl:with-param name="inString" select="$inName"/>
@@ -371,7 +393,14 @@
<xsl:choose>
+ <xsl:choose>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD'">OVCLASSC111_OPC_TABLE1</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OPC_1'">OVCLASSC111_OPC_TABLE2</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPS_TABLE_HA'">OVCLASSC111_OPS_TABLE1</xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
@@ -386,7 +415,9 @@
<xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_ACDBV2'">polyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
<xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_1'">electricdevice_maint_history_maint_history_item</xsl:when>
<xsl:when test="$inName='MAINT_HISTORY_MAINT_HISTORY_I1'">maint_history_maint_history_item</xsl:when>
- <xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OPC_1'">ovclassc111_opc_table_hd_opc_table_hda</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE1'">ovclassc111_opc_table_hd</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPC_TABLE2'">ovclassc111_opc_table_hd_opc_table_hda</xsl:when>
+ <xsl:when test="$inName='OVCLASSC111_OPS_TABLE1'">ovclassc111_ops_table_ha</xsl:when>
<xsl:otherwise>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt 2007-01-19 18:54:03 UTC (rev 653)
@@ -10,7 +10,7 @@
<xsl:template match="lp:schema[@name='F_MetaClass']"/>
-<xsl:template match="lp:column[@name = 'classname' or @name = 'schemaname']">
+<xsl:template match="lp:column[@name = 'classname' or @name = 'schemaname' or @name = 'CLASSNAME' or @name = 'SCHEMANAME']">
</xsl:template>
<xsl:template match="lp:column[@dataType and not(@name = 'classname' or @name = 'schemaname' or @name = 'CLASSNAME' or @name = 'SCHEMANAME')]">
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt 2007-01-19 18:54:03 UTC (rev 653)
@@ -23,6 +23,20 @@
</xsl:apply-templates>
</xsl:copy>
</xsl:template>
+<xsl:template match="lp:uniqueConstraints">
+ <xsl:copy>
+ <xsl:apply-templates select="lp:uniqueConstraint">
+ <xsl:sort select="count(lp:property)"/>
+ </xsl:apply-templates>
+ </xsl:copy>
+</xsl:template>
+<xsl:template match="lp:uniqueConstraint">
+ <xsl:copy>
+ <xsl:apply-templates select="lp:property">
+ <xsl:sort select="@name"/>
+ </xsl:copy>
+</xsl:template>
<xsl:template match="lp:table">
<xsl:copy>
<xsl:apply-templates select="@*|lp:target"/>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt 2007-01-19 18:54:03 UTC (rev 653)
@@ -295,7 +295,7 @@
</targetProperties>
<class xsi:type="Class" name="OvClassC111.Object B" description="Autogenerated Object Property Class"
baseClass="" abstract="False"
- tableName="OVCLASSC111_OPS_TABLE_HA" tblCreator="True" fixedTbl="False" >
+ tableName="OVCLASSC111_OPS_TABLE1" tblCreator="True" fixedTbl="False" >
<tableMapping>Concrete</tableMapping>
<identityProperties>
<property xsi:type="Data" name="OvClassC111_FeatId" />
@@ -307,7 +307,7 @@
<mappingDefinition xsi:type="Single" prefix="prefixA">
<class xsi:type="Class" name="OvClassC111.Object B.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSC111_OPS_TABLE_HA" tblCreator="False" fixedTbl="False" >
+ tableName="OVCLASSC111_OPS_TABLE1" tblCreator="False" fixedTbl="False" >
</identityProperties>
@@ -318,7 +318,7 @@
<mappingDefinition xsi:type="Single" prefix="prefixA_prefixA">
<class xsi:type="Class" name="OvClassC111.Object B.ObjectA.ObjectA" description="Autogenerated Object Property Class"
@@ -326,14 +326,14 @@
<property xsi:type="Data" name="OpA" description="first data property"
dataType="string" length="10" precision="0" scale="0"
readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue=""
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="PREFIXA_PREFIXA_OPA" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="PREFIXA_PREFIXA_OPA" colCreator="True" fixedCol="True" >
<column name="PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
<property xsi:type="Data" name="OpB" description="first data property"
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="PREFIXA_PREFIXA_OPB" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="PREFIXA_PREFIXA_OPB" colCreator="True" fixedCol="True" >
<column name="PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
@@ -354,7 +354,7 @@
</column>
</property>
</properties>
-<table name="OVCLASSC111_OPS_TABLE_HA" description="" pkeyName="PK_OVCLASSC111_OPS_TABLE_HA" >
+<table name="OVCLASSC111_OPS_TABLE1" description="" pkeyName="PK_OVCLASSC111_OPS_TA1" >
<property xsi:type="Data" name="OpA" />
<property xsi:type="Data" name="OpB" />
<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
@@ -373,7 +373,7 @@
</column>
</table>
<tables>
</table>
<table name="F_CLASSDEFINITION" description="" pkeyName="" >
</table>
@@ -384,14 +384,14 @@
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="PREFIXA_OPA" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="PREFIXA_OPA" colCreator="True" fixedCol="True" >
<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="PREFIXA_OPB" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="PREFIXA_OPB" colCreator="True" fixedCol="True" >
<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
@@ -412,7 +412,7 @@
</column>
</property>
</properties>
<property xsi:type="Object" name="ObjectA" description=""
objectType="Value" className="OverridesA:OvOpClassHAAA" idColumn="" order="ascending"
fixedCol="False" >
@@ -435,7 +435,7 @@
</column>
</table>
<tables>
</table>
</table>
@@ -446,21 +446,21 @@
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="OPA" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="OPA" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="OPB" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="OPB" colCreator="True" fixedCol="True" >
<column name="OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
<property xsi:type="Data" name="OvClassC111_FeatId" description="Feature id number (uniquely identifies a feature)"
dataType="int64" length="0" precision="0" scale="0"
readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
- tableName="OVCLASSC111_OPS_TABLE_HA" columnName="OVCLASSC111_FEATID" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPS_TABLE1" columnName="OVCLASSC111_FEATID" colCreator="True" fixedCol="True" >
<column name="OVCLASSC111_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -481,7 +481,7 @@
</column>
</property>
</properties>
<target>
<table name="OVCLASSC111" description="" pkeyName="PK_OVCLASSC111" >
</table>
@@ -515,7 +515,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -548,7 +548,7 @@
</targetProperties>
<class xsi:type="Class" name="OvClassC111.Object D" description="Autogenerated Object Property Class"
- tableName="OVCLASSC111_OPC_TABLE_HD" tblCreator="True" fixedTbl="False" >
+ tableName="OVCLASSC111_OPC_TABLE1" tblCreator="True" fixedTbl="False" >
@@ -569,7 +569,7 @@
</targetProperties>
<class xsi:type="Class" name="OvClassC111.Object D.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" tblCreator="True" fixedTbl="False" >
+ tableName="OVCLASSC111_OPC_TABLE2" tblCreator="True" fixedTbl="False" >
<property xsi:type="Data" name="OpId1" />
@@ -581,7 +581,7 @@
<class xsi:type="Class" name="OvClassC111.Object D.ObjectA.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" tblCreator="False" fixedTbl="False" >
+ tableName="OVCLASSC111_OPC_TABLE2" tblCreator="False" fixedTbl="False" >
@@ -589,14 +589,14 @@
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="PREFIXA_OPA" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="PREFIXA_OPA" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="PREFIXA_OPB" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="PREFIXA_OPB" colCreator="True" fixedCol="True" >
</column>
</property>
@@ -617,7 +617,7 @@
</column>
</property>
</properties>
-<table name="OVCLASSC111_OPC_TABLE_HD_OPC_1" description="" pkeyName="PK_OVCLASSC111_OPC_TABLE_HD_O1" >
+<table name="OVCLASSC111_OPC_TABLE2" description="" pkeyName="PK_OVCLASSC111_OPC_TA1" >
@@ -626,9 +626,9 @@
</column>
<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
-<column name="OVCLASSC111_OPC_TABLE_HD_OVCL1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="OVCLASSC111_OPC_TABLE1_OVCL1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
-<column name="OVCLASSC111_OPC_TABLE_HD_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+<column name="OVCLASSC111_OPC_TABLE1_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</column>
@@ -636,7 +636,7 @@
</column>
</table>
<tables>
</table>
</table>
@@ -647,36 +647,36 @@
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="OPA" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="OPA" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
<column name="OP_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
<property xsi:type="Data" name="OpId1" description="object property id property"
dataType="int32" length="0" precision="0" scale="0"
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="OPID1" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="OPID1" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="OVCLASSC111_OPC_TABLE_HD_OVCL1" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="OVCLASSC111_OPC_TABLE1_OVCL1" colCreator="True" fixedCol="True" >
</column>
</property>
<property xsi:type="Data" name="OvOpClassHD_OpId1" description="object property id property"
- tableName="OVCLASSC111_OPC_TABLE_HD_OPC_1" columnName="OVCLASSC111_OPC_TABLE_HD_OPID1" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE2" columnName="OVCLASSC111_OPC_TABLE1_OPID1" colCreator="True" fixedCol="True" >
</column>
</property>
<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
@@ -696,9 +696,9 @@
</column>
</property>
</properties>
<target>
-<table name="OVCLASSC111_OPC_TABLE_HD" description="" pkeyName="PK_OVCLASSC111_OPC_TABLE_HD" >
+<table name="OVCLASSC111_OPC_TABLE1" description="" pkeyName="PK_OVCLASSC111_OPC_TA2" >
<target>
</table>
@@ -711,8 +711,8 @@
</target>
</table>
<sourceColumns>
-<column name="OVCLASSC111_OPC_TABLE_HD_OVCL1" />
-<column name="OVCLASSC111_OPC_TABLE_HD_OPID1" />
+<column name="OVCLASSC111_OPC_TABLE1_OVCL1" />
+<column name="OVCLASSC111_OPC_TABLE1_OPID1" />
</sourceColumns>
<targetColumns>
<column name="OVCLASSC111_FEATID" />
@@ -734,9 +734,9 @@
</column>
</column>
</column>
</column>
</column>
@@ -744,9 +744,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -759,8 +759,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -777,28 +777,28 @@
- tableName="OVCLASSC111_OPC_TABLE_HD" columnName="OPA" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE1" columnName="OPA" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPC_TABLE_HD" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE1" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPC_TABLE_HD" columnName="OPID1" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE1" columnName="OPID1" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSC111_OPC_TABLE_HD" columnName="OVCLASSC111_FEATID" colCreator="True" fixedCol="True" >
+ tableName="OVCLASSC111_OPC_TABLE1" columnName="OVCLASSC111_FEATID" colCreator="True" fixedCol="True" >
</column>
</property>
@@ -819,7 +819,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -848,7 +848,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -2064,7 +2064,7 @@
</column>
</column>
-<column name="OVCLASSH_FTABLED_OVCLASSH_FEA1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="OVCLASSH_FTABLED_OVCLASSH_F1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
<column name="OVCLASSH_FTABLED_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
@@ -2109,9 +2109,9 @@
<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_FEA1" colCreator="False" fixedCol="True" >
+ tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_F1" colCreator="False" fixedCol="True" >
<Inherited baseClass="OvClassH.ObjectD.ObjectA" />
</column>
</property>
@@ -2154,7 +2154,7 @@
</target>
</table>
<sourceColumns>
-<column name="OVCLASSH_FTABLED_OVCLASSH_FEA1" />
+<column name="OVCLASSH_FTABLED_OVCLASSH_F1" />
<column name="OVCLASSH_FTABLED_OPID1" />
</sourceColumns>
<targetColumns>
@@ -2177,7 +2177,7 @@
</column>
</column>
</column>
</column>
@@ -2202,7 +2202,7 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4883,7 +4883,7 @@
</column>
</column>
</column>
</column>
@@ -4925,8 +4925,8 @@
- tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_FEA1" colCreator="True" fixedCol="True" >
+ tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_F1" colCreator="True" fixedCol="True" >
</column>
</property>
@@ -4968,7 +4968,7 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4991,7 +4991,7 @@
</column>
</column>
</column>
</column>
@@ -5016,7 +5016,7 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -7230,7 +7230,7 @@
</column>
</column>
</column>
</column>
@@ -7275,9 +7275,9 @@
</column>
</property>
@@ -7320,7 +7320,7 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -7343,7 +7343,7 @@
</column>
</column>
</column>
</column>
@@ -7368,7 +7368,7 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt 2007-01-19 18:54:03 UTC (rev 653)
@@ -295,7 +295,7 @@
</targetProperties>
@@ -307,7 +307,7 @@
@@ -318,7 +318,7 @@
</column>
</property>
</column>
</property>
@@ -354,7 +354,7 @@
</column>
</property>
</properties>
@@ -373,7 +373,7 @@
</column>
</table>
<tables>
</table>
</table>
</column>
</property>
</column>
</property>
@@ -412,7 +412,7 @@
</column>
</property>
</properties>
fixedCol="False" >
@@ -435,7 +435,7 @@
</column>
</table>
<tables>
</table>
</table>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -481,7 +481,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -515,7 +515,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -548,7 +548,7 @@
</targetProperties>
@@ -569,7 +569,7 @@
</targetProperties>
@@ -581,7 +581,7 @@
</column>
</property>
</column>
</property>
@@ -617,7 +617,7 @@
</column>
</property>
</properties>
@@ -626,9 +626,9 @@
</column>
</column>
</column>
</column>
</column>
@@ -636,7 +636,7 @@
</column>
</table>
<tables>
</table>
</table>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -696,9 +696,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -711,8 +711,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -734,9 +734,9 @@
</column>
</column>
</column>
</column>
</column>
@@ -744,9 +744,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -759,8 +759,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -819,7 +819,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -848,7 +848,7 @@
</column>
</table>
<tables>
<target>
</table>
</column>
</column>
</column>
</column>
</column>
</property>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</column>
</property>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</column>
</property>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt 2007-01-19 18:54:03 UTC (rev 653)
@@ -38,10 +38,10 @@
<Column name="OPID1"/>
</element>
<element name="OvClassC111_FeatId">
-<Column name="OVCLASSC111_OPC_TABLE_HD_OVCL1"/>
+<Column name="OVCLASSC111_OPC_TABLE1_OVCL1"/>
</element>
<element name="OvOpClassHD_OpId1">
-<Column name="OVCLASSC111_OPC_TABLE_HD_OPID1"/>
+<Column name="OVCLASSC111_OPC_TABLE1_OPID1"/>
</element>
</PropertyMappingConcrete>
</element>
@@ -224,7 +224,7 @@
</element>
<element name="OvClassH_FeatId">
-<Column name="OVCLASSH_FTABLED_OVCLASSH_FEA1"/>
+<Column name="OVCLASSH_FTABLED_OVCLASSH_F1"/>
</element>
<Column name="OVCLASSH_FTABLED_OPID1"/>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt 2007-01-19 18:54:03 UTC (rev 653)
@@ -14,7 +14,7 @@
<Table pkeyName="PK_OVCLASSC111" name="OVCLASSC111"/>
<element name="Object-x20-B">
<PropertyMappingConcrete>
-<Table pkeyName="PK_OVCLASSC111_OPS_TABLE_HA" name="OVCLASSC111_OPS_TABLE_HA"/>
+<Table pkeyName="PK_OVCLASSC111_OPS_TA1" name="OVCLASSC111_OPS_TABLE1"/>
<element name="ObjectA">
<PropertyMappingSingle prefix="prefixA"/>
</element>
@@ -31,10 +31,10 @@
</element>
<element name="Object-x20-D">
-<Table pkeyName="PK_OVCLASSC111_OPC_TABLE_HD" name="OVCLASSC111_OPC_TABLE_HD"/>
+<Table pkeyName="PK_OVCLASSC111_OPC_TA2" name="OVCLASSC111_OPC_TABLE1"/>
-<Table pkeyName="PK_OVCLASSC111_OPC_TABLE_HD_O1" name="OVCLASSC111_OPC_TABLE_HD_OPC_1"/>
+<Table pkeyName="PK_OVCLASSC111_OPC_TA1" name="OVCLASSC111_OPC_TABLE2"/>
</element>
@@ -48,10 +48,10 @@
</element>
</element>
</element>
</element>
@@ -253,7 +253,7 @@
</element>
</element>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt 2007-01-18 22:17:21 UTC (rev 652)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt 2007-01-19 18:54:03 UTC (rev 653)
@@ -1,1375 +1,1068 @@
-<?xml version="1.0" standalone="yes"?>
-<schemas xmlns:xsi="http://www.w3.org/2001/XMLSchema" xmlns="http:/www.autodesk.com/isd/fdo/GenericLogicalPhysical" >
-<schema name="F_MetaClass" description="Special classes for FDO Feature metaclasses" >
-<class xsi:type="Class" name="Class" description="Non-feature metaclass"
- baseClass="ClassDefinition" abstract="False"
- tableName=" " tblCreator="False" fixedTbl="True" >
-<tableMapping>Concrete</tableMapping>
+<?xml version="1.0" encoding="UTF-8" ?>
+<schemas xmlns:xsi="http://www.w3.org/2001/XMLSchema" xmlns="http:/www.autodesk.com/isd/fdo/GenericLogicalPhysical">
+<schema name="F_MetaClass" description="Special classes for FDO Feature metaclasses">
+<class xsi:type="Class" name="Class" description="Non-feature metaclass" baseClass="ClassDefinition" abstract="False" tableName=" " tblCreator="False" fixedTbl="True">
+<tableMapping>
+Concrete</tableMapping>
<properties>
-<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
- dataType="string" length="30" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue=""
- tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True" >
-<Inherited baseClass="ClassDefinition" />
-<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+<Inherited baseClass="ClassDefinition"/>
+<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False">
</column>
</property>
-<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name"
- dataType="string" length="255" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue=""
- tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True" >
-<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
+<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True">
</column>
</property>
</properties>
</class>
-<class xsi:type="Class" name="ClassDefinition" description="Base for all metaclasses"
- baseClass="" abstract="True"
- tableName="F_CLASSDEFINITION" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="ClassDefinition" description="Base for all metaclasses" baseClass="" abstract="True" tableName="F_CLASSDEFINITION" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
</column>
</property>
</column>
</property>
</properties>
-<table name="F_CLASSDEFINITION" description="" pkeyName="" >
-<property xsi:type="Data" name="ClassName" />
-<property xsi:type="Data" name="SchemaName" />
-<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<table name="F_CLASSDEFINITION" description="" pkeyName="">
+<property xsi:type="Data" name="ClassName"/>
+<property xsi:type="Data" name="SchemaName"/>
+<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</column>
+<column name="CLASSTYPE" description="" dataType="NUMBER" length="10" scale="0" nullable="False">
</column>
-<column name="TABLENAME" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
+<column name="DESCRIPTION" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True">
</column>
-<column name="ROOTTABLENAME" description="" dataType="VARCHAR2" length="30" scale="0" nullable="True" >
+<column name="GEOMETRYPROPERTY" description="" dataType="VARCHAR2" length="4000" scale="0" nullable="True">
</column>
-<column name="TABLEOWNER" description="" dataType="VARCHAR2" length="30" scale="0" nullable="True" >
+<column name="HASLOCK" description="" dataType="NUMBER" length="1" scale="0" nullable="True">
</column>
-<column name="TABLELINKNAME" description="" dataType="VARCHAR2" length="128" scale="0" nullable="True" >
+<column name="HASVERSION" description="" dataType="NUMBER" length="1" scale="0" nullable="True">
</column>
-<column name="TABLEMAPPING" description="" dataType="VARCHAR2" length="30" scale="0" nullable="True" >
+<column name="ISABSTRACT" description="" dataType="NUMBER" length="1" scale="0" nullable="False">
</column>
-<column name="CLASSTYPE" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+<column name="ISFIXEDTABLE" description="" dataType="NUMBER" length="1" scale="0" nullable="True">
</column>
-<column name="DESCRIPTION" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
+<column name="ISTABLECREATOR" description="" dataType="NUMBER" length="1" scale="0" nullable="True">
</column>
-<column name="ISABSTRACT" description="" dataType="NUMBER" length="1" scale="0" nullable="False" >
+<column name="PARENTCLASSNAME" description="" dataType="VARCHAR2" length="512" scale="0" nullable="True">
</column>
-<column name="PARENTCLASSNAME" description="" dataType="VARCHAR2" length="512" scale="0" nullable="True" >
+<column name="ROOTTABLENAME" description="" dataType="VARCHAR2" length="30" scale="0" nullable="True">
</column>
-<column name="ISFIXEDTABLE" description="" dataType="NUMBER" length="1" scale="0" nullable="True" >
</column>
-<column name="ISTABLECREATOR" description="" dataType="NUMBER" length="1" scale="0" nullable="True" >
+<column name="TABLELINKNAME" description="" dataType="VARCHAR2" length="128" scale="0" nullable="True">
</column>
-<column name="HASVERSION" description="" dataType="NUMBER" length="1" scale="0" nullable="True" >
+<column name="TABLEMAPPING" description="" dataType="VARCHAR2" length="30" scale="0" nullable="True">
</column>
-<column name="HASLOCK" description="" dataType="NUMBER" length="1" scale="0" nullable="True" >
+<column name="TABLENAME" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False">
</column>
-<column name="GEOMETRYPROPERTY" description="" dataType="VARCHAR2" length="4000" scale="0" nullable="True" >
+<column name="TABLEOWNER" description="" dataType="VARCHAR2" length="30" scale="0" nullable="True">
</column>
</table>
<tables>
-</table>
+<table name="F_CLASSDEFINITION" description="" pkeyName=""/>
</tables>
</class>
-<class xsi:type="Class" name="Feature" description="Feature metaclass"
- tableName="F_FEATURE" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="Feature" description="Feature metaclass" baseClass="ClassDefinition" abstract="False" tableName="F_FEATURE" tblCreator="False" fixedTbl="True">
+<tableMapping>
-<property xsi:type="Data" name="ClassId" />
+<property xsi:type="Data" name="ClassId"/>
<properties>
-<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature"
-geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False"
- tableName="" columnName="n/a" colCreator="False" fixedCol="False" >
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="" columnName="n/a" colCreator="False" fixedCol="False">
</property>
-<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)"
- dataType="int64" length="0" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue=""
- tableName="F_FEATURE" columnName="CLASSID" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="F_FEATURE" columnName="CLASSID" colCreator="False" fixedCol="True">
</property>
-<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)"
- readOnly="True" featId="True" system="True" nullable="False" autogenerated="True" defaultValue=""
- tableName="F_FEATURE" columnName="FEATID" colCreator="False" fixedCol="True" >
+</column>
</property>
-<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated."
- dataType="double" length="0" precision="0" scale="0"
- tableName="F_FEATURE" columnName="REVISIONNUMBER" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="F_FEATURE" columnName="FEATID" colCreator="False" fixedCol="True">
</property>
-</column>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="F_FEATURE" columnName="REVISIONNUMBER" colCreator="False" fixedCol="True">
</property>
</column>
</property>
</properties>
</class>
-</schema >
-<schema name="OverridesA" description="AutoCAD schema" >
-<class xsi:type="Feature" name="OvClassA" description="a class"
- baseClass="" abstract="False"
- tableName="OVCLASSA" tblCreator="True" fixedTbl="False" >
-<geometryProperty>GeomA</geometryProperty>
+</schema>
+<schema name="OverridesA" description="AutoCAD schema">
+<class xsi:type="Feature" name="OvClassA" description="a class" baseClass="" abstract="False" tableName="OVCLASSA" tblCreator="True" fixedTbl="False">
+<geometryProperty>
+GeomA</geometryProperty>
+<tableMapping>
-<property xsi:type="Data" name="FeatId" />
+<property xsi:type="Data" name="FeatId"/>
<properties>
- tableName="OVCLASSA" columnName="CLASSID" colCreator="True" fixedCol="True" >
-<Inherited baseClass="Feature" />
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="OVCLASSA" columnName="n/a" colCreator="False" fixedCol="False">
+<Inherited baseClass="Feature"/>
+</property>
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSA" columnName="CLASSID" colCreator="True" fixedCol="True">
</column>
</property>
-<property xsi:type="Data" name="DataA" description="a data property"
- dataType="string" length="10" precision="0" scale="0"
- readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue=""
- tableName="OVCLASSA" columnName="DATAA" colCreator="True" fixedCol="False" >
-<column name="DATAA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
- readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue=""
- tableName="OVCLASSA" columnName="FEATID" colCreator="True" fixedCol="False" >
-<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSA" columnName="DATAA" colCreator="True" fixedCol="False">
+<column name="DATAA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
-<property xsi:type="Geometric" name="GeomA" description="a geometry property"
-geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False"
- tableName="OVCLASSA" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True" >
-<column name="OV_GEOMCOL_A" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSA" columnName="FEATID" colCreator="True" fixedCol="False">
+<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</property>
- tableName="OVCLASSA" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
-<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSA" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True">
+<column name="OV_GEOMCOL_A" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
</property>
- tableName="OVCLASSA" columnName="n/a" colCreator="False" fixedCol="False" >
-</property>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSA" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True">
+<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False">
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSA" description="" pkeyName="PK_OVCLASSA" >
-<property xsi:type="Data" name="DataA" />
-<property xsi:type="Geometric" name="GeomA" />
-<property xsi:type="Data" name="RevisionNumber" />
+<table name="OVCLASSA" description="" pkeyName="PK_OVCLASSA">
+<property xsi:type="Data" name="DataA"/>
+<property xsi:type="Geometric" name="GeomA"/>
+<property xsi:type="Data" name="RevisionNumber"/>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
+<table name="OVCLASSA" description="" pkeyName="PK_OVCLASSA"/>
<target>
-</table>
<sourceColumns>
-<column name="CLASSID" />
+<column name="CLASSID"/>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassB" description="a class"
- baseClass="OvClassA" abstract="False"
- tableName="OVCLASSB" tblCreator="True" fixedTbl="False" >
+<class xsi:type="Feature" name="OvClassB" description="a class" baseClass="OvClassA" abstract="False" tableName="OVCLASSB" tblCreator="True" fixedTbl="False">
+<geometryProperty>
+<tableMapping>
<properties>
- tableName="OVCLASSB" columnName="CLASSID" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="OVCLASSB" columnName="n/a" colCreator="False" fixedCol="False">
+</property>
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSB" columnName="CLASSID" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSB" columnName="DATAA" colCreator="True" fixedCol="False" >
-<Inherited baseClass="OvClassA" />
</column>
</property>
-<property xsi:type="Data" name="DataB" description="a data property"
- tableName="OVCLASSB" columnName="OV_COL_B" colCreator="True" fixedCol="True" >
-<column name="OV_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSB" columnName="DATAA" colCreator="True" fixedCol="False">
+<Inherited baseClass="OvClassA"/>
</column>
-<sequence name="OV_SEQ_1"/>
</property>
- tableName="OVCLASSB" columnName="FEATID" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSB" columnName="OV_COL_B" colCreator="True" fixedCol="True">
+<column name="OV_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
+<sequence name="OV_SEQ_1"/>
</property>
- tableName="OVCLASSB" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSB" columnName="FEATID" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSB" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSB" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSB" columnName="n/a" colCreator="False" fixedCol="False" >
-</property>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSB" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True">
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSB" description="" pkeyName="PK_OVCLASSB" >
-<property xsi:type="Data" name="DataB" />
+<table name="OVCLASSB" description="" pkeyName="PK_OVCLASSB">
+<property xsi:type="Data" name="DataB"/>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
+<table name="OVCLASSB" description="" pkeyName="PK_OVCLASSB"/>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassC" description="a class"
- baseClass="OvClassB" abstract="False"
- tableName="OV_TABLE_C" tblCreator="True" fixedTbl="True" >
+<class xsi:type="Feature" name="OvClassC" description="a class" baseClass="OvClassB" abstract="False" tableName="OV_TABLE_C" tblCreator="True" fixedTbl="True">
+<geometryProperty>
+<tableMapping>
<properties>
- tableName="OV_TABLE_C" columnName="CLASSID" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_C" columnName="n/a" colCreator="False" fixedCol="False">
+</property>
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_C" columnName="CLASSID" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_C" columnName="DATAA" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="OV_TABLE_C" columnName="OV_COL_B" colCreator="True" fixedCol="True" >
-<Inherited baseClass="OvClassB" />
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="DATAA" colCreator="True" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="DataC" description="a data property"
- tableName="OV_TABLE_C" columnName="DATAC" colCreator="True" fixedCol="False" >
-<column name="DATAC" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="OV_COL_B" colCreator="True" fixedCol="True">
+<Inherited baseClass="OvClassB"/>
</column>
</property>
- tableName="OV_TABLE_C" columnName="FEATID" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataC" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="DATAC" colCreator="True" fixedCol="False">
+<column name="DATAC" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- tableName="OV_TABLE_C" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_C" columnName="FEATID" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OV_TABLE_C" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_C" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_C" columnName="n/a" colCreator="False" fixedCol="False" >
-</property>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_C" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True">
</column>
</property>
</column>
</property>
</properties>
-<table name="OV_TABLE_C" description="" pkeyName="PK_OV_TABLE_C" >
-<property xsi:type="Data" name="DataC" />
+<table name="OV_TABLE_C" description="" pkeyName="PK_OV_TABLE_C">
+<property xsi:type="Data" name="DataC"/>
</column>
</column>
</column>
+<column name="DATAE" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
</column>
+<column name="OV_COL_D" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="OV_COL_D" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OV_COL_F" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="DATAE" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="OV_COL_F" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OV_GEOMCOL_F" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
-<column name="OV_GEOMCOL_F" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
</column>
</table>
<tables>
-</table>
+<table name="OV_TABLE_C" description="" pkeyName="PK_OV_TABLE_C"/>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassD" description="a class"
- baseClass="OvClassC" abstract="False"
- tableName="OV_TABLE_C" tblCreator="False" fixedTbl="False" >
-<tableMapping>Base</tableMapping>
+<class xsi:type="Feature" name="OvClassD" description="a class" baseClass="OvClassC" abstract="False" tableName="OV_TABLE_C" tblCreator="False" fixedTbl="False">
+<geometryProperty>
+<tableMapping>
+Base</tableMapping>
<properties>
- tableName="OV_TABLE_C" columnName="CLASSID" colCreator="False" fixedCol="True" >
-</column>
</property>
- tableName="OV_TABLE_C" columnName="DATAA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_C" columnName="CLASSID" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_C" columnName="OV_COL_B" colCreator="False" fixedCol="True" >
</column>
</property>
- tableName="OV_TABLE_C" columnName="DATAC" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassC" />
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="DATAA" colCreator="False" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="DataD" description="a data property"
- tableName="OV_TABLE_C" columnName="OV_COL_D" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="OV_COL_B" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_C" columnName="FEATID" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="DataC" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="DATAC" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassC"/>
</column>
</property>
- tableName="OV_TABLE_C" columnName="OV_GEOMCOL_A" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="DataD" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="OV_COL_D" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_C" columnName="REVISIONNUMBER" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_C" columnName="FEATID" colCreator="False" fixedCol="False">
</column>
</property>
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_C" columnName="OV_GEOMCOL_A" colCreator="False" fixedCol="True">
+</column>
</property>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_C" columnName="REVISIONNUMBER" colCreator="False" fixedCol="True">
</column>
</property>
</column>
</property>
</properties>
-<property xsi:type="Data" name="DataD" />
+<property xsi:type="Data" name="DataD"/>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassE" description="a class"
- baseClass="OvClassD" abstract="False"
+<class xsi:type="Feature" name="OvClassE" description="a class" baseClass="OvClassD" abstract="False" tableName="OV_TABLE_C" tblCreator="False" fixedTbl="False">
+<geometryProperty>
+<tableMapping>
<properties>
-</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
- tableName="OV_TABLE_C" columnName="OV_COL_D" colCreator="False" fixedCol="True" >
-<Inherited baseClass="OvClassD" />
</column>
</property>
-<property xsi:type="Data" name="DataE" description="a data property"
- tableName="OV_TABLE_C" columnName="DATAE" colCreator="True" fixedCol="False" >
</column>
</property>
+<property xsi:type="Data" name="DataD" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="OV_COL_D" colCreator="False" fixedCol="True">
+<Inherited baseClass="OvClassD"/>
</column>
</property>
+<property xsi:type="Data" name="DataE" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="DATAE" colCreator="True" fixedCol="False">
</column>
</property>
</column>
</property>
+</column>
</property>
</column>
</property>
</column>
</property>
</properties>
-<property xsi:type="Data" name="DataE" />
+<property xsi:type="Data" name="DataE"/>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassF" description="a class"
- baseClass="OvClassE" abstract="False"
+<class xsi:type="Feature" name="OvClassF" description="a class" baseClass="OvClassE" abstract="False" tableName="OV_TABLE_C" tblCreator="False" fixedTbl="False">
+<geometryProperty>
+<tableMapping>
<properties>
-</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
- tableName="OV_TABLE_C" columnName="DATAE" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassE" />
</column>
</property>
-<property xsi:type="Data" name="DataF" description="a data property"
- tableName="OV_TABLE_C" columnName="OV_COL_F" colCreator="True" fixedCol="True" >
</column>
</property>
+<property xsi:type="Data" name="DataE" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="DATAE" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassE"/>
</column>
</property>
+<property xsi:type="Data" name="DataF" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_C" columnName="OV_COL_F" colCreator="True" fixedCol="True">
</column>
</property>
-<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property"
- tableName="OV_TABLE_C" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True" >
</column>
</property>
</column>
</property>
+<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_C" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True">
+</column>
</property>
</column>
</property>
</column>
</property>
</properties>
-<property xsi:type="Data" name="DataF" />
-<property xsi:type="Geometric" name="GeomF" />
+<property xsi:type="Data" name="DataF"/>
+<property xsi:type="Geometric" name="GeomF"/>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassG" description="a class"
- baseClass="OvClassF" abstract="False"
- tableName="OVCLASSG" tblCreator="True" fixedTbl="False" >
+<class xsi:type="Feature" name="OvClassG" description="a class" baseClass="OvClassF" abstract="False" tableName="OVCLASSG" tblCreator="True" fixedTbl="False">
+<geometryProperty>
+<tableMapping>
<properties>
- tableName="OVCLASSG" columnName="CLASSID" colCreator="True" fixedCol="True" >
-</column>
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="OVCLASSG" columnName="n/a" colCreator="False" fixedCol="False">
</property>
- tableName="OVCLASSG" columnName="DATAA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSG" columnName="CLASSID" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSG" columnName="OV_COL_B" colCreator="True" fixedCol="True" >
</column>
</property>
- tableName="OVCLASSG" columnName="DATAC" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="DATAA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSG" columnName="OV_COL_D" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="OV_COL_B" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSG" columnName="DATAE" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataC" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="DATAC" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSG" columnName="OV_COL_F" colCreator="True" fixedCol="True" >
-<Inherited baseClass="OvClassF" />
+<property xsi:type="Data" name="DataD" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="OV_COL_D" colCreator="True" fixedCol="True">
</column>
</property>
-<property xsi:type="Data" name="DataG" description="a data property"
- tableName="OVCLASSG" columnName="DATAG" colCreator="True" fixedCol="False" >
-<column name="DATAG" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="DataE" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="DATAE" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSG" columnName="FEATID" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataF" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="OV_COL_F" colCreator="True" fixedCol="True">
+<Inherited baseClass="OvClassF"/>
</column>
</property>
- tableName="OVCLASSG" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataG" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSG" columnName="DATAG" colCreator="True" fixedCol="False">
+<column name="DATAG" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- tableName="OVCLASSG" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSG" columnName="FEATID" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSG" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSG" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSG" columnName="n/a" colCreator="False" fixedCol="False" >
+<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSG" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True">
+</column>
</property>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSG" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True">
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSG" description="" pkeyName="PK_OVCLASSG" >
-<property xsi:type="Data" name="DataG" />
+<table name="OVCLASSG" description="" pkeyName="PK_OVCLASSG">
+<property xsi:type="Data" name="DataG"/>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
+<table name="OVCLASSG" description="" pkeyName="PK_OVCLASSG"/>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassH" description="a class"
- baseClass="OvClassG" abstract="False"
- tableName="OVCLASSH" tblCreator="True" fixedTbl="False" >
+<class xsi:type="Feature" name="OvClassH" description="a class" baseClass="OvClassG" abstract="False" tableName="OVCLASSH" tblCreator="True" fixedTbl="False">
+<geometryProperty>
+<tableMapping>
<properties>
- tableName="OVCLASSH" columnName="CLASSID" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="OVCLASSH" columnName="n/a" colCreator="False" fixedCol="False">
+</property>
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSH" columnName="CLASSID" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH" columnName="DATAA" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="OVCLASSH" columnName="OV_COL_B" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAA" colCreator="True" fixedCol="False">
</column>
+</property>
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_B" colCreator="True" fixedCol="True">
+</column>
</property>
- tableName="OVCLASSH" columnName="DATAC" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataC" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAC" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="OV_COL_D" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataD" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_D" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH" columnName="DATAE" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataE" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAE" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="OV_COL_F" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataF" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_F" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH" columnName="DATAG" colCreator="True" fixedCol="False" >
-<Inherited baseClass="OvClassG" />
+<property xsi:type="Data" name="DataG" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAG" colCreator="True" fixedCol="False">
+<Inherited baseClass="OvClassG"/>
</column>
</property>
-<property xsi:type="Data" name="DataH" description="a data property"
- tableName="OVCLASSH" columnName="OV_COL_H" colCreator="True" fixedCol="True" >
-<column name="OV_COL_H" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="DataH" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_H" colCreator="True" fixedCol="True">
+<column name="OV_COL_H" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
<sequence name="OV_SEQ_2"/>
</property>
- tableName="OVCLASSH" columnName="FEATID" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSH" columnName="FEATID" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSH" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSH" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True">
</column>
</property>
-<property xsi:type="Object" name="ObjectA" description=""
- objectType="Value" className="OverridesA:OvOpClassHA" idColumn="" order="ascending"
- fixedCol="False" >
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHA" idColumn="" order="ascending" fixedCol="False">
<mappingDefinition xsi:type="Single" prefix="prefixA">
-<class xsi:type="Class" name="OvClassH.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSH" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassH.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<identityProperties>
</identityProperties>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHAA" idColumn="" order="ascending"
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHAA" idColumn="" order="ascending" fixedCol="False">
<mappingDefinition xsi:type="Single" prefix="prefixA_prefixA">
-<class xsi:type="Class" name="OvClassH.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassH.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHAAA" idColumn="" order="ascending"
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHAAA" idColumn="" order="ascending" fixedCol="False">
<mappingDefinition xsi:type="Single" prefix="prefixA_prefixA_prefixA">
-<class xsi:type="Class" name="OvClassH.ObjectA.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassH.ObjectA.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
-<property xsi:type="Data" name="OpA" description="first data property"
- tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPA" colCreator="True" fixedCol="False" >
-<column name="REFIXA_PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
-<property xsi:type="Data" name="OpB" description="first data property"
- tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPB" colCreator="True" fixedCol="False" >
-<column name="REFIXA_PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPA" colCreator="True" fixedCol="False">
+<column name="REFIXA_PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPB" colCreator="True" fixedCol="False">
+<column name="REFIXA_PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSH" description="" pkeyName="PK_OVCLASSH" >
-<property xsi:type="Data" name="OpA" />
-<property xsi:type="Data" name="OpB" />
+<table name="OVCLASSH" description="" pkeyName="PK_OVCLASSH">
+<property xsi:type="Data" name="OpA"/>
+<property xsi:type="Data" name="OpB"/>
</column>
</column>
</column>
</column>
</column>
+<column name="DATAI" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
+<column name="GEOMI" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
</column>
</column>
</column>
</column>
</column>
-<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
+<column name="PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
+<column name="PREFIXB_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="PREFIXB_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="PREFIXB_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="PREFIXB_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="PREFIXE_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="GEOMI" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+<column name="PREFIXE_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="DATAI" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXE_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXE_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</table>
<tables>
-</table>
+<table name="OVCLASSH" description="" pkeyName="PK_OVCLASSH"/>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -1377,107 +1070,86 @@
</class>
</mappingDefinition>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPB" colCreator="True" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -1485,107 +1157,86 @@
</class>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -1593,224 +1244,181 @@
</class>
</property>
-<property xsi:type="Object" name="ObjectB" description=""
- objectType="Value" className="OverridesA:OvOpClassHB" idColumn="" order="ascending"
+<property xsi:type="Object" name="ObjectB" description="" objectType="Value" className="OverridesA:OvOpClassHB" idColumn="" order="ascending" fixedCol="False">
<mappingDefinition xsi:type="Single" prefix="prefixB">
-<class xsi:type="Class" name="OvClassH.ObjectB" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassH.ObjectB" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- objectType="Collection" className="OverridesA:OvOpClassHBA" idColumn="" order="ascending"
-<mappingDefinition xsi:type="Concrete" >
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Collection" className="OverridesA:OvOpClassHBA" idColumn="" order="ascending" fixedCol="False">
+<mappingDefinition xsi:type="Concrete">
<sourceProperties>
</sourceProperties>
<targetProperties>
-<property xsi:type="Data" name="OvClassH_FeatId" />
+<property xsi:type="Data" name="OvClassH_FeatId"/>
</targetProperties>
-<class xsi:type="Class" name="OvClassH.ObjectB.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_OPC_TABLE_HBA" tblCreator="True" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassH.ObjectB.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_OPC_TABLE_HBA" tblCreator="True" fixedTbl="False">
+<tableMapping>
-<property xsi:type="Data" name="OpId1" />
+<property xsi:type="Data" name="OpId1"/>
<properties>
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPA" colCreator="True" fixedCol="False" >
-<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectB.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPB" colCreator="True" fixedCol="False" >
-<column name="OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPA" colCreator="True" fixedCol="False">
+<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
-<property xsi:type="Data" name="OpId1" description="object property id property"
- dataType="int32" length="0" precision="0" scale="0"
- readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPID1" colCreator="True" fixedCol="False" >
-<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPB" colCreator="True" fixedCol="False">
+<column name="OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
-<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OVCLASSH_FEATID" colCreator="True" fixedCol="False" >
-<column name="OVCLASSH_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPID1" colCreator="True" fixedCol="False">
+<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectB.ObjectA"
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OVCLASSH_FEATID" colCreator="True" fixedCol="False">
+<column name="OVCLASSH_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="OverridesA"
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="OverridesA" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
</column>
</property>
</properties>
-<table name="OVCLASSH_OPC_TABLE_HBA" description="" pkeyName="PK_OVCLASSH_OPC_TABLE_HBA" >
+<table name="OVCLASSH_OPC_TABLE_HBA" description="" pkeyName="PK_OVCLASSH_OPC_TABLE1">
<target>
-</table>
<sourceColumns>
-<column name="OVCLASSH_FEATID" />
+<column name="OVCLASSH_FEATID"/>
</sourceColumns>
<targetColumns>
-<column name="FEATID" />
+<column name="FEATID"/>
</targetColumns>
</target>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- tableName="OVCLASSH" columnName="PREFIXB_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXB_OPA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXB_OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXB_OPB" colCreator="True" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
- dataType="string" length="30" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue=""
- tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True" >
-<Inherited baseClass="ClassDefinition" />
-<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False" >
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
+<Inherited baseClass="ClassDefinition"/>
+<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True">
</column>
</property>
-<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name"
- dataType="string" length="255" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue=""
- tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True" >
-<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
-</column>
-</property>
</properties>
</property>
+<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
-<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
-<table name="F_CLASSDEFINITION" description="" pkeyName="" >
+<table name="F_CLASSDEFINITION" description="" pkeyName="">
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -1818,902 +1426,714 @@
</class>
</property>
-<property xsi:type="Object" name="ObjectC" description=""
- objectType="Collection" className="OverridesA:OvOpClassHC" idColumn="" order="ascending"
- fixedCol="True" >
+<property xsi:type="Object" name="ObjectC" description="" objectType="Collection" className="OverridesA:OvOpClassHC" idColumn="" order="ascending" fixedCol="True">
<sourceProperties>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvClassH.ObjectC" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_FTABLEC" tblCreator="True" fixedTbl="True" >
-<tableMapping>Concrete</tableMapping>
+<class xsi:type="Class" name="OvClassH.ObjectC" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLEC" tblCreator="True" fixedTbl="True">
+<tableMapping>
+Concrete</tableMapping>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHCA" idColumn="" order="ascending"
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectC" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False">
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHCA" idColumn="" order="ascending" fixedCol="False">
-<class xsi:type="Class" name="OvClassH.ObjectC.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassH.ObjectC.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectC.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectC.ObjectA"
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSH_FTABLEC" description="" pkeyName="PK_OVCLASSH_FTABLEC" >
+<table name="OVCLASSH_FTABLEC" description="" pkeyName="PK_OVCLASSH_FTABLEC">
</column>
</column>
-<column name="OP_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OP_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="PARENTID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="PARENTID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</column>
</column>
</table>
<tables>
-</table>
-</table>
+<table name="OVCLASSH_FTABLEC" description="" pkeyName="PK_OVCLASSH_FTABLEC"/>
+<table name="F_CLASSDEFINITION" description="" pkeyName=""/>
</tables>
</class>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="OPA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="OP_COL_B" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="OPID1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="OPID1" colCreator="True" fixedCol="False">
</column>
</property>
- dataType="int64" length="0" precision="0" scale="0"
- tableName="OVCLASSH_FTABLEC" columnName="PARENTID" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="PARENTID" colCreator="True" fixedCol="True">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectC"
</column>
</property>
-</column>
-</property>
</properties>
<target>
-</table>
<sourceColumns>
-<column name="PARENTID" />
+<column name="PARENTID"/>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
-<property xsi:type="Object" name="ObjectD" description=""
- objectType="Collection" className="OverridesA:OvOpClassHD" idColumn="OPID1" order="ascending"
- fixedCol="True" >
+<property xsi:type="Object" name="ObjectD" description="" objectType="Collection" className="OverridesA:OvOpClassHD" idColumn="OPID1" order="ascending" fixedCol="True">
<idProperty>
</idProperty>
<sourceProperties>
-<property xsi:type="Data" name="FeatId" />
+<property xsi:type="Data" name="FeatId"/>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvClassH.ObjectD" description="Autogenerated Object Property Class"
- baseClass="" abstract="False"
- tableName="OVCLASSH_FTABLED" tblCreator="True" fixedTbl="True" >
+<class xsi:type="Class" name="OvClassH.ObjectD" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLED" tblCreator="True" fixedTbl="True">
+<tableMapping>
<properties>
- objectType="Collection" className="OverridesA:OvOpClassHDA" idColumn="" order="ascending"
- fixedCol="True" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectD" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Collection" className="OverridesA:OvOpClassHDA" idColumn="" order="ascending" fixedCol="True">
<sourceProperties>
</sourceProperties>
<targetProperties>
-<property xsi:type="Data" name="OvOpClassHD_OpId1" />
+<property xsi:type="Data" name="OvOpClassHD_OpId1"/>
</targetProperties>
-<class xsi:type="Class" name="OvClassH.ObjectD.ObjectA" description="Autogenerated Object Property Class"
- tableName="FNESTED_DA" tblCreator="True" fixedTbl="True" >
+<class xsi:type="Class" name="OvClassH.ObjectD.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="FNESTED_DA" tblCreator="True" fixedTbl="True">
+<tableMapping>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHDAA" idColumn="" order="ascending"
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectD.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHDAA" idColumn="" order="ascending" fixedCol="False">
-<class xsi:type="Class" name="OvClassH.ObjectD.ObjectA.ObjectA" description="Autogenerated Object Property Class"
- tableName="FNESTED_DA" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassH.ObjectD.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="FNESTED_DA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- dataType="string" length="10" precision="0" scale="0"
- readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue=""
- tableName="FNESTED_DA" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectD.ObjectA.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="FNESTED_DA" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectD.ObjectA.ObjectA"
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
-<table name="FNESTED_DA" description="" pkeyName="PK_FNESTED_DA" >
+<table name="FNESTED_DA" description="" pkeyName="PK_FNESTED_DA">
+<column name="NESTED_COL_A" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="NESTED_COL_A" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
-<column name="OVCLASSH_FTABLED_OVCLASSH_FEA1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="OVCLASSH_FTABLED_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False">
</column>
-<column name="OVCLASSH_FTABLED_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+<column name="OVCLASSH_FTABLED_OVCLASSH_F1" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</column>
</column>
</table>
<tables>
-</table>
-</table>
+<table name="FNESTED_DA" description="" pkeyName="PK_FNESTED_DA"/>
</tables>
</class>
</property>
- tableName="FNESTED_DA" columnName="NESTED_COL_A" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="NESTED_COL_A" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="FNESTED_DA" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OP_COL_B" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="FNESTED_DA" columnName="OPID1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OPID1" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_FEA1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_F1" colCreator="True" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="OvOpClassHD_OpId1" description="object property id property"
- tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OPID1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OvOpClassHD_OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OPID1" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectD.ObjectA"
</column>
</property>
-</column>
-</property>
</properties>
<target>
-<table name="OVCLASSH_FTABLED" description="" pkeyName="PK_OVCLASSH_FTABLED" >
+<table name="OVCLASSH_FTABLED" description="" pkeyName="PK_OVCLASSH_FTABLED">
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
-<column name="OVCLASSH_FTABLED_OVCLASSH_FEA1" />
-<column name="OVCLASSH_FTABLED_OPID1" />
+<column name="OVCLASSH_FTABLED_OVCLASSH_F1"/>
+<column name="OVCLASSH_FTABLED_OPID1"/>
</sourceColumns>
<targetColumns>
-<column name="OPID1" />
+<column name="OPID1"/>
</targetColumns>
</target>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OPA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OP_COL_B" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OPID1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OPID1" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OVCLASSH_FEATID" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OVCLASSH_FEATID" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassH.ObjectD"
</column>
</property>
-</column>
-</property>
</properties>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
- fixedCol="True" >
</property>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
-<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated."
- dataType="double" length="0" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue=""
- tableName="OVCLASSH" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
-<Inherited baseClass="Feature" />
-<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False" >
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSH" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True">
+<Inherited baseClass="Feature"/>
+<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False">
</column>
</property>
-<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature"
-geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False"
- tableName="OVCLASSH" columnName="n/a" colCreator="False" fixedCol="False" >
-</property>
</column>
</property>
-</column>
-</property>
</properties>
-<property xsi:type="Data" name="ClassId" />
-<property xsi:type="Data" name="DataA" />
-<property xsi:type="Data" name="DataB" />
-<property xsi:type="Data" name="DataC" />
-<property xsi:type="Data" name="DataH" />
-<property xsi:type="Geometric" name="GeomA" />
+<property xsi:type="Data" name="ClassId"/>
+<property xsi:type="Data" name="DataA"/>
+<property xsi:type="Data" name="DataB"/>
+<property xsi:type="Data" name="DataC"/>
+<property xsi:type="Data" name="DataH"/>
+<property xsi:type="Geometric" name="GeomA"/>
</property>
</property>
- fixedCol="True" >
</property>
- fixedCol="True" >
</property>
-<property xsi:type="Data" name="RevisionNumber" />
+<property xsi:type="Data" name="RevisionNumber"/>
</column>
+<column name="DATAA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="OV_COL_F" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="DATAC" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="OV_GEOMCOL_F" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+<column name="DATAE" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="DATAE" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="OV_COL_D" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="DATAC" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
-<column name="OV_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="OV_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="DATAA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OV_COL_D" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="OV_GEOMCOL_A" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+<column name="OV_COL_F" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
+<column name="OV_GEOMCOL_A" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
+<column name="OV_GEOMCOL_F" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
-<column name="CLASSID" />
+<column name="CLASSID"/>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassI" description="a class"
- baseClass="OvClassH" abstract="False"
-<geometryProperty>GeomA</geometryProperty>
-<tableMapping>Base</tableMapping>
+<class xsi:type="Feature" name="OvClassI" description="a class" baseClass="OvClassH" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<geometryProperty>
+GeomA</geometryProperty>
+<tableMapping>
+Base</tableMapping>
<properties>
-<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)"
- tableName="OVCLASSH" columnName="CLASSID" colCreator="False" fixedCol="True" >
+</property>
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSH" columnName="CLASSID" colCreator="False" fixedCol="True">
</column>
</property>
-<property xsi:type="Data" name="DataA" description="a data property"
- tableName="OVCLASSH" columnName="DATAA" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassA" />
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
-<property xsi:type="Data" name="DataB" description="a data property"
- tableName="OVCLASSH" columnName="OV_COL_B" colCreator="False" fixedCol="True" >
-<Inherited baseClass="OvClassB" />
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAA" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassA"/>
</column>
+</property>
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_B" colCreator="False" fixedCol="True">
+<Inherited baseClass="OvClassB"/>
+</column>
<sequence name="OV_SEQ_1"/>
</property>
-<property xsi:type="Data" name="DataC" description="a data property"
- tableName="OVCLASSH" columnName="DATAC" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassC" />
+<property xsi:type="Data" name="DataC" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAC" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassC"/>
</column>
</property>
-<property xsi:type="Data" name="DataD" description="a data property"
- tableName="OVCLASSH" columnName="OV_COL_D" colCreator="False" fixedCol="True" >
-<Inherited baseClass="OvClassD" />
+<property xsi:type="Data" name="DataD" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_D" colCreator="False" fixedCol="True">
+<Inherited baseClass="OvClassD"/>
</column>
</property>
-<property xsi:type="Data" name="DataE" description="a data property"
- tableName="OVCLASSH" columnName="DATAE" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="DataE" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAE" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="OV_COL_F" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="DataF" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_F" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH" columnName="DATAG" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="DataG" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAG" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="OV_COL_H" colCreator="False" fixedCol="True" >
-<Inherited baseClass="OvClassH" />
+<property xsi:type="Data" name="DataH" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="OV_COL_H" colCreator="False" fixedCol="True">
+<Inherited baseClass="OvClassH"/>
</column>
</property>
-<property xsi:type="Data" name="DataI" description="a data property"
- tableName="OVCLASSH" columnName="DATAI" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataI" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="DATAI" colCreator="True" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)"
- readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue=""
- tableName="OVCLASSH" columnName="FEATID" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSH" columnName="FEATID" colCreator="False" fixedCol="False">
</column>
</property>
-<property xsi:type="Geometric" name="GeomA" description="a geometry property"
-geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False"
- tableName="OVCLASSH" columnName="OV_GEOMCOL_A" colCreator="False" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSH" columnName="OV_GEOMCOL_A" colCreator="False" fixedCol="True">
</column>
</property>
-<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property"
- tableName="OVCLASSH" columnName="OV_GEOMCOL_F" colCreator="False" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSH" columnName="OV_GEOMCOL_F" colCreator="False" fixedCol="True">
</column>
</property>
-<property xsi:type="Geometric" name="GeomI" description="another secondary geometric property"
- tableName="OVCLASSH" columnName="GEOMI" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomI" description="another secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OVCLASSH" columnName="GEOMI" colCreator="True" fixedCol="True">
</column>
</property>
-<class xsi:type="Class" name="OvClassI.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassI.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
-<Inherited baseClass="OvClassH.ObjectA" />
+</column>
+</property>
+<Inherited baseClass="OvClassH.ObjectA"/>
-<class xsi:type="Class" name="OvClassI.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassI.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
-<Inherited baseClass="OvClassH.ObjectA.ObjectA" />
+</column>
+</property>
+<Inherited baseClass="OvClassH.ObjectA.ObjectA"/>
-<class xsi:type="Class" name="OvClassI.ObjectA.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassI.ObjectA.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassH.ObjectA.ObjectA.ObjectA" />
</column>
</property>
- tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassH.ObjectA.ObjectA.ObjectA"/>
</column>
</property>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="REFIXA_PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
</column>
-<column name="DATAG" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -2721,109 +2141,88 @@
</class>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
+<column name="DATAG" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -2831,109 +2230,88 @@
</class>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -2941,232 +2319,189 @@
</class>
</property>
-<class xsi:type="Class" name="OvClassI.ObjectB" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassI.ObjectB" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
-<Inherited baseClass="OvClassH.ObjectB" />
+</column>
+</property>
+<Inherited baseClass="OvClassH.ObjectB"/>
<sourceProperties>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvClassI.ObjectB.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_OPC_TABLE_HBA" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassI.ObjectB.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_OPC_TABLE_HBA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPA" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassH.ObjectB.ObjectA" />
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectB.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPA" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassH.ObjectB.ObjectA"/>
</column>
</property>
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPID1" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPB" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OVCLASSH_FEATID" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OPID1" colCreator="False" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectB.ObjectA"
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_OPC_TABLE_HBA" columnName="OVCLASSH_FEATID" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- tableName="OVCLASSH" columnName="PREFIXB_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXB_OPA" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXB_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXB_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
-<column name="OV_COL_H" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
+<column name="OV_COL_H" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -3174,1173 +2509,934 @@
</class>
</property>
-<property xsi:type="Object" name="ObjectE" description=""
- objectType="Value" className="OverridesA:OvOpClassIE" idColumn="" order="ascending"
-<mappingDefinition xsi:type="Single" prefix="prefixE">
-<class xsi:type="Class" name="OvClassI.ObjectE" description="Autogenerated Object Property Class"
+<sourceProperties>
+</sourceProperties>
+<targetProperties>
+</targetProperties>
+<class xsi:type="Class" name="OvClassI.ObjectC" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
- tableName="OVCLASSH" columnName="PREFIXE_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectC" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH" columnName="PREFIXE_OPB" colCreator="True" fixedCol="False" >
+<Inherited baseClass="OvClassH.ObjectC"/>
+<mappingDefinition xsi:type="Single" prefix="prefixA">
+<class xsi:type="Class" name="OvClassI.ObjectC.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="False">
+<tableMapping>
+<identityProperties>
+</identityProperties>
+<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectC.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassH.ObjectC.ObjectA"/>
</column>
</property>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
+</column>
+</property>
</properties>
</column>
</column>
</column>
</column>
</column>
</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-<column name="REFIXA_PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
-</column>
-<column name="REFIXA_PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
</table>
<tables>
-</table>
-<target>
-</table>
-<sourceColumns>
-</sourceColumns>
-<targetColumns>
-</targetColumns>
-</target>
-</table>
</tables>
</class>
</property>
-<property xsi:type="Object" name="ObjectF" description=""
- objectType="Collection" className="OverridesA:OvOpClassIF" idColumn="OPID1" order="ascending"
- fixedCol="True" >
-<idProperty>
-</idProperty>
-<sourceProperties>
-</sourceProperties>
-<targetProperties>
-<property xsi:type="Data" name="OvClassI_FeatId" />
-</targetProperties>
-<class xsi:type="Class" name="OvClassI.ObjectF" description="Autogenerated Object Property Class"
- tableName="OVCLASSI_FTABLEF" tblCreator="True" fixedTbl="True" >
-<identityProperties>
-</identityProperties>
-<properties>
-<property xsi:type="Data" name="OpA" description="first data property"
- tableName="OVCLASSI_FTABLEF" columnName="OP_PROP_A" colCreator="True" fixedCol="True" >
-<column name="OP_PROP_A" description="" dataType="VARCHAR2" length="10" scale="0" nullable="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="OPA" colCreator="False" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="OpB" description="first data property"
- tableName="OVCLASSI_FTABLEF" columnName="OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="OP_COL_B" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSI_FTABLEF" columnName="OPID1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="OPID1" colCreator="False" fixedCol="False">
</column>
</property>
-<property xsi:type="Data" name="OvClassI_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="OVCLASSI_FTABLEF" columnName="PARENTID" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLEC" columnName="PARENTID" colCreator="False" fixedCol="True">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectF"
</column>
</property>
-</column>
-</property>
</properties>
-<table name="OVCLASSI_FTABLEF" description="" pkeyName="PK_OVCLASSI_FTABLEF" >
<target>
-<table name="OVCLASSH" description="" pkeyName="PK_OVCLASSH" >
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
-<property xsi:type="Data" name="OpA" />
-<property xsi:type="Data" name="OpB" />
+</property>
+<property xsi:type="Data" name="OpA"/>
+<property xsi:type="Data" name="OpB"/>
</column>
</column>
</column>
</column>
+<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
</table>
<tables>
<target>
-</table>
+<table name="OVCLASSH" description="" pkeyName="PK_OVCLASSH"/>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</mappingDefinition>
</property>
- tableName="OVCLASSH" columnName="REVISIONNUMBER" colCreator="False" fixedCol="True" >
+<idProperty>
+</idProperty>
+<sourceProperties>
+<targetProperties>
+<class xsi:type="Class" name="OvClassI.ObjectD" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLED" tblCreator="False" fixedTbl="True">
+<tableMapping>
+<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectD" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- fixedCol="True" >
+<Inherited baseClass="OvClassH.ObjectD"/>
<sourceProperties>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvClassI.ObjectC" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="OvClassI.ObjectD.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="FNESTED_DA" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
-<property xsi:type="Object" name="ObjectA" description=""
- fixedCol="False" >
-<Inherited baseClass="OvClassH.ObjectC" />
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectD.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
+<Inherited baseClass="OvClassH.ObjectD.ObjectA"/>
-<class xsi:type="Class" name="OvClassI.ObjectC.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassI.ObjectD.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="FNESTED_DA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassH.ObjectC.ObjectA" />
-<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectD.ObjectA.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False" >
-<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassH.ObjectD.ObjectA.ObjectA"/>
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectC.ObjectA"
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
</column>
</column>
</column>
</column>
</column>
</column>
+</column>
</table>
<tables>
-</table>
-</table>
</tables>
</class>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="NESTED_COL_A" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="OP_COL_B" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OP_COL_B" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="OPID1" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OPID1" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OVCLASSH_FTABLEC" columnName="PARENTID" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_F1" colCreator="False" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectC"
+<property xsi:type="Data" name="OvOpClassHD_OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OPID1" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
<target>
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</property>
-<property xsi:type="Data" name="OpId1" />
-<property xsi:type="Data" name="OvClassH_FeatId" />
-<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+<property xsi:type="Data" name="OpId1"/>
+<property xsi:type="Data" name="OvClassH_FeatId"/>
</column>
-<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False">
</column>
</column>
</column>
</column>
</column>
+</column>
</table>
<tables>
<target>
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- fixedCol="True" >
-<idProperty>
-</idProperty>
-<mappingDefinition xsi:type="Concrete" >
-<sourceProperties>
-<targetProperties>
-<class xsi:type="Class" name="OvClassI.ObjectD" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_FTABLED" tblCreator="False" fixedTbl="True" >
-<properties>
- fixedCol="True" >
-<Inherited baseClass="OvClassH.ObjectD" />
-<sourceProperties>
-<targetProperties>
-<class xsi:type="Class" name="OvClassI.ObjectD.ObjectA" description="Autogenerated Object Property Class"
- tableName="FNESTED_DA" tblCreator="False" fixedTbl="True" >
-<properties>
-<Inherited baseClass="OvClassH.ObjectD.ObjectA" />
-<mappingDefinition xsi:type="Single" prefix="prefixA">
-<class xsi:type="Class" name="OvClassI.ObjectD.ObjectA.ObjectA" description="Autogenerated Object Property Class"
-<properties>
- tableName="FNESTED_DA" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassH.ObjectD.ObjectA.ObjectA" />
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OPA" colCreator="False" fixedCol="False">
+<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- tableName="FNESTED_DA" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OP_COL_B" colCreator="False" fixedCol="True">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectD.ObjectA.ObjectA"
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OPID1" colCreator="False" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="OverridesA"
+<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSH_FTABLED" columnName="OVCLASSH_FEATID" colCreator="False" fixedCol="False">
+<column name="OVCLASSH_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</property>
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="OverridesA" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
+<Inherited baseClass="ClassDefinition"/>
+<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True">
+</column>
+</property>
</properties>
+<target>
+<sourceColumns>
+<column name="OVCLASSH_FEATID"/>
+</sourceColumns>
+<targetColumns>
+<column name="FEATID"/>
+</targetColumns>
+</target>
+</property>
</column>
</column>
</column>
</column>
-</column>
-</column>
-</column>
</table>
<tables>
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
</table>
-</table>
</tables>
</class>
</property>
- tableName="FNESTED_DA" columnName="NESTED_COL_A" colCreator="False" fixedCol="True" >
+<property xsi:type="Object" name="ObjectE" description="" objectType="Value" className="OverridesA:OvOpClassIE" idColumn="" order="ascending" fixedCol="False">
+<mappingDefinition xsi:type="Single" prefix="prefixE">
+<class xsi:type="Class" name="OvClassI.ObjectE" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH" tblCreator="False" fixedTbl="False">
+<tableMapping>
+<properties>
</column>
</property>
- tableName="FNESTED_DA" columnName="OP_COL_B" colCreator="False" fixedCol="True" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXE_OPA" colCreator="True" fixedCol="False">
+<column name="PREFIXE_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
-<property xsi:type="Data" name="OpId1" description="object property id property"
- dataType="int32" length="0" precision="0" scale="0"
- readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
- tableName="FNESTED_DA" columnName="OPID1" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSH" columnName="PREFIXE_OPB" colCreator="True" fixedCol="False">
+<column name="PREFIXE_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
-<property xsi:type="Data" name="OvClassH_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OVCLASSH_FEA1" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="FNESTED_DA" columnName="OVCLASSH_FTABLED_OPID1" colCreator="False" fixedCol="False" >
+</properties>
+<table name="OVCLASSH" description="" pkeyName="PK_OVCLASSH">
+<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
-</property>
-<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
- dataType="string" length="30" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectD.ObjectA"
- tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True" >
-<Inherited baseClass="ClassDefinition" />
-<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False" >
</column>
-</property>
-<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name"
- dataType="string" length="255" precision="0" scale="0"
- tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True" >
-<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
</column>
-</property>
-</properties>
-<target>
-<target>
-</table>
-<sourceColumns>
-<column name="OVCLASSH_FEATID" />
-</sourceColumns>
-<targetColumns>
-<column name="FEATID" />
-</targetColumns>
-</target>
-</table>
-<sourceColumns>
-</sourceColumns>
-<targetColumns>
-</targetColumns>
-</target>
-</property>
</column>
</column>
+<column name="DATAI" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
+<column name="GEOMI" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
</column>
</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+<column name="PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+<column name="PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+<column name="PREFIXB_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+<column name="PREFIXB_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+</column>
+</column>
+<column name="REFIXA_PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+<column name="REFIXA_PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+</column>
</table>
<tables>
+<table name="F_CLASSDEFINITION" description="" pkeyName="">
<target>
-<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-<sourceColumns>
-</sourceColumns>
-<targetColumns>
-</targetColumns>
-</target>
-</table>
-<table name="F_CLASSDEFINITION" description="" pkeyName="" >
-</table>
</tables>
</class>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Object" name="ObjectF" description="" objectType="Collection" className="OverridesA:OvOpClassIF" idColumn="OPID1" order="ascending" fixedCol="True">
+<idProperty>
+</idProperty>
+<mappingDefinition xsi:type="Concrete">
+<sourceProperties>
+<targetProperties>
+<property xsi:type="Data" name="OvClassI_FeatId"/>
+<class xsi:type="Class" name="OvClassI.ObjectF" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSI_FTABLEF" tblCreator="True" fixedTbl="True">
+<tableMapping>
+Concrete</tableMapping>
+<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectF" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False">
</column>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OP_COL_B" colCreator="False" fixedCol="True" >
-<column name="OP_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="OP_PROP_A" colCreator="True" fixedCol="True">
+<column name="OP_PROP_A" description="" dataType="VARCHAR2" length="10" scale="0" nullable="False">
</column>
</property>
- tableName="OVCLASSH_FTABLED" columnName="OPID1" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="OPB" colCreator="True" fixedCol="False">
+<column name="OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- dataType="int64" length="0" precision="0" scale="0"
- tableName="OVCLASSH_FTABLED" columnName="OVCLASSH_FEATID" colCreator="False" fixedCol="False" >
-<column name="OVCLASSH_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="OPID1" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassI.ObjectD"
+<property xsi:type="Data" name="OvClassI_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="PARENTID" colCreator="True" fixedCol="True">
+<column name="PARENTID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</property>
</column>
</property>
</properties>
+<table name="OVCLASSI_FTABLEF" description="" pkeyName="PK_OVCLASSI_FTABLEF">
<target>
-</table>
<sourceColumns>
+<column name="PARENTID"/>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
- objectType="Collection" className="OverridesA:OvOpClassHDA" idColumn="" order="ascending"
- fixedCol="True" >
-</property>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
+<table name="F_CLASSDEFINITION" description="" pkeyName=""/>
</tables>
</class>
</property>
-</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue=""
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OVCLASSH" columnName="REVISIONNUMBER" colCreator="False" fixedCol="True">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue=""
</column>
</property>
</properties>
-<property xsi:type="Data" name="DataD" />
-<property xsi:type="Data" name="DataE" />
-<property xsi:type="Data" name="DataF" />
-<property xsi:type="Data" name="DataG" />
-<property xsi:type="Data" name="DataI" />
-<property xsi:type="Data" name="FeatId" />
-<property xsi:type="Geometric" name="GeomF" />
-<property xsi:type="Geometric" name="GeomI" />
- objectType="Value" className="OverridesA:OvOpClassHA" idColumn="" order="ascending"
+<property xsi:type="Data" name="DataD"/>
+<property xsi:type="Data" name="DataE"/>
+<property xsi:type="Data" name="DataF"/>
+<property xsi:type="Data" name="DataG"/>
+<property xsi:type="Data" name="DataI"/>
+<property xsi:type="Data" name="FeatId"/>
+<property xsi:type="Geometric" name="GeomF"/>
+<property xsi:type="Geometric" name="GeomI"/>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHA" idColumn="" order="ascending" fixedCol="False">
</property>
-<property xsi:type="Object" name="ObjectB" description=""
- objectType="Value" className="OverridesA:OvOpClassHB" idColumn="" order="ascending"
+<property xsi:type="Object" name="ObjectB" description="" objectType="Value" className="OverridesA:OvOpClassHB" idColumn="" order="ascending" fixedCol="False">
</property>
+<property xsi:type="Object" name="ObjectC" description="" objectType="Collection" className="OverridesA:OvOpClassHC" idColumn="" order="ascending" fixedCol="True">
</property>
- fixedCol="True" >
+<property xsi:type="Object" name="ObjectD" description="" objectType="Collection" className="OverridesA:OvOpClassHD" idColumn="OPID1" order="ascending" fixedCol="True">
</property>
-<property xsi:type="Object" name="ObjectC" description=""
- objectType="Collection" className="OverridesA:OvOpClassHC" idColumn="" order="ascending"
- fixedCol="True" >
</property>
-<property xsi:type="Object" name="ObjectD" description=""
- objectType="Collection" className="OverridesA:OvOpClassHD" idColumn="OPID1" order="ascending"
- fixedCol="True" >
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
-<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</column>
</column>
</column>
-<column name="PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
</column>
-<column name="PREFIXB_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXB_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="GEOMI" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
</column>
-<column name="DATAI" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXE_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXE_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Feature" name="OvClassJ" description="a class"
- baseClass="OvClassI" abstract="False"
- tableName="OV_TABLE_J" tblCreator="True" fixedTbl="True" >
-<tableMapping>Concrete</tableMapping>
+<class xsi:type="Feature" name="OvClassJ" description="a class" baseClass="OvClassI" abstract="False" tableName="OV_TABLE_J" tblCreator="True" fixedTbl="True">
+<geometryProperty>
+<tableMapping>
<properties>
- tableName="OV_TABLE_J" columnName="CLASSID" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature" geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_J" columnName="n/a" colCreator="False" fixedCol="False">
+</property>
+<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_J" columnName="CLASSID" colCreator="True" fixedCol="True">
</column>
</property>
- dataType="string" length="10" precision="0" scale="0"
- readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue=""
- tableName="OV_TABLE_J" columnName="DATAA" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="OV_TABLE_J" columnName="OV_COL_B" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataA" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="DATAA" colCreator="True" fixedCol="False">
</column>
+</property>
+<property xsi:type="Data" name="DataB" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="OV_COL_B" colCreator="True" fixedCol="True">
+</column>
</property>
- tableName="OV_TABLE_J" columnName="DATAC" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="DataC" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="DATAC" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OV_TABLE_J" columnName="OV_COL_D" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataD" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="OV_COL_D" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_J" columnName="DATAE" colCreator="True" fixedCol="False" >
-<Inherited baseClass="OvClassE" />
+<property xsi:type="Data" name="DataE" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="DATAE" colCreator="True" fixedCol="False">
+<Inherited baseClass="OvClassE"/>
</column>
</property>
-<property xsi:type="Data" name="DataF" description="a data property"
- tableName="OV_TABLE_J" columnName="OV_COL_F" colCreator="True" fixedCol="True" >
-<Inherited baseClass="OvClassF" />
+<property xsi:type="Data" name="DataF" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="OV_COL_F" colCreator="True" fixedCol="True">
+<Inherited baseClass="OvClassF"/>
</column>
</property>
-<property xsi:type="Data" name="DataG" description="a data property"
- tableName="OV_TABLE_J" columnName="DATAG" colCreator="True" fixedCol="False" >
-<Inherited baseClass="OvClassG" />
+<property xsi:type="Data" name="DataG" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="DATAG" colCreator="True" fixedCol="False">
+<Inherited baseClass="OvClassG"/>
</column>
</property>
-<property xsi:type="Data" name="DataH" description="a data property"
- tableName="OV_TABLE_J" columnName="OV_COL_H" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="DataH" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="OV_COL_H" colCreator="True" fixedCol="True">
</column>
<sequence name="OV_SEQ_2"/>
</property>
- tableName="OV_TABLE_J" columnName="DATAI" colCreator="True" fixedCol="False" >
-<Inherited baseClass="OvClassI" />
+<property xsi:type="Data" name="DataI" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="DATAI" colCreator="True" fixedCol="False">
+<Inherited baseClass="OvClassI"/>
</column>
</property>
-<property xsi:type="Data" name="DataJ" description="a data property"
- tableName="OV_TABLE_J" columnName="OV_COL_J" colCreator="True" fixedCol="True" >
-<column name="OV_COL_J" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="DataJ" description="a data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="OV_COL_J" colCreator="True" fixedCol="True">
+<column name="OV_COL_J" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- tableName="OV_TABLE_J" columnName="FEATID" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="True" featId="True" system="False" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_J" columnName="FEATID" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OV_TABLE_J" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomA" description="a geometry property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_J" columnName="OV_GEOMCOL_A" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_J" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomF" description="a secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_J" columnName="OV_GEOMCOL_F" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_J" columnName="GEOMI" colCreator="True" fixedCol="True" >
+<property xsi:type="Geometric" name="GeomI" description="another secondary geometric property" geometricTypes="15" geometryTypes="126912" hasElevation="False" hasMeasure="False" tableName="OV_TABLE_J" columnName="GEOMI" colCreator="True" fixedCol="True">
</column>
</property>
-<class xsi:type="Class" name="OvClassJ.ObjectA" description="Autogenerated Object Property Class"
- baseClass="" abstract="False"
- tableName="OV_TABLE_J" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassJ.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OV_TABLE_J" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHAA" idColumn="" order="ascending"
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHAA" idColumn="" order="ascending" fixedCol="False">
<mappingDefinition xsi:type="Single" prefix="prefixA_prefixA">
-<class xsi:type="Class" name="OvClassJ.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassJ.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OV_TABLE_J" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHAAA" idColumn="" order="ascending"
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHAAA" idColumn="" order="ascending" fixedCol="False">
<mappingDefinition xsi:type="Single" prefix="prefixA_prefixA_prefixA">
-<class xsi:type="Class" name="OvClassJ.ObjectA.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassJ.ObjectA.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OV_TABLE_J" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OV_TABLE_J" columnName="REFIXA_PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False" >
</column>
</property>
- tableName="OV_TABLE_J" columnName="REFIXA_PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="REFIXA_PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False">
</column>
</property>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="REFIXA_PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
-<table name="OV_TABLE_J" description="" pkeyName="PK_OV_TABLE_J"
- tablespace="SYSTEM" >
+<table name="OV_TABLE_J" description="" pkeyName="PK_OV_TABLE_J" tablespace="SYSTEM">
</column>
+<column name="DATAA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
+<column name="DATAC" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
+<column name="DATAE" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
-<column name="OV_COL_F" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="OV_GEOMCOL_F" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
-<column name="DATAE" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="OV_COL_D" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OV_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="DATAC" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OV_COL_D" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="OV_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<column name="OV_COL_F" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
-<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
-<column name="DATAA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="OV_GEOMCOL_A" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+<column name="OV_GEOMCOL_A" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
+<column name="OV_GEOMCOL_F" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True">
</column>
-<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False" >
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
+<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False">
</column>
</table>
<tables>
-</table>
+<table name="OV_TABLE_J" description="" pkeyName="PK_OV_TABLE_J" tablespace="SYSTEM"/>
<target>
-</table>
<sourceColumns>
-<column name="CLASSID" />
+<column name="CLASSID"/>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -4348,114 +3444,90 @@
</class>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -4463,114 +3535,90 @@
</class>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -4578,239 +3626,191 @@
</class>
</property>
-<Inherited baseClass="OvClassH" />
+<Inherited baseClass="OvClassH"/>
<mappingDefinition xsi:type="Single" prefix="prefixB">
-<class xsi:type="Class" name="OvClassJ.ObjectB" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassJ.ObjectB" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OV_TABLE_J" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- objectType="Collection" className="OverridesA:OvOpClassHBA" idColumn="" order="ascending"
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Collection" className="OverridesA:OvOpClassHBA" idColumn="" order="ascending" fixedCol="False">
<sourceProperties>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvClassJ.ObjectB.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassJ.ObjectB.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_OPC_TABLE_HBA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectB.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
-<column name="OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</property>
</column>
</property>
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectB.ObjectA"
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSH_OPC_TABLE_HBA" description="" pkeyName="PK_OVCLASSH_OPC_TABLE_HBA" >
+<table name="OVCLASSH_OPC_TABLE_HBA" description="" pkeyName="PK_OVCLASSH_OPC_TABLE1">
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXB_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXB_OPA" colCreator="False" fixedCol="False">
</column>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXB_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXB_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -4818,1860 +3818,1355 @@
</class>
</property>
-<class xsi:type="Class" name="OvClassJ.ObjectE" description="Autogenerated Object Property Class"
+<sourceProperties>
+<targetProperties>
+<class xsi:type="Class" name="OvClassJ.ObjectC" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
- tableName="OV_TABLE_J" columnName="PREFIXE_OPA" colCreator="False" fixedCol="False" >
-<Inherited baseClass="OvClassI.ObjectE" />
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectC" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OV_TABLE_J" columnName="PREFIXE_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHCA" idColumn="" order="ascending" fixedCol="False">
+<class xsi:type="Class" name="OvClassJ.ObjectC.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="False">
+<tableMapping>
+<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectC.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
</column>
</property>
</column>
</property>
+</column>
+</property>
</properties>
+<table name="OVCLASSH_FTABLEC" description="" pkeyName="PK_OVCLASSH_FTABLEC">
</column>
</column>
+<column name="OP_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
-<column name="DATAG" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
-</column>
</table>
<tables>
-</table>
-<target>
-</table>
-<sourceColumns>
-</sourceColumns>
-<targetColumns>
-</targetColumns>
-</target>
-</table>
+<table name="OVCLASSH_FTABLEC" description="" pkeyName="PK_OVCLASSH_FTABLEC"/>
</tables>
</class>
</property>
-<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated."
- dataType="double" length="0" precision="0" scale="0"
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue=""
- tableName="OV_TABLE_J" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
-<Inherited baseClass="Feature" />
</column>
</property>
- fixedCol="True" >
-<idProperty>
-</idProperty>
-<sourceProperties>
-<targetProperties>
-<class xsi:type="Class" name="OvClassJ.ObjectF" description="Autogenerated Object Property Class"
- tableName="OVCLASSI_FTABLEF" tblCreator="False" fixedTbl="True" >
-<properties>
- tableName="OVCLASSI_FTABLEF" columnName="OP_PROP_A" colCreator="False" fixedCol="True" >
-<Inherited baseClass="OvClassI.ObjectF" />
</column>
</property>
- tableName="OVCLASSI_FTABLEF" columnName="OPB" colCreator="False" fixedCol="False" >
</column>
</property>
- tableName="OVCLASSI_FTABLEF" columnName="OPID1" colCreator="False" fixedCol="False" >
</column>
</property>
- tableName="OVCLASSI_FTABLEF" columnName="PARENTID" colCreator="False" fixedCol="True" >
-<column name="PARENTID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectF"
-</column>
-</property>
-</column>
-</property>
</properties>
<target>
-</table>
<sourceColumns>
-<column name="PARENTID" />
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
+</property>
</column>
</column>
</column>
</column>
+</column>
+</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- fixedCol="True" >
+<idProperty>
+</idProperty>
<sourceProperties>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvClassJ.ObjectC" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvClassJ.ObjectD" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSH_FTABLED" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
- objectType="Value" className="OverridesA:OvOpClassHCA" idColumn="" order="ascending"
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectD" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Collection" className="OverridesA:OvOpClassHDA" idColumn="" order="ascending" fixedCol="True">
+<sourceProperties>
+<targetProperties>
+<property xsi:type="Data" name="OvOpClassHD_OpId1"/>
+<class xsi:type="Class" name="OvClassJ.ObjectD.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="FNESTED_DA" tblCreator="False" fixedTbl="True">
+<tableMapping>
+<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectD.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Value" className="OverridesA:OvOpClassHDAA" idColumn="" order="ascending" fixedCol="False">
-<class xsi:type="Class" name="OvClassJ.ObjectC.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVCLASSH_FTABLEC" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvClassJ.ObjectD.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="FNESTED_DA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectD.ObjectA.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectC.ObjectA"
</column>
</property>
</column>
</property>
</properties>
-<table name="OVCLASSH_FTABLEC" description="" pkeyName="PK_OVCLASSH_FTABLEC" >
+<table name="FNESTED_DA" description="" pkeyName="PK_FNESTED_DA">
+<column name="NESTED_COL_A" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
</column>
+<column name="OVCLASSH_FTABLED_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False">
</column>
+<column name="OVCLASSH_FTABLED_OVCLASSH_F1" description="" dataType="NUMBER" length="20" scale="0" nullable="False">
</column>
</column>
+</column>
</table>
<tables>
-</table>
-</table>
+<table name="FNESTED_DA" description="" pkeyName="PK_FNESTED_DA"/>
</tables>
</class>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectC"
</column>
</property>
</column>
</property>
</properties>
<target>
+<table name="OVCLASSH_FTABLED" description="" pkeyName="PK_OVCLASSH_FTABLED">
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
</table>
<sourceColumns>
+<column name="OVCLASSH_FTABLED_OVCLASSH_F1"/>
+<column name="OVCLASSH_FTABLED_OPID1"/>
</sourceColumns>
<targetColumns>
+<column name="OPID1"/>
</targetColumns>
</target>
</property>
</column>
</column>
</column>
</column>
</column>
</column>
+</column>
</table>
<tables>
<target>
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</property>
- fixedCol="True" >
-<idProperty>
-</idProperty>
-<sourceProperties>
-<targetProperties>
-<class xsi:type="Class" name="OvClassJ.ObjectD" description="Autogenerated Object Property Class"
-<properties>
- fixedCol="True" >
-<sourceProperties>
-<targetProperties>
-<property xsi:type="Data" name="OvOpClassHD_OpId1" />
-<class xsi:type="Class" name="OvClassJ.ObjectD.ObjectA" description="Autogenerated Object Property Class"
-<properties>
- objectType="Value" className="OverridesA:OvOpClassHDAA" idColumn="" order="ascending"
-<class xsi:type="Class" name="OvClassJ.ObjectD.ObjectA.ObjectA" description="Autogenerated Object Property Class"
- tableName="FNESTED_DA" tblCreator="False" fixedTbl="False" >
-<properties>
</column>
</property>
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectD.ObjectA.ObjectA"
</column>
</property>
</column>
</property>
+</column>
+</property>
</properties>
-<table name="FNESTED_DA" description="" pkeyName="PK_FNESTED_DA" >
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
+</property>
</column>
-<column name="NESTED_COL_A" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
-<column name="OVCLASSH_FTABLED_OVCLASSH_FEA1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
-<column name="OVCLASSH_FTABLED_OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
-</column>
-</column>
-</column>
</table>
<tables>
+<target>
+<sourceColumns>
+</sourceColumns>
+<targetColumns>
+</targetColumns>
+</target>
</table>
-</table>
</tables>
</class>
</property>
+<class xsi:type="Class" name="OvClassJ.ObjectE" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OV_TABLE_J" tblCreator="False" fixedTbl="False">
+<tableMapping>
+<identityProperties>
+</identityProperties>
+<properties>
</column>
</property>
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXE_OPA" colCreator="False" fixedCol="False">
+<Inherited baseClass="OvClassI.ObjectE"/>
</column>
</property>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OV_TABLE_J" columnName="PREFIXE_OPB" colCreator="False" fixedCol="False">
</column>
</property>
</column>
</property>
-<property xsi:type="Data" name="OvOpClassHD_OpId1" description="object property id property"
+</properties>
</column>
-</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectD.ObjectA"
</column>
-</property>
</column>
-</property>
-</properties>
-<target>
-<table name="OVCLASSH_FTABLED" description="" pkeyName="PK_OVCLASSH_FTABLED" >
-<target>
-</table>
-<sourceColumns>
-</sourceColumns>
-<targetColumns>
-</targetColumns>
-</target>
-</table>
-<sourceColumns>
-<column name="OVCLASSH_FTABLED_OVCLASSH_FEA1" />
-<column name="OVCLASSH_FTABLED_OPID1" />
-</sourceColumns>
-<targetColumns>
-<column name="OPID1" />
-</targetColumns>
-</target>
-</property>
</column>
+<column name="DATAG" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
</column>
</column>
</column>
</column>
+</column>
+<column name="OV_COL_H" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
+</column>
</table>
<tables>
<target>
-<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-<sourceColumns>
-</sourceColumns>
-<targetColumns>
-</targetColumns>
-</target>
-</table>
-</table>
</tables>
</class>
</property>
-<property xsi:type="Data" name="OpA" description="first data property"
+<idProperty>
+</idProperty>
+<sourceProperties>
+</sourceProperties>
+<targetProperties>
+</targetProperties>
+<class xsi:type="Class" name="OvClassJ.ObjectF" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVCLASSI_FTABLEF" tblCreator="False" fixedTbl="True">
+<tableMapping>
+<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectF" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
-<property xsi:type="Data" name="OpB" description="first data property"
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="OP_PROP_A" colCreator="False" fixedCol="True">
+<Inherited baseClass="OvClassI.ObjectF"/>
</column>
</property>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="OPB" colCreator="False" fixedCol="False">
</column>
</property>
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="OPID1" colCreator="False" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvClassJ.ObjectD"
+<property xsi:type="Data" name="OvClassI_FeatId" description="Feature id number (uniquely identifies a feature)" dataType="int64" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVCLASSI_FTABLEF" columnName="PARENTID" colCreator="False" fixedCol="True">
</column>
</property>
</column>
</property>
</properties>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
- fixedCol="True" >
-</property>
-<property xsi:type="Data" name="OpA" />
-<property xsi:type="Data" name="OpB" />
+<property xsi:type="Data" name="OpA"/>
+<property xsi:type="Data" name="OpB"/>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
-</table>
</tables>
</class>
</mappingDefinition>
</property>
-<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature"
-geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False"
- tableName="OV_TABLE_J" columnName="n/a" colCreator="False" fixedCol="False" >
-</property>
+<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated." dataType="double" length="0" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue="" tableName="OV_TABLE_J" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True">
+<Inherited baseClass="Feature"/>
</column>
</property>
</column>
</property>
</properties>
-<property xsi:type="Data" name="ClassId" />
-<property xsi:type="Data" name="DataA" />
-<property xsi:type="Data" name="DataB" />
-<property xsi:type="Data" name="DataC" />
-<property xsi:type="Data" name="DataH" />
-<property xsi:type="Data" name="DataJ" />
-<property xsi:type="Geometric" name="GeomA" />
-<property xsi:type="Object" name="ObjectA" description=""
- fixedCol="False" >
+<uniqueConstraints>
+<uniqueConstraint>
+<property xsi:type="Data" name="DataJ"/>
+<property xsi:type="Data" name="DataC"/>
+</uniqueConstraint>
+<uniqueConstraint>
+<property xsi:type="Data" name="DataH"/>
+</uniqueConstraints>
+<property xsi:type="Data" name="ClassId"/>
+<property xsi:type="Data" name="DataA"/>
+<property xsi:type="Data" name="DataB"/>
+<property xsi:type="Geometric" name="GeomA"/>
</property>
</property>
-<property xsi:type="Object" name="ObjectE" description=""
- objectType="Value" className="OverridesA:OvOpClassIE" idColumn="" order="ascending"
</property>
-<property xsi:type="Data" name="RevisionNumber" />
-<property xsi:type="Object" name="ObjectF" description=""
- objectType="Collection" className="OverridesA:OvOpClassIF" idColumn="OPID1" order="ascending"
- fixedCol="True" >
</property>
- fixedCol="True" >
</property>
- fixedCol="True" >
</property>
+<property xsi:type="Data" name="RevisionNumber"/>
</column>
</column>
</column>
-<column name="OV_COL_H" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
</column>
+<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
+<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</column>
-<column name="PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
</column>
-<column name="REFIXA_PREFIXA_PREFIXA_OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
-<column name="REFIXA_PREFIXA_PREFIXA_OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
</column>
</column>
</column>
</table>
<tables>
-</table>
<target>
-</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
</tables>
</class>
-<class xsi:type="Class" name="OvOpClassHA" description="an object property class"
- tableName="OPS_TABLE_HA" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHA" description="an object property class" baseClass="" abstract="False" tableName="OPS_TABLE_HA" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
+</column>
+</property>
-<class xsi:type="Class" name="OvOpClassHA.ObjectA" description="Autogenerated Object Property Class"
- tableName="OPS_TABLE_HA" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvOpClassHA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OPS_TABLE_HA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
+</column>
+</property>
-<class xsi:type="Class" name="OvOpClassHA.ObjectA.ObjectA" description="Autogenerated Object Property Class"
+<class xsi:type="Class" name="OvOpClassHA.ObjectA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OPS_TABLE_HA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OPS_TABLE_HA" columnName="PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False" >
+</column>
</property>
- tableName="OPS_TABLE_HA" columnName="PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HA" columnName="PREFIXA_PREFIXA_OPA" colCreator="False" fixedCol="False">
</property>
-</column>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HA" columnName="PREFIXA_PREFIXA_OPB" colCreator="False" fixedCol="False">
</property>
</column>
</property>
</properties>
</class>
</property>
- tableName="OPS_TABLE_HA" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HA" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False">
</property>
- tableName="OPS_TABLE_HA" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HA" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False">
</property>
</column>
</property>
-</column>
-</property>
</properties>
</class>
</property>
- tableName="OPS_TABLE_HA" columnName="OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HA" columnName="OPA" colCreator="False" fixedCol="False">
</property>
- tableName="OPS_TABLE_HA" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HA" columnName="OPB" colCreator="False" fixedCol="False">
</property>
</column>
</property>
-</column>
-</property>
</properties>
</class>
-<class xsi:type="Class" name="OvOpClassHAA" description="an object property class"
- tableName="OPS_TABLE_HAA" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHAA" description="an object property class" baseClass="" abstract="False" tableName="OPS_TABLE_HAA" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
+</column>
+</property>
<mappingDefinition xsi:type="Single" prefix="prefixA">
-<class xsi:type="Class" name="OvOpClassHAA.ObjectA" description="Autogenerated Object Property Class"
- tableName="OPS_TABLE_HAA" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvOpClassHAA.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OPS_TABLE_HAA" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OPS_TABLE_HAA" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False" >
+</column>
</property>
- tableName="OPS_TABLE_HAA" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HAA" columnName="PREFIXA_OPA" colCreator="False" fixedCol="False">
</property>
-</column>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HAA" columnName="PREFIXA_OPB" colCreator="False" fixedCol="False">
</property>
</column>
</property>
</properties>
</class>
</property>
- tableName="OPS_TABLE_HAA" columnName="OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HAA" columnName="OPA" colCreator="False" fixedCol="False">
</property>
- tableName="OPS_TABLE_HAA" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HAA" columnName="OPB" colCreator="False" fixedCol="False">
</property>
+<Inherited baseClass="ClassDefinition"/>
+<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True">
</column>
</property>
-</column>
-</property>
</properties>
</class>
-<class xsi:type="Class" name="OvOpClassHAAA" description="an object property class"
- tableName="OPS_TABLE_HAAA" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHAAA" description="an object property class" baseClass="" abstract="False" tableName="OPS_TABLE_HAAA" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
- tableName="OPS_TABLE_HAAA" columnName="OPA" colCreator="False" fixedCol="False" >
+</column>
</property>
- tableName="OPS_TABLE_HAAA" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HAAA" columnName="OPA" colCreator="False" fixedCol="False">
</property>
-</column>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HAAA" columnName="OPB" colCreator="False" fixedCol="False">
</property>
</column>
</property>
</properties>
</class>
-<class xsi:type="Class" name="OvOpClassHB" description="an object property class"
- tableName="OPS_TABLE_HB" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHB" description="an object property class" baseClass="" abstract="False" tableName="OPS_TABLE_HB" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
- fixedCol="True" >
-<mappingDefinition xsi:type="Concrete" >
+</column>
+</property>
+<property xsi:type="Object" name="ObjectA" description="" objectType="Collection" className="OverridesA:OvOpClassHBA" idColumn="" order="ascending" fixedCol="True">
<sourceProperties>
</sourceProperties>
<targetProperties>
</targetProperties>
-<class xsi:type="Class" name="OvOpClassHB.ObjectA" description="Autogenerated Object Property Class"
- tableName="OVOPCLASSHB_FTABLEA" tblCreator="False" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHB.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OVOPCLASSHB_FTABLEA" tblCreator="False" fixedTbl="True">
+<tableMapping>
-<property xsi:type="Data" name="OpId1" />
+<property xsi:type="Data" name="OpId1"/>
<properties>
- tableName="OVOPCLASSHB_FTABLEA" columnName="OPA" colCreator="False" fixedCol="False" >
+</column>
</property>
- tableName="OVOPCLASSHB_FTABLEA" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVOPCLASSHB_FTABLEA" columnName="OPA" colCreator="False" fixedCol="False">
</property>
-<property xsi:type="Data" name="OpId1" description="object property id property"
- dataType="int32" length="0" precision="0" scale="0"
- readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
- tableName="OVOPCLASSHB_FTABLEA" columnName="OPID1" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OVOPCLASSHB_FTABLEA" columnName="OPB" colCreator="False" fixedCol="False">
</property>
-<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
- dataType="string" length="30" precision="0" scale="0"
- tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True" >
-<Inherited baseClass="ClassDefinition" />
-<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False" >
-</column>
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OVOPCLASSHB_FTABLEA" columnName="OPID1" colCreator="False" fixedCol="False">
</property>
-<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name"
- dataType="string" length="255" precision="0" scale="0"
- tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True" >
-<column name="SCHEMANAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
</column>
</property>
</properties>
</class>
</property>
- tableName="OPS_TABLE_HB" columnName="OPA" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HB" columnName="OPA" colCreator="False" fixedCol="False">
</property>
- tableName="OPS_TABLE_HB" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HB" columnName="OPB" colCreator="False" fixedCol="False">
</property>
</column>
</property>
-</column>
-</property>
</properties>
</class>
-<class xsi:type="Class" name="OvOpClassHBA" description="an object property class"
- tableName="OPC_TABLE_HBA" tblCreator="True" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHBA" description="an object property class" baseClass="" abstract="False" tableName="OPC_TABLE_HBA" tblCreator="True" fixedTbl="True">
+<tableMapping>
<properties>
- tableName="OPC_TABLE_HBA" columnName="OPA" colCreator="True" fixedCol="False" >
-<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvOpClassHBA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+<column name="CLASSNAME" description="" dataType="VARCHAR2" length="255" scale="0" nullable="False">
</column>
</property>
- tableName="OPC_TABLE_HBA" columnName="OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HBA" columnName="OPA" colCreator="True" fixedCol="False">
+<column name="OPA" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- tableName="OPC_TABLE_HBA" columnName="OPID1" colCreator="True" fixedCol="False" >
-<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HBA" columnName="OPB" colCreator="True" fixedCol="False">
+<column name="OPB" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvOpClassHBA"
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HBA" columnName="OPID1" colCreator="True" fixedCol="False">
+<column name="OPID1" description="" dataType="NUMBER" length="10" scale="0" nullable="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="OverridesA"
+<property xsi:type="Data" name="SchemaName" description="FDO base property: object class schema name" dataType="string" length="255" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue="OverridesA" tableName="F_CLASSDEFINITION" columnName="SCHEMANAME" colCreator="False" fixedCol="True">
</column>
</property>
</properties>
-<table name="OPC_TABLE_HBA" description="" pkeyName="PK_OPC_TABLE_HBA" >
+<table name="OPC_TABLE_HBA" description="" pkeyName="PK_OPC_TABLE_HBA">
</column>
</column>
</column>
</table>
<tables>
-</table>
-<table name="F_CLASSDEFINITION" description="" pkeyName="" >
-</table>
+<table name="OPC_TABLE_HBA" description="" pkeyName="PK_OPC_TABLE_HBA"/>
</tables>
</class>
-<class xsi:type="Class" name="OvOpClassHC" description="an object property class"
- tableName="OPC_TABLE_HC" tblCreator="True" fixedTbl="True" >
+<class xsi:type="Class" name="OvOpClassHC" description="an object property class" baseClass="" abstract="False" tableName="OPC_TABLE_HC" tblCreator="True" fixedTbl="True">
+<tableMapping>
+Concrete</tableMapping>
<properties>
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvOpClassHC" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
+</column>
+</property>
-<class xsi:type="Class" name="OvOpClassHC.ObjectA" description="Autogenerated Object Property Class"
- tableName="OPC_TABLE_HC" tblCreator="False" fixedTbl="False" >
+<class xsi:type="Class" name="OvOpClassHC.ObjectA" description="Autogenerated Object Property Class" baseClass="" abstract="False" tableName="OPC_TABLE_HC" tblCreator="False" fixedTbl="False">
+<tableMapping>
<properties>
- tableName="OPC_TABLE_HC" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="ClassName" description="FDO base property: object class name" dataType="string" length="30" precision="0" scale="0" readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvOpClassHC.ObjectA" tableName="F_CLASSDEFINITION" columnName="CLASSNAME" colCreator="False" fixedCol="True">
</column>
</property>
- tableName="OPC_TABLE_HC" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HC" columnName="PREFIXA_OPA" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvOpClassHC.ObjectA"
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HC" columnName="PREFIXA_OPB" colCreator="True" fixedCol="False">
</column>
</property>
</column>
</property>
</properties>
-<table name="OPC_TABLE_HC" description="" pkeyName="PK_OPC_TABLE_HC" >
-<column name="OP_COL_B" description="" dataType="VARCHAR2" length="10" scale="0" nullable="True" >
+<table name="OPC_TABLE_HC" description="" pkeyName="PK_OPC_TABLE_HC">
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
-</table>
+<table name="OPC_TABLE_HC" description="" pkeyName="PK_OPC_TABLE_HC"/>
+<table name="F_CLASSDEFINITION" description="" pkeyName=""/>
</tables>
</class>
</property>
- tableName="OPC_TABLE_HC" columnName="OPA" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HC" columnName="OPA" colCreator="True" fixedCol="False">
</column>
</property>
- tableName="OPC_TABLE_HC" columnName="OP_COL_B" colCreator="True" fixedCol="True" >
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HC" columnName="OP_COL_B" colCreator="True" fixedCol="True">
</column>
</property>
- tableName="OPC_TABLE_HC" columnName="OPID1" colCreator="True" fixedCol="False" >
+<property xsi:type="Data" name="OpId1" description="object property id property" dataType="int32" length="0" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue="" tableName="OPC_TABLE_HC" columnName="OPID1" colCreator="True" fixedCol="False">
</column>
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue="OvOpClassHC"
</column>
</property>
-</column>
-</property>
</properties>
</property>
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
-</table>
-</table>
</tables>
</class>
-<class xsi:type="Class" name="OvOpClassHCA" description="an object property class"
- tableName="OPS_TABLE_HCA" tblCreator="False" fixedTbl="True" >
-<tableMapping>Concrete</tableMapping>
+<class xsi:type="Class" name="OvOpClassHCA" description="an object property class" baseClass="" abstract="False" tableName="OPS_TABLE_HCA" tblCreator="False" fixedTbl="True">
+<tableMapping>
<properties>
- tableName="OPS_TABLE_HCA" columnName="OPA" colCreator="False" fixedCol="False" >
+</column>
</property>
- tableName="OPS_TABLE_HCA" columnName="OPB" colCreator="False" fixedCol="False" >
+<property xsi:type="Data" name="OpA" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HCA" columnName="OPA" colCreator="False" fixedCol="False">
</property>
- readOnly="True" featId="False" system="True" nullable="False" autogenerated="False" defaultValue=""
-</column>
+<property xsi:type="Data" name="OpB" description="first data property" dataType="string" length="10" precision="0" scale="0" readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue="" tableName="OPS_TABLE_HCA" columnName="OPB" colCreator="False" fixedCol="False">
</property>
- readOnly="True" featId="False" system="True" nullable="True" autogenerated="False" defaultValue=""
