[fdo-commits] r677 - in branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS: . sql
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 22 21:09:46 EST 2007
Author: mloskot
Date: 2007-01-22 21:09:46 -0500 (Mon, 22 Jan 2007)
New Revision: 677
Added:
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_associationdefinition.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedefinition.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedependencies.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classdefinition.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classtype.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_dbopen.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_feature.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_options.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_sad.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemainfo.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemaoptions.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontext.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgeom.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgroup.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys.sql
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys_idx.sql
Added 'sql' module for PostGIS with SQL templates for FDO meta schema scripts.
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_associationdefinition.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_associationdefinition.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_associationdefinition.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,19 @@
+-- f_associationdefinition
+DROP TABLE IF EXISTS f_associationdefinition;
+create table f_associationdefinition (
+     pseudocolname        varchar(64) not null,
+     pktablename          varchar(64) not null,
+     pkcolumnnames        varchar(1056),
+     fktablename          varchar(64) not null,
+     fkcolumnnames        varchar(1056),
+     multiplicity         varchar(5),
+     reversemultiplicity  varchar(5),
+     cascadelock          char(1),
+     deleterule           integer,
+     reversename          varchar(200)
+COMMENT ON TABLE f_associationdefinition IS 'TODO';
\ No newline at end of file
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedefinition.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedefinition.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedefinition.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,68 @@
+-- f_attributedefinition
+DROP TABLE IF EXISTS f_attributedefinition;
+create table f_attributedefinition (
+    tablename         varchar(64) not null,
+    classid           integer not null,
+    columnname        varchar(255) not null,
+    attributename     varchar(4000) not null,
+    idposition        smallint,
+    columntype        varchar(30) not null,
+    columnsize        bigint not null,
+    columnscale       smallint,
+    attributetype     varchar(512) not null,
+    geometrytype      varchar(64),
+    isnullable        smallint not null,
+    isfeatid          smallint not null,
+    issystem          smallint not null,
+    isreadonly        smallint not null,
+    isautogenerated   smallint,
+    isrevisionnumber  smallint,
+    sequencename      varchar(30),
+    owner             varchar(255),
+    description       varchar(255),
+    rootobjectname    varchar(64),
+    isfixedcolumn     smallint,
+    iscolumncreator   smallint,
+    haselevation      smallint,
+    hasmeasure        smallint
+COMMENT ON TABLE f_attributedefinition IS 'Definition of properties for classes from FDO feature schema.';
+-- Base properties common to all classes
+insert into f_classdefinition
+(classname, schemaname, tablename,classtype, description, isabstract, parentclassname, istablecreator, isfixedtable, hasversion, haslock)
+values
+('ClassDefinition', 'F_MetaClass', 'f_classdefinition', 1, 'Base for all metaclasses', 1, null, 0, 1, 0, 0);
+insert into f_attributedefinition
+(tablename, classid, columnname, attributename, columntype, columnsize, columnscale, attributetype, isnullable,
+isfeatid, issystem, isreadonly, isautogenerated, isrevisionnumber, owner, description, iscolumncreator, isfixedcolumn)
+values
+('f_classdefinition', currval('f_classdefinition_classid_seq'), 'classname', 'ClassName', 'CHAR', 30, 0, 'string', 0, 0, 1, 1, 0, 0,
+current_user, 'FDO base property: object class name', 0, 1);
+values
+('f_classdefinition', currval('f_classdefinition_classid_seq'), 'schemaname', 'SchemaName', 'CHAR', 255, 0, 'string', 1, 0, 1, 1, 0, 0,
+current_user, 'FDO base property: object class schema name', 0, 1);
+(tablename, classid, columnname, attributename, idposition, columntype, columnsize, columnscale, attributetype,
+isnullable, isfeatid, issystem, isreadonly, isautogenerated, isrevisionnumber, owner, description, iscolumncreator, isfixedcolumn)
+values
+('f_feature', currval('f_classdefinition_classid_seq'), 'classid', 'ClassId', 1, 'BIGINT', 0, 0, 'int64', 0, 0, 1, 1, 1, 0,
+current_user, 'Class id number (uniquely identifies a class)', 0, 1);
+(tablename, classid, columnname, attributename, columntype, columnsize, columnscale, attributetype, geometrytype, isnullable,
+values
+('n/a', currval('f_classdefinition_classid_seq'), 'n/a', 'Bounds', 'GEOMETRY', 0, 0, '4', '84224', 1, 0, 1, 1, 0, 0,
+current_user, 'Bounding box for the feature', 0, 0);
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedependencies.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedependencies.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_attributedependencies.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,24 @@
+-- f_attributedependencies
+DROP TABLE IF EXISTS f_attributedependencies;
+create table f_attributedependencies (
+    fkcardinality   integer not null,
+    identitycolumn  varchar(64),
+    ordertype       char(1)
+COMMENT ON TABLE f_attributedependencies IS 'Definition of attribute dependencies.';
+-- Add dependency for navigating from a feature to its class and schema name
+insert into f_attributedependencies
+( pktablename, pkcolumnnames, fktablename, fkcolumnnames, fkcardinality )
+values
+( 'F_FEATURE', 'CLASSID', 'F_CLASSDEFINITION', 'CLASSID', 1 );
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classdefinition.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classdefinition.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classdefinition.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,34 @@
+-- f_classdefinition  -
+DROP TABLE IF EXISTS f_classdefinition;
+create table f_classdefinition (
+    classid          serial not null,
+    classname        varchar(255) not null,
+    schemaname       varchar(255),
+    roottablename    varchar(64),
+    tableowner       varchar(64),
+    tablelinkname    varchar(128),
+    tablemapping     varchar(64),
+    classtype        smallint not null,
+    isabstract       smallint not null,
+    parentclassname  varchar(512),
+    isfixedtable     smallint,
+    istablecreator   smallint,
+    hasversion       smallint,
+    haslock          smallint,
+    geometryproperty varchar(4000),
+    CONSTRAINT f_classdefinition_pk PRIMARY KEY (classid)
+COMMENT ON TABLE f_classdefinition IS 'Definition of classes from FDO feature schema.';
+-- insert only classes that do not require any data in the F_AttributeDefinition table
+values
+('Class', 'F_MetaClass', ' ', 1, 'Non-feature metaclass', 0, 'ClassDefinition', 0, 1, 0, 0);
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classtype.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classtype.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_classtype.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,15 @@
+-- f_classtype
+DROP TABLE IF EXISTS f_classtype;
+create table f_classtype (
+    classtype      integer not null,
+    classtypename  varchar(255) not null
+COMMENT ON TABLE f_classtype IS 'Definition of types for FDO classes.';
+-- Lookups for class type enums-string pairs
+insert into f_classtype (classtype, classtypename) values (1, 'Class');
+insert into f_classtype (classtype, classtypename) values (2, 'Feature');
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_dbopen.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_dbopen.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_dbopen.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,16 @@
+-- f_dbopen -
+DROP TABLE IF EXISTS f_dbopen;
+create table f_dbopen (
+    usernum     integer not null,
+    dbuser      varchar(30) not null,
+    accessmode  varchar(1),
+    activescid  bigint,
+    opendate    timestamp,
+    sessionid   smallint,
+    process     varchar(128)
+COMMENT ON TABLE f_dbopen IS 'TODO';
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_feature.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_feature.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_feature.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,29 @@
+-- f_feature -
+DROP TABLE IF EXISTS f_feature;
+-- #ifdef FDO_FEATURE
+create table f_feature (
+    featid        bigint not null,
+    classid       numeric(20),
+-- #ifdef FDO_VERSIONS
+    ltid          numeric(20),
+    nextltid      numeric(20),
+    ltgeneration  numeric(20),
+-- #endif
+-- #ifdef FDO_LOCKS
+    rowlockid     numeric(20),
+    rowlocktype   varchar(1)
+-- #endif
+COMMENT ON TABLE f_feature IS 'Definition of FDO spatial feature types.';
+-- #ifndef FDO_VERSIONS
+-- #ifndef FDO_LOCKS
+alter table f_feature add (constraint f_feature_pk primary key (featid));
+-- #endif
+-- #endif
+-- #endif
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_options.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_options.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_options.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,12 @@
+-- f_options - store different options used by the datastore
+DROP TABLE IF EXISTS f_options;
+create table f_options (
+      name	 varchar(100),
+      value	 varchar(100)
+insert into f_options values ('LT_MODE', '1');
+insert into f_options values ('LOCKING_MODE', '1');
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_sad.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_sad.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_sad.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,14 @@
+-- f_sad - Schema Attribute Dictionary table
+DROP TABLE IF EXISTS f_sad;
+create table f_sad (
+    ownername    varchar(512) not null,
+    elementname  varchar(255) not null,
+    elementtype  varchar(30) not null,
+    name         varchar(255) not null,
+    value        varchar(4000)
+COMMENT ON TABLE f_sad IS 'Definition of schema attribute dictionary for FDO meta schema.';
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemainfo.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemainfo.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemainfo.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,24 @@
+-- f_schemainfo
+DROP TABLE IF EXISTS f_schemainfo;
+create table f_schemainfo (
+    schemaname       varchar(255) not null,
+    owner            varchar(255) not null,
+    creationdate     timestamp,
+    schemaversionid  numeric(5,3) not null,
+    tablemapping     varchar(30)
+COMMENT ON TABLE f_schemainfo IS 'Definition of information properties for FDO meta schema.';
+insert into f_schemainfo (schemaname, description, creationdate, owner, schemaversionid )
+values (current_schema(), 'System Metaschema', current_timestamp, current_user, 3.000);
+-- F_MetaClass is a special schema with a class for each FDO Feature schema class type
+values ('F_MetaClass', 'Special classes for FDO Feature metaclasses', current_timestamp, current_user, 3.000);
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemaoptions.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemaoptions.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_schemaoptions.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,14 @@
+-- f_schemaoptions - Schema Options table, based on the f_sad table design
+DROP TABLE IF EXISTS f_schemaoptions;
+create table f_schemaoptions (
+COMMENT ON TABLE f_schemaoptions IS 'Definition of options for FDO meta schema.';
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontext.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontext.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontext.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,26 @@
+-- f_spatialcontext
+DROP TABLE IF EXISTS f_spatialcontext;
+create table f_spatialcontext (
+    scid         serial not null,
+    scname       varchar(255) not null,
+    scgid        bigint null,
+    rowlockid   bigint null,
+    rowlocktype  varchar(1) null,
+-- #endif
+   CONSTRAINT f_spatialcontext_pk PRIMARY KEY (scid)
+COMMENT ON TABLE f_spatialcontext IS 'Definition of FDO spatial context.';
+-- Insert default spatial context
+insert into f_spatialcontext
+(scname, description, scgid)
+values
+('Default', 'Default Database Spatial Context', 1);
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgeom.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgeom.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgeom.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,13 @@
+-- f_spatialcontextgeom
+DROP TABLE IF EXISTS f_spatialcontextgeom;
+create table f_spatialcontextgeom (
+    geomtablename   varchar(64) not null,
+    geomcolumnname  varchar(64) not null,
+    dimensionality  smallint  not null
+COMMENT ON TABLE f_spatialcontextgeom IS 'TODO';
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgroup.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgroup.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/f_spatialcontextgroup.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,36 @@
+-- f_spatialcontextgroup
+DROP TABLE IF EXISTS f_spatialcontextgroup;
+create table f_spatialcontextgroup (
+    scgid           serial not null,
+    crsname         varchar(255),
+    crswkt          varchar(2048),
+    srid            bigint,
+    areaunit        varchar(30),
+    lengthunit      varchar(30),
+    positionxyunit  varchar(30),
+    positionzunit   varchar(30),
+    volumeunit      varchar(30),
+    measureunit     varchar(30),
+    xtolerance      double precision not null,
+    ztolerance      double precision,
+    minx            double precision not null, -- TODO: xmin is a system column name
+    miny            double precision not null,
+    minz            double precision,
+    maxx            double precision not null, -- TODO: xmax is a system column name
+    maxy            double precision not null,
+    maxz            double precision,
+    extenttype      varchar(1) not null,
+    CONSTRAINT f_spatialcontextgroup_pk PRIMARY KEY (scgid)
+COMMENT ON TABLE f_spatialcontextgroup IS 'TODO';
+insert into f_spatialcontextgroup
+(crsname, xtolerance, ztolerance, minx, miny, maxx, maxy, extenttype)
+values
+('', 0.001, 0.001, -2000000, -2000000, 2000000, 2000000, 'S');
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,299 @@
+#ifndef VISION_noschema
+#ifdef PostGIS
+(schemaname, description, creationdate, owner, schemaversionid )
+values
+(current_schema(), 'System Metaschema', current_timestamp, current_user, 3.000);
+values
+('F_MetaClass', 'Special classes for FDO Feature metaclasses', current_timestamp, current_user, 3.000);
+#ifdef FDO_FEATURE
+#ifdef FDO_VERSIONS
+    ,ltid          numeric(20),
+#endif
+#ifdef FDO_LOCKS
+    ,rowlockid     numeric(20),
+#endif
+#ifndef FDO_VERSIONS
+#ifndef FDO_LOCKS
+#endif
+#endif
+#endif
+    haslock          smallint,
+/* insert only classes that do not require any data in the F_AttributeDefinition table */
+values
+/* Base properties common to all classes */
+values
+values
+values
+values
+values
+    srid            bigint,
+values
+    ordertype       char(1)
+COMMENT ON TABLE f_attributedependencies IS 'TODO';
+#ifdef FDO_FEATURE
+/* Add dependency for navigating from a feature to its class and schema name */
+values ( 'F_FEATURE', 'CLASSID', 'F_CLASSDEFINITION', 'CLASSID', 1 );
+#endif
+#ifdef FDO_LOCKS
+#endif
+values
+#endif /* PostGIS */
+#endif /* VISION_noschema */
+/* End */
Added: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys_idx.sql
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys_idx.sql	2007-01-23 02:08:10 UTC (rev 676)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/sql/postgis_fdo_sys_idx.sql	2007-01-23 02:09:46 UTC (rev 677)
@@ -0,0 +1,229 @@
+/* Name        */
+/*  g_sys_i.sql - create indexes for standard system tables schema      */
+/* Description                                                          */
+/*      Command file to create indexes for standard schema and system   */
+/*      tables in a newly granted database.                             */
+/* Remarks                                                              */
+/*      This file is executed by a call to adb_exec_file().  Portions   */
+/*      of this script are enabled or disabled via #ifdef variables.    */
+/*      In particular defining VISION_noschema disables the creation of */
+/*      the so called schema table indexes.                             */
+create unique index f_schemainfo_idx on f_schemainfo(schemaname)
+#ifdef Oracle
+    pctfree 5
+    storage (initial     4K
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_dbopen_usrnum_idx on f_dbopen(usernum)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+#ifdef    FDO_FEATURE
+create unique index f_feature_pk_idx on f_feature(featid, ltid)
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5);
+create index f_feature_class_idx on f_feature(featid, classid)
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5);
+create index f_feature_lt_idx on f_feature(ltid, nextltid)
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5);
+create unique index f_geometry_0_pk_idx on f_geometry_0(featid, scid, seq, ltid)
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5);
+create index f_geometry_0_lt_idx on f_geometry_0(ltid, nextltid)
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5);
+#endif
+#endif
+create unique index f_classdef_pk_idx on f_classdefinition(classid)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_classdef_schnm_idx on f_classdefinition(classname, schemaname)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_attributedef_pk_idx on f_attributedefinition(tablename, classid, columnname)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_attributedep_pk_idx on f_attributedependencies(pktablename, fktablename)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_association_pk_idx on f_associationdefinition(pseudocolname, pktablename, fktablename)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_sad_pk_idx on f_sad(ownername, elementname, elementtype, name)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_schemaoptions_pk_idx on f_schemaoptions(ownername, elementname, elementtype, name)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+/* F_SEQUNCE table primary key */
+#ifdef Oracle
+create unique index f_sequence_seq_id on f_sequence(seqid)
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5);
+#endif
+/*  Create the G_PLAN table indexes.                                */
+/* Primary Key */
+create unique index f_spatialcontext_scid_pk_idx on f_spatialcontext(scid)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+create unique index f_spatialcontext_name_pk_idx on f_spatialcontext(scname)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+/*  Create the G_PLAN_GROUPS index              */
+create unique index f_spatialcontextgroup_pk_idx on f_spatialcontextgroup(scgid)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+/*#endif VISION_sdo */
+/* create the f_spatialcontextgeom index */
+create unique index f_spatialcontextgeom_pk_idx on f_spatialcontextgeom(scid, geomtablename, geomcolumnname)
+#ifdef Oracle
+    pctfree 5
+             next        4K
+             minextents  1
+             maxextents  9999
+             pctincrease 5)
+#endif
+#endif
+/* End */
More information about the fdo-commits mailing list
