[fdo-commits] r676 -
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver
svn_fdo at osgeo.org
Mon Jan 22 21:08:10 EST 2007
Author: mloskot
Date: 2007-01-22 21:08:10 -0500 (Mon, 22 Jan 2007)
New Revision: 676
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/Geometry.h
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/PostGISDriver.vcproj
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/bind.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/conn_status.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/connect.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/desc_slct.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/execute.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/fetch.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/get_msg.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.h
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.h
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/rdbi_init.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/run_sql.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.h
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/sql.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/stdafx.h
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.c
branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.h
New features, fixes and types support in RDBI driver for PostGIS. TODO: not all RDBI type mappings are covered.
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/Geometry.h
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/Geometry.h 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/Geometry.h 2007-01-23 02:08:10 UTC (rev 676)
@@ -23,9 +23,8 @@
#pragma once
#endif // _WIN32
+extern void* GeometryFromWkb (void *wkb, unsigned long size);
+extern char* WkbFromGeometry (void *geometry, int* size);
+extern void FreeGeometry (void *geometry);
-extern void *GeometryFromWkb (void *wkb, unsigned long size);
-extern void FreeGeometry (void *geometry);
-extern char *WkbFromGeometry (void *geometry, int* size);
#endif /* POSTGIS_GEOMETRY_H */
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/PostGISDriver.vcproj
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/PostGISDriver.vcproj 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/PostGISDriver.vcproj 2007-01-23 02:08:10 UTC (rev 676)
@@ -1,7 +1,7 @@
<?xml version="1.0" encoding="Windows-1252"?>
<VisualStudioProject
ProjectType="Visual C++"
- Version="8.00"
+ Version="8,00"
Name="PostGISDriver"
ProjectGUID="{69D1E6E5-9391-40FE-A989-B9BEBE3EE305}"
RootNamespace="PostGISDriver"
@@ -476,6 +476,18 @@
</FileConfiguration>
</File>
<File
+ RelativePath=".\get_gen_id.c"
+ <FileConfiguration
+ Name="Debug|Win32"
+ <Tool
+ Name="VCCLCompilerTool"
+ CompileAs="2"
+ </FileConfiguration>
+ </File>
+ <File
RelativePath=".\get_msg.c"
<FileConfiguration
@@ -584,6 +596,18 @@
</File>
<File
+ RelativePath=".\set_err_msg.c"
+ <Tool
+ CompileAs="2"
+ </File>
+ <File
RelativePath=".\set_schema.c"
<FileConfiguration
@@ -706,6 +730,10 @@
</File>
<File
+ RelativePath=".\digits.h"
+ </File>
+ <File
RelativePath=".\disconnect.h"
</File>
@@ -730,6 +758,10 @@
</File>
<File
+ RelativePath=".\get_gen_id.h"
+ </File>
+ <File
RelativePath=".\get_msg.h"
</File>
@@ -770,6 +802,10 @@
</File>
<File
+ RelativePath=".\set_err_msg.h"
+ </File>
+ <File
RelativePath=".\set_schema.h"
</File>
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/bind.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/bind.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/bind.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -1,48 +1,48 @@
- * Copyright (C) 2006 Refractions Research, Inc.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of version 2.1 of the GNU Lesser
- * General Public License as published by the Free Software Foundation.
- * This library is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- * Lesser General Public License for more details.
- * You should have received a copy of the GNU Lesser General Public
- * License along with this library; if not, write to the Free Software
- * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include "stdafx.h"
-#include "bind.h"
-#include "local.h"
-#include "type.h"
-#include "pgconn_status.h"
-#include "pgresult_status.h"
-#include <limits.h> /* LONG_MIN, LONG_MAX */
-#include <stdlib.h> /* malloc(), free() */
-#include <string.h> /* memset() */
-int postgis_bind (
- postgis_context_def *context,
- char *cursor,
- char *name,
- int datatype,
- int size,
- char *address,
- char *null_ind)
- PGconn* postgis = NULL;
- postgis_cursor_def* curs = NULL;
- PGSQL_BIND *binds = NULL;
- Oid typeoid = 0;
- int index = 0;
- int ret = RDBI_GENERIC_ERROR;
+ * Copyright (C) 2006 Refractions Research, Inc.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of version 2.1 of the GNU Lesser
+ * General Public License as published by the Free Software Foundation.
+ * This library is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ * Lesser General Public License for more details.
+ * You should have received a copy of the GNU Lesser General Public
+ * License along with this library; if not, write to the Free Software
+ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "stdafx.h"
+#include "bind.h"
+#include "local.h"
+#include "type.h"
+#include "pgconn_status.h"
+#include "pgresult_status.h"
+#include <limits.h> /* LONG_MIN, LONG_MAX */
+#include <stdlib.h> /* malloc(), free() */
+#include <string.h> /* memset() */
+int postgis_bind (
+ postgis_context_def *context,
+ char *cursor,
+ char *name,
+ int datatype,
+ int size,
+ char *address,
+ char *null_ind)
+ PGconn* postgis = NULL;
+ postgis_cursor_def* curs = NULL;
+ PGSQL_BIND *binds = NULL;
+ Oid typeoid = 0;
+ int index = 0;
+ int ret = RDBI_GENERIC_ERROR;
if (-1 == context->postgis_current_connect)
ret = RDBI_NOT_CONNECTED;
else
@@ -50,71 +50,76 @@
postgis = context->postgis_connections[context->postgis_current_connect];
if (RDBI_SUCCESS != postgis_pgconn_status(postgis))
- else
+ else
curs = (postgis_cursor_def*)cursor;
if (NULL == curs)
- else
- /* TODO: need an error for bind names not supported */
- /* Numeric position */
- index = strtol(name, NULL, 10);
- if (0 >= index || LONG_MIN == index || LONG_MAX == index)
- ret = RDBI_GENERIC_ERROR; /* need an error for unknown name */
- else
- index--; /* Make parameter index zero -based */
- typeoid = rdbi_to_postgis_type(postgis, datatype, size, 0);
- if (0 >= typeoid)
- ret = RDBI_INVLD_DESCR_OBJTYPE;
- else
- if (index >= curs->bind_count)
- binds = (PGSQL_BIND *)malloc((index + 1) * sizeof(PGSQL_BIND));
- if ((PGSQL_BIND*)NULL == binds)
- if ((PGSQL_BIND*)NULL != curs->binds)
- free (curs->binds);
- curs->bind_count = 0;
- else
- memset (binds, 0, (index + 1) * sizeof(PGSQL_BIND));
- memcpy (binds, curs->binds, curs->bind_count * sizeof(PGSQL_BIND));
- curs->bind_count = index + 1;
- curs->binds = binds;
- ret = RDBI_MALLOC_FAILED;
- else
- curs->binds[index].buffer_type = typeoid;
- curs->binds[index].buffer_length = size;
- curs->binds[index].buffer = address;
- if ((char*)NULL != null_ind)
- curs->binds[index].is_null = null_ind;
- ret = RDBI_SUCCESS;
- return (ret);
+ else
+ /* TODO: need an error for bind names not supported */
+ /* Numeric position */
+ index = strtol(name, NULL, 10);
+ if (0 >= index || LONG_MIN == index || LONG_MAX == index)
+ ret = RDBI_GENERIC_ERROR; /* need an error for unknown name */
+ else
+ index--; /* Make parameter index zero -based */
+ typeoid = rdbi_to_postgis_type(postgis, datatype, size, 0);
+ if (0 >= typeoid)
+ ret = RDBI_INVLD_DESCR_OBJTYPE;
+ else
+ if (index >= curs->bind_count)
+ binds = (PGSQL_BIND *)malloc((index + 1) * sizeof(PGSQL_BIND));
+ if ((PGSQL_BIND*)NULL == binds)
+ if ((PGSQL_BIND*)NULL != curs->binds)
+ free (curs->binds);
+ curs->bind_count = 0;
+ else
+ memset (binds, 0, (index + 1) * sizeof(PGSQL_BIND));
+ memcpy (binds, curs->binds, curs->bind_count * sizeof(PGSQL_BIND));
+ curs->bind_count = index + 1;
+ curs->binds = binds;
+ ret = RDBI_MALLOC_FAILED;
+ else
+ * typeoid - native PostgreSQL type is detected.
+ * size - value passed from GDBI layer.
+ * address - comes from GDBI too
+ curs->binds[index].buffer_type = typeoid;
+ curs->binds[index].buffer_length = size;
+ curs->binds[index].buffer = address;
+ if ((char*)NULL != null_ind)
+ curs->binds[index].is_null = null_ind;
+ ret = RDBI_SUCCESS;
+ return (ret);
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/conn_status.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/conn_status.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/conn_status.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -29,36 +29,36 @@
int index = -1;
- assert(NULL != context);
if (NULL != context)
- if (-1 == context->postgis_current_connect)
+ * TODO: mloskot - Is secondary connection mandatory?
+ if (-1 == context->postgis_current_connect
+ || -1 == context->postgis_current_connect2)
else
+ * Check primary connection.
index = context->postgis_current_connect;
conn = context->postgis_connections[index];
+ ret = postgis_pgconn_status(conn);
+ if (RDBI_SUCCESS == ret)
+ * Check secondary connection.
+ index = context->postgis_current_connect2;
+ conn = context->postgis_connections[index];
- if (NULL != conn)
- // Returns RDBI status code
- else
- // TODO - mloskot: If context indicates the connection
- // is active, but connection handle is NULL, it means
- // undefined error, like libpq allocation failure.
- // TODO - mloskot: Remove assertion before merging with 'trunk'
- assert(false);
- return RDBI_GENERIC_ERROR;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/connect.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/connect.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/connect.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -19,6 +19,8 @@
#include "stdafx.h"
#include "connect.h"
+#include "set_err_msg.h"
#include "Inc/ut.h"
#include <malloc.h> /* alloca() */
#include <stdio.h>
@@ -31,34 +33,37 @@
char** vendor_data,
int* connect_id)
- /* Used in strings manipulation. */
- char *p = NULL;
- size_t length = 0;
+ PGconn* conn = NULL; /* Database connection handler. */
- /* Splited values of connection string. */
+ /* Properties retrieved from connection string. */
char* dbname = NULL;
char* pghost = NULL;
char* pgport = DEF_PGPORT_STR; /* default port, defined in stdafx.h */
+ /* Properties passed explicitly. */
const char* pglogin = user;
const char* pgpwd = pswd;
- const char* pgoptions = NULL; /* not used */
- const char* pgtty = NULL; /* not used */
+ /* Properties not used in current version. */
+ const char* pgoptions = NULL;
+ const char* pgtty = NULL;
- /* Database connection handler. */
- PGconn* conn = NULL;
+ /* Used in strings manipulation. */
+ char* pch = NULL;
+ size_t length = 0;
+ int conn_index = 0;
+ int max_connects = 0;
int ret = RDBI_SUCCESS;
- int max_connects = 0;
- int index = 0;
- int rows_processed = 0;
- * Split RDBI connection string to separate values.
- * Input format: database at host:port
- * where default host is localhost and default port is DEF_PGPORT=5432.
+ * Retrieve connection properties from the RDBI connection string.
+ * Connection string format is:
+ * - short: database
+ * where default host is localhost and default port is 5432.
+ * - long: database at host:port
pghost = "localhost";
@@ -67,82 +72,83 @@
* Database name.
- p = strchr(connect_string, '@');
- if (NULL != p)
+ pch = strchr(connect_string, '@');
+ if (NULL != pch)
- length = p - connect_string;
+ length = pch - connect_string;
dbname = (char*)alloca(length + 1);
strncpy(dbname, connect_string, length);
dbname[length] = '\0';
- p++;
- connect_string = p;
+ pch++;
+ connect_string = pch;
- * Host name and port.
- p = strchr(connect_string, ':');
- if (NULL != p)
- pghost = (char*)alloca(length + 1);
- strncpy(pghost, connect_string, length);
- pghost[length] = '\0';
- p++;
+ * Hostname and port.
+ pch = strchr(connect_string, ':');
+ if (NULL != pch)
+ pghost = (char*)alloca(length + 1);
+ strncpy(pghost, connect_string, length);
+ pghost[length] = '\0';
+ pch++;
- pgport = p;
+ pgport = pch;
+ else
+ pghost = connect_string;
else
- pghost = connect_string;
+ dbname = connect_string;
- * No database name provided, use 'template_postgis' as default target.
- * with assumptions user wants to create new datastore and reconnect to it.
+ * Find an open slot and try to connect.
+ max_connects = ELEMENTS(context->postgis_connections);
+ * PostgreSQL database name is required.
if (NULL == dbname)
- length = strlen(POSTGIS_TEMPLATE_DBNAME);
- dbname = (char*)alloca(length + 1);
- strncpy(dbname, POSTGIS_TEMPLATE_DBNAME, length + 1);
- dbname[length] = '\0';
+ ret = RDBI_NOT_CONNECTED;
- * TODO: Replace assertions with test-and-error-return.
- assert(NULL != pghost);
- assert(NULL != pgport);
- assert(NULL != dbname);
- * Find an open slot and try to connect.
- max_connects = ELEMENTS(context->postgis_connections);
- if (max_connects <= context->postgis_connect_count)
+ else if (max_connects <= context->postgis_connect_count)
ret = RDBI_TOO_MANY_CONNECTS;
else
- for (index = 0; (index < max_connects) && (RDBI_SUCCESS == ret); index++)
+ assert(NULL != pghost);
+ assert(NULL != pgport);
+ assert(NULL != dbname);
+ for (conn_index = 0;
+ ((conn_index < max_connects) && (RDBI_SUCCESS == ret));
+ conn_index++)
- if (NULL == context->postgis_connections[index])
+ if (NULL == context->postgis_connections[conn_index])
- /* Initialize a connection */
- /* PQsetdbLogin always returns non-NULL pointer. */
+ * Establish connection with PostgreSQL database.
conn = PQsetdbLogin(pghost, pgport, pgoptions, pgtty, dbname, pglogin, pgpwd);
- if (CONNECTION_BAD == PQstatus(conn))
+ if (RDBI_SUCCESS != ret)
- /* Retrieve connection error. */
- char* p = PQerrorMessage(conn);
- memset(context->postgis_last_err_msg, '\0', RDBI_MSG_SIZE);
- strncpy(context->postgis_last_err_msg, p, RDBI_MSG_SIZE);
- context->postgis_last_err_msg[RDBI_MSG_SIZE - 1] = '\0';
+ /* Retrieve connection error and
+ * set as last error message for context.
+ pch = PQerrorMessage(conn);
+ postgis_set_err_msg(context, pch);
PQfinish(conn);
conn = NULL;
@@ -152,19 +158,19 @@
context->postgis_connect_count++;
- context->postgis_current_connect = index;
- context->postgis_connections[index] = conn;
+ context->postgis_current_connect = conn_index;
+ context->postgis_connections[conn_index] = conn;
- /* Return id of established connection. */
- *connect_id = index;
+ /* Index is used as a connection ID. */
+ *connect_id = conn_index;
ret = RDBI_SUCCESS;
else if (-1 == context->postgis_current_connect2)
- context->postgis_current_connect2 = index;
+ context->postgis_current_connect2 = conn_index;
ret = RDBI_SUCCESS;
break;
@@ -174,5 +180,5 @@
} // for
- return (ret);
+ return ret;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/desc_slct.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/desc_slct.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/desc_slct.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -36,6 +36,7 @@
#define case_insensitive_compare strcasecmp
#endif
int postgis_desc_slct (
char *cursor,
@@ -114,23 +115,34 @@
switch (type)
- case RDBI_CHAR: /* Fixed-length strings. */
+ case RDBI_CHAR: /* Fixed-length strings. */
case RDBI_FIXED_CHAR:
- fsize = postgis_get_char_length(pgres, position);
+ if (-1 == fsize)
+ /* Fetch size from typemod. */
+ fsize = postgis_get_char_length(pgres, position);
assert(PGSQL_VAR_NOINFO != fsize);
if (1 == fsize) /* CHAR(1) */
*binary_size = fsize + 1;
- else /* CHAR(N) */
+ else /* CHAR(N) */
*binary_size = fsize;
break;
- case RDBI_STRING: /* Variable-length strings. */
- fsize = postgis_get_varchar_length(pgres, position);
- if (fsize > 0) /* VARCHAR(N) */
+ case RDBI_STRING: /* Variable-length strings. */
+ if (-1 == fsize)
+ fsize = postgis_get_varchar_length(pgres, position);
+ if (fsize > 0) /* VARCHAR(N) */
- else /* TEXT */
- *binary_size = 65536; /* Arbitrary value of 64 KB */
+ else /* TEXT */
+ *binary_size = PGSQL_VARCHAR_MAX_SIZE;
break;
case RDBI_FLOAT:
*binary_size = sizeof(float);
break;
@@ -156,7 +168,18 @@
*binary_size = sizeof(int64_t);
#endif
break;
+ case RDBI_BOOLEAN:
+ *binary_size = PGSQL_BOOLEAN_RDBI_SIZE;
+ break;
+ case RDBI_DATE:
+ * TODO: mloskot - check size of DATE type
+ break;
+ case RDBI_ROWID:
+ assert(!"postgis_desc_slct: ROWID type is unsupported");
+ break;
default:
* TODO: mloskot - Unknown size?
@@ -164,7 +187,6 @@
assert(!"postgis_desc_slct: Unknown field size");
*binary_size = 0;
- break;
@@ -173,7 +195,6 @@
*null_ok = 1; /* 1 is a temporary value. */
ret = RDBI_SUCCESS;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/execute.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/execute.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/execute.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -18,15 +18,18 @@
#include "stdafx.h"
+#include "digits.h"
+#include "errno.h"
#include "execute.h"
-#include "Geometry.h"
-#include "errno.h"
#include "pgresult_clear.h"
#include "pgresult_error.h"
+#include "Geometry.h"
#include <string.h> /* memset(), strcpy() */
// TODO: mloskot - To be removed for release.
@@ -70,16 +73,14 @@
assert (NULL != curs->stmt_name);
+ params_count = 0; /* Important, if binds is NULL. */
* Prepare input parameters for statement.
- params_count = 0; /* Important, if binds is NULL. */
if (NULL != curs->binds)
params_count = curs->bind_count;
param_values = (char**)malloc(sizeof(char*) * params_count);
if (NULL == param_values)
@@ -91,7 +92,7 @@
switch (curs->binds[i].buffer_type)
- case PGSQL_TYPE_CHAR:
+ case PGSQL_TYPE_CHAR: /* TODO: mloskot - check if not move to separate case */
case PGSQL_TYPE_BPCHAR:
case PGSQL_TYPE_VARCHAR:
case PGSQL_TYPE_TEXT:
@@ -101,29 +102,72 @@
memset(buf, 0, buf_size);
strncpy(buf, (const char*)curs->binds[i].buffer, buf_size);
- param_values[i] = buf;
break;
+ case PGSQL_TYPE_INT2:
+ buf_size = NUMBER_OF_DIGITS10(short);
+ buf = (char*)malloc(buf_size);
+ memset(buf, 0, buf_size);
+ snprintf(buf, buf_size, "%d", (int)(*((short*)curs->binds[i].buffer)));
+ break;
+ case PGSQL_TYPE_INT4:
+ buf_size = NUMBER_OF_DIGITS10(int);
+ snprintf(buf, buf_size, "%d", (*((int*)curs->binds[i].buffer)));
+ break;
+ case PGSQL_TYPE_INT8:
+ buf_size = NUMBER_OF_DIGITS10(rdbi_int64_t);
+ snprintf(buf, buf_size, "%I64d", (*((rdbi_int64_t*)curs->binds[i].buffer)));
+ break;
+ case PGSQL_TYPE_FLOAT:
+ buf_size = NUMBER_OF_FLOAT_DIGITS;
+ snprintf(buf, buf_size, "%.20g", (*((float*)curs->binds[i].buffer)));
+ break;
+ case PGSQL_TYPE_DOUBLE:
+ buf_size = NUMBER_OF_DOUBLE_DIGITS;
+ snprintf(buf, buf_size, "%.20g", (*((double*)curs->binds[i].buffer)));
+ break;
+ default:
+ assert(!"execute: UNKNOWN TYPE");
+ /* Assign value to input parameter. */
+ param_values[i] = buf;
+ buf = NULL;
+ buf_size = 0;
- assert(RDBI_MALLOC_FAILED != ret); // TODO: mloskot - replace with cleanup & error return
* Execute prepared statement.
- curs->stmt_result = PQexecPrepared(postgis, curs->stmt_name,
- params_count,
- param_values,
+ curs->stmt_result = PQexecPrepared(postgis, curs->stmt_name,
+ params_count, param_values,
NULL, NULL, 0);
ret = postgis_pgresult_status(curs->stmt_result);
- postgis_pgresult_error(curs->stmt_result, NULL);
+ postgis_pgresult_error(context, curs->stmt_result);
postgis_pgresult_clear(curs->stmt_result);
curs->stmt_result = NULL;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/fetch.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/fetch.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/fetch.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -20,20 +20,27 @@
#include "fetch.h"
#include "local.h"
+#include "conn_status.h"
-int postgis_fetch (
- char *cursor,
- int count,
- int do_exec,
- int do_cancel,
- int *rows_processed)
+#include <stdlib.h> /* strtol() */
+#include <string.h> /* memcpy(), strncpy() */
+#include <assert.h>
+int postgis_fetch (postgis_context_def *context,
+ char *cursor,
+ int count,
+ int do_exec,
+ int do_cancel,
+ int *rows_processed)
- postgis_cursor_def *curs;
+ postgis_cursor_def *curs = NULL;
+ char* buffer = NULL;
+ char* fvalue = NULL;
+ size_t fvalue_length = 0;
int nrows = 0;
int nfields = 0;
@@ -42,51 +49,145 @@
if (NULL != rows_processed)
*rows_processed = 0;
- ret = RDBI_NOT_CONNECTED;
- else
+ ret = postgis_conn_status(context);
- if (RDBI_SUCCESS != postgis_pgconn_status(postgis))
+ assert(NULL != postgis);
+ curs = (postgis_cursor_def*)cursor;
+ if (NULL == curs)
else
- curs = (postgis_cursor_def*)cursor;
- if (NULL == curs)
- else
+ * Fetch next row from query results into buffers in defines.
+ if (NULL != curs->stmt_name
+ && NULL != curs->defines
+ && PGRES_TUPLES_OK == PQresultStatus(curs->stmt_result))
- //ret = RDBI_END_OF_FETCH; // TODO: mloskot - Is there any better code to use here?
+ /* Move cursor to next row. */
+ curs->current_row++;
- if (NULL != curs->stmt_name && PGRES_TUPLES_OK == PQresultStatus(curs->stmt_result))
+ nrows = PQntuples(curs->stmt_result);
+ if (curs->current_row >= nrows)
- /* Move cursor to next row. */
- curs->current_row++;
+ /* End of query result. */
+ curs->current_row = -1;
+ ret = RDBI_END_OF_FETCH;
+ else
+ /* Fetch data into buffers in defines. */
+ const int nfields = PQnfields(curs->stmt_result);
- nrows = PQntuples(curs->stmt_result);
- if (curs->current_row >= nrows)
+ /* Pre-condition assures the state of RDBI machinery. */
+ assert(nfields == curs->define_count);
+ for (int i = 0; i < nfields; ++i)
- /* End of query result. */
- ret = RDBI_END_OF_FETCH;
- else
- /* Fetch data into buffers in defines. */
- nfields = PQnfields(curs->stmt_result);
- for (int i = 0; i < nfields; ++i)
+ /* Read field value */
+ fvalue = PQgetvalue(curs->stmt_result, curs->current_row, i);
+ assert(NULL != curs->defines[i].buffer);
+ /* Convert value type and safe to define buffer. */
+ switch(curs->defines[i].buffer_type)
- printf("F %d: %s\n", i, PQgetvalue(curs->stmt_result, curs->current_row, i));
+ case PGSQL_TYPE_BPCHAR:
+ case PGSQL_TYPE_VARCHAR:
+ case PGSQL_TYPE_TEXT:
+ case PGSQL_TYPE_NAME:
+ assert((strlen(fvalue) + 1) <= curs->defines[i].buffer_length);
+ fvalue_length = strlen(fvalue);
+ buffer = (char*)curs->defines[i].buffer;
+ strncpy(buffer, fvalue, fvalue_length);
+ buffer[fvalue_length] = '\0';
+ break;
+ assert(sizeof(short) == curs->defines[i].buffer_length);
+ short val = (short)strtol(fvalue, NULL, 10);
+ memcpy(curs->defines[i].buffer, &val, sizeof(short));
+ break;
+ assert(sizeof(int) == curs->defines[i].buffer_length);
+ int val = (int)strtol(fvalue, NULL, 10);
+ memcpy(curs->defines[i].buffer, &val, sizeof(int));
+ break;
+ assert(sizeof(rdbi_int64_t) == curs->defines[i].buffer_length);
+ rdbi_int64_t val = (rdbi_int64_t)strtol(fvalue, NULL, 10);
+ size_t type_size = sizeof(rdbi_int64_t);
+ memcpy(curs->defines[i].buffer, &val, type_size);
+ break;
+ assert(sizeof(float) == curs->defines[i].buffer_length);
+ float val = (float)strtod(fvalue, NULL);
+ memcpy(curs->defines[i].buffer, &val, sizeof(float));
+ break;
+ assert(sizeof(double) == curs->defines[i].buffer_length);
+ double val = (double)strtod(fvalue, NULL);
+ memcpy(curs->defines[i].buffer, &val, sizeof(double));
+ break;
+ case PGSQL_TYPE_DECIMAL:
+ break;
+ default:
+ assert(!"fetch: NOT IMPLEMENTED TYPE");
- if (NULL != rows_processed)
- *rows_processed = 1;
+ buffer = NULL;
+ fvalue_length = 0;
+ if (NULL != rows_processed)
+ *rows_processed = 1;
+ else if (NULL != curs->stmt_name
+ && PGRES_COMMAND_OK == PQresultStatus(curs->stmt_result))
+ // TODO: mloskot - Test empty result set
+ else
+ // TODO: mloskot - Find better error code.
+ assert(false);
- return (ret);
+ return ret;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/get_msg.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/get_msg.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/get_msg.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -29,19 +29,20 @@
const char* msg = NULL;
+ assert(NULL != buffer);
memset(buffer, '\0', RDBI_MSG_SIZE);
strncpy (buffer, context->postgis_last_err_msg, RDBI_MSG_SIZE);
buffer[RDBI_MSG_SIZE - 1] = '\0';
else if (0 != context->postgis_last_err_msg[0])
else
@@ -58,7 +59,7 @@
ret = RDBI_SUCCESS;
- return (ret);
+ return ret;
int postgis_get_msgW (postgis_context_def *context, wchar_t *buffer)
@@ -67,21 +68,24 @@
* TODO: mloskot - last_err_msg store Unicode
+ assert(!"postgis_get_msgW() - Not Implemented");
//wcscpy (buffer, context->postgis_last_err_msg);
else if ( 0 != context->postgis_last_err_msg[0] )
else
@@ -96,5 +100,5 @@
ret = RDBI_SUCCESS;
- return (ret);
+ return ret;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -29,11 +29,9 @@
if (NULL != conn)
- // Connection status tests
if (CONNECTION_OK != PQstatus(conn))
- // Try error recovery if a working connection is lost.
+ /* Try error recovery if a working connection is lost. */
ret = RDBI_SUCCESS;
PQreset(conn);
@@ -47,23 +45,6 @@
ret = RDBI_SUCCESS;
- else
- // TODO - mloskot: This assumption is not 100% correct.
- // If libpq connection function return NULL, that means
- // internal libpq error occured, so it's good to return
- // real error code here.
- // So, I decided to use assert for debug testing.
- assert(false);
- assert(RDBI_SUCCESS == ret
- || RDBI_NOT_CONNECTED == ret
- || RDBI_GENERIC_ERROR == ret);
return ret;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.h
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.h 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgconn_status.h 2007-01-23 02:08:10 UTC (rev 676)
@@ -31,6 +31,6 @@
* @return Returns RDBI_SUCCESS if context connection is established,
* RDBI_NOT_CONNECTED otherwise or RDBI_GENERIC_ERROR if error occured.
-int postgis_pgconn_status (PGconn* context);
+int postgis_pgconn_status (PGconn* conn);
#endif /* POSTGIS_PGCONN_STATUS_H */
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -17,25 +17,34 @@
#include "stdafx.h"
-void postgis_pgresult_error (const PGresult* result, const char *msg)
+void postgis_pgresult_error (
+ const PGresult* pgresult
ExecStatusType status;
- if (NULL != result)
+ if (NULL != context)
- status = PQresultStatus(result);
- if (PGRES_COMMAND_OK != status)
+ /* Reset last error message. */
+ memset(context->postgis_last_err_msg, 0, RDBI_MSG_SIZE);
+ if (NULL != pgresult)
- printf("\n[%s] %s\n",
- PQresStatus(status),
- PQresultErrorMessage(result));
+ status = PQresultStatus(pgresult);
+ if ((PGRES_EMPTY_QUERY != status)
+ && (PGRES_COMMAND_OK != status)
+ && (PGRES_TUPLES_OK != status))
+ sprintf(context->postgis_last_err_msg,
+ "[%s] %s",
+ PQresStatus(status),
+ PQresultErrorMessage(pgresult));
- else if (NULL != msg)
- fprintf(stderr, " [PostgreSQL] %s\n", msg);
\ No newline at end of file
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.h
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.h 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/pgresult_error.h 2007-01-23 02:08:10 UTC (rev 676)
@@ -18,13 +18,17 @@
#ifndef POSTGIS_PGRESULT_ERROR_H
#define POSTGIS_PGRESULT_ERROR_H
-#ifdef _WIN32
-#pragma once
-#endif // _WIN32
+#include "local.h"
- * Prints error message for PGresult status.
+ * Sets PGresult status error message to as current context last error.
+ * @param context [out] - pointer to current PostGIS session context.
+ * The function updates passed context by setting last error message.
+ * @param pgresult [in] - pointer to last PostgreSQL command result.
-void postgis_pgresult_error (const PGresult* result, const char *msg);
#endif /* POSTGIS_PGRESULT_ERROR_H */
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/rdbi_init.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/rdbi_init.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/rdbi_init.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -18,6 +18,7 @@
#include "stdafx.h"
+#include "rdbi_init.h"
#include "bind.h"
#include "commit.h"
@@ -29,18 +30,15 @@
#include "fetch.h"
#include "fre_cursor.h"
#include "get_gen_id.h"
#include "get_msg.h"
#include "null.h"
-#include "rdbi_init.h"
#include "run_sql.h"
#include "set_schema.h"
#include "sql.h"
#include "term.h"
+#include "vndr_info.h"
#include "vndr_name.h"
-#include "vndr_info.h"
#include <string.h> // memset()
#include <assert.h>
@@ -81,7 +79,7 @@
methods->bind = (int (*)(void*, char*, char*, int, int, char*, void*))postgis_bind;
methods->fetch = (int (*)(void*, char*, int, int, int, int*))postgis_fetch;
methods->get_msg = (void (*)(void*, char*))postgis_get_msg;
- methods->get_msgW = NULL; // (void (*)(void*, wchar_t*))mysql_get_msgW;
+ methods->get_msgW = (void (*)(void*, wchar_t*))postgis_get_msgW;
methods->alcnullind = (int (*)(void*, int, char**))postgis_alloc_null_ind;
methods->set_null = (void (*)(void*, void*, int, int))postgis_set_null;
methods->set_nnull = (void (*)(void*, void*, int, int))postgis_set_not_null;
@@ -97,15 +95,15 @@
methods->objects_act = NULL;
methods->objects_get = NULL;
methods->objects_deac = NULL;
- methods->users_act = NULL;
- methods->users_get = NULL;
- methods->users_deac = NULL;
- methods->usr_exists = NULL;
- methods->get_con_var = NULL;
- methods->do_break = NULL;
- methods->set_schema = (int (*)(void*, const char*))postgis_set_schema;
- methods->set_schemaW = NULL;
- methods->vndr_info = (int (*)(void*, rdbi_vndr_info_def*))postgis_vndr_info;
+ methods->users_act = NULL;
+ methods->users_get = NULL;
+ methods->users_deac = NULL;
+ methods->usr_exists = NULL;
+ methods->get_con_var = NULL;
+ methods->do_break = NULL;
+ methods->set_schema = (int (*)(void*, const char*))postgis_set_schema;
+ methods->set_schemaW = NULL;
+ methods->vndr_info = (int (*)(void*, rdbi_vndr_info_def*))postgis_vndr_info;
methods->geom_srid_set = NULL;
methods->geom_dimens_set = NULL;
methods->get_geoms_ext = NULL;
@@ -125,12 +123,16 @@
methods->capabilities.supports_autoincrement = 1;
methods->capabilities.supports_unicode = 0;
methods->capabilities.supports_int64_binding = 1;
- methods->get_gen_id = NULL; //(int (*)(void*, char*, int*))postgis_get_gen_id;
+ methods->get_gen_id = (int (*)(void*, const char*, const char*, int*))postgis_get_gen_id;
*contextp = context;
ret = RDBI_SUCCESS;
+ * TODO: mloskot - Remove before release
return (ret);
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/run_sql.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/run_sql.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/run_sql.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -1,103 +1,101 @@
-#include "run_sql.h"
-#include "pgresult_clear.h"
-#include <stdlib.h> /* strtol */
-#include <assert.h>
-#include <errno.h>
-int postgis_run_sql(
- char* sql,
- int isddl,
- int* rows_processed
- PGresult* pgresult = NULL;
- char* buf = NULL;
- long rows = 0;
- assert(NULL != sql);
- else
- if (isddl > 0)
- postgis = context->postgis_connections[context->postgis_current_connect2];
- else
- postgis = context->postgis_connections[context->postgis_current_connect];
- ret = postgis_pgconn_status(postgis);
- if (RDBI_SUCCESS == ret)
- // SQL statement execution
- pgresult = PQexec(postgis, sql);
- ret = postgis_pgresult_status(pgresult);
- rows = 0;
- if (PGRES_TUPLES_OK == PQresultStatus(pgresult))
- buf = PQcmdTuples(pgresult);
- rows = strtol(buf, NULL, 10);
- assert(ERANGE != errno && EINVAL != errno);
- (*rows_processed) = (int)rows;
- else
- /* Retrieve error message associated with last command. */
- char* p = PQresultErrorMessage(pgresult);
- * TODO: mloskot - Find better error code or map PgSQL error codes to RDBI.
- ret = RDBI_RESOURCE_LOCK;
- /* Clear PostgreSQL resources. */
- postgis_pgresult_clear(pgresult);
- return (ret);
+#include "run_sql.h"
+#include "pgresult_clear.h"
+#include <stdlib.h> /* strtol */
+#include <errno.h> /* ERANGE, EINVAL */
+int postgis_run_sql(
+ char* sql,
+ int isddl,
+ int* rows_processed
+ PGresult* pgresult = NULL;
+ char* buf = NULL;
+ long conn_index = 0;
+ long rows = 0;
+ assert(NULL != context);
+ assert(NULL != sql);
+ if (isddl > 0)
+ conn_index = context->postgis_current_connect2;
+ else
+ conn_index = context->postgis_current_connect;
+ postgis = context->postgis_connections[conn_index];
+ ret = postgis_pgconn_status(postgis);
+ /* SQL statement execution */
+ pgresult = PQexec(postgis, sql);
+ ret = postgis_pgresult_status(pgresult);
+ rows = 0;
+ if (PGRES_TUPLES_OK == PQresultStatus(pgresult))
+ buf = PQcmdTuples(pgresult);
+ rows = strtol(buf, NULL, 10);
+ assert(ERANGE != errno && EINVAL != errno);
+ (*rows_processed) = (int)rows;
+ else
+ /* Retrieve error message associated with last command. */
+ buf = PQresultErrorMessage(pgresult);
+ postgis_set_err_msg(context, buf);
+ * TODO: mloskot - Find better error code or map PgSQL error codes to RDBI.
+ ret = RDBI_RESOURCE_LOCK;
+ /* Clear PostgreSQL resources. */
+ postgis_pgresult_clear(pgresult);
+ return (ret);
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -22,118 +22,61 @@
#include "disconnect.h"
-#include <string.h> /* strncpy() */
-#include <malloc.h> /* alloca() */
+#include "pgresult_error.h"
+#include <string.h> /* memset(), strlen(), strncpy() */
+#include <malloc.h>
#include <assert.h>
-int postgis_set_schema(postgis_context_def *context, char* schema_name)
+int postgis_set_schema(postgis_context_def *context, const char* schema_name)
- int conn_index = 0;
- char* pgdb = NULL;
- char* pghost = NULL;
- char* pgport = DEF_PGPORT_STR; /* Default port for PostgreSQL */
+ char* sql = NULL;
+ size_t sql_len = 0;
+ const size_t sql_part_len = 20;
- char* pglogin = NULL;
- char* pgpwd = NULL;
- /* Connection string - need to be freed */
- char* connstr = NULL;
- size_t connstr_len = 0;
/* Strings manipulation helpers */
- char* buf = NULL;
- size_t buf_len = 0;
assert(NULL != schema_name);
- if (RDBI_SUCCESS == postgis_conn_status(context))
- if (NULL != postgis)
- * Collect connection string elements.
- /* database + @ */
- connstr_len = strlen(schema_name) + 1;
+ * SET search_path TO <new_schema_name>
- buf = PQhost(postgis);
- buf_len = strlen(buf) + 1;
- pghost = (char*)alloca(buf_len);
- strncpy(pghost, buf, buf_len);
+ sql_len = strlen(schema_name) + sql_part_len;
+ sql = (char*)malloc(sql_len);
+ if (NULL == sql)
+ else
+ memset(sql, 0, sql_len);
+ sprintf(sql, "SET search_path TO %s", schema_name);
- /* database + @ + host + : */
- connstr_len = connstr_len + buf_len;
- buf = PQport(postgis);
- pgport = (char*)alloca(buf_len);
- strncpy(pgport, buf, buf_len);
- /* database + @ + host + : + port */
- * Collect authorization parameters.
- buf = PQuser(postgis);
- pglogin = (char*)malloc(buf_len);
- memset(pglogin, '\0', buf_len);
- strncpy(pglogin, buf, buf_len);
- buf = PQpass(postgis);
- pgpwd = (char*)malloc(buf_len);
- memset(pgpwd, '\0', buf_len);
- strncpy(pgpwd, buf, buf_len);
- * Disconnect from current schema (database).
- ret = postgis_disconnect(context);
- * Make new connection string: database at host:port
- connstr_len = connstr_len + 1;
- connstr = (char*)malloc(connstr_len);
- if (NULL == connstr)
- return RDBI_MALLOC_FAILED;
- memset(connstr, '\0', connstr_len);
- strncpy(connstr, schema_name, strlen(schema_name)); /* Excluding null */
- strncat(connstr, "@", 1);
- strncat(connstr, pghost, strlen(pghost));
- strncat(connstr, ":", 1);
- strncat(connstr, pgport, strlen(pgport));
- assert(strlen(connstr) <= connstr_len);
- * Re-connect using new schema name.
- // TODO - mloskot: Confirm if disconnect-connect chain will
- // keep the same previously assigned connection ID (index).
- ret = postgis_connect(context, connstr, pglogin, pgpwd, NULL, &conn_index);
- free(connstr);
- free(pgpwd);
- free(pglogin);
+ postgis_pgresult_error(context, pgresult);
- } /* if (NULL != postgis) */
+ free(sql);
+ sql = NULL;
return (ret);
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.h
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.h 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/set_schema.h 2007-01-23 02:08:10 UTC (rev 676)
@@ -23,16 +23,12 @@
* Change schema for current session.
- * Current schema is changed in following sequence of operations:
- * - disconnect of current database
- * - alter connection parameters with new schema name (database)
- * - connect using new parametres
* @param context [in] - pointer to PostGIS session context.
- * @param schema_name [in] - name of new schema (database) to set
- * for current session.
+ * @param schema_name [in] - name of PostgreSQL schema being switched to
+ * for the current session.
* @return RDBI_SUCCESS on success, error code otherwise.
-int postgis_set_schema(postgis_context_def *context, char* schema_name);
+int postgis_set_schema(postgis_context_def *context, const char* schema_name);
#endif /* POSTGIS_SET_SCHEMA_H */
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/sql.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/sql.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/sql.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -20,83 +20,75 @@
#include "sql.h"
#include <assert.h>
-int postgis_sql (
- char *cursor,
- char *sql,
- int defer, /* not used */
- char *verb,
- void *ptree, /* dbi_prse_tree_def - not used */
- char *cursor_coc) /* not used */
+int postgis_sql (postgis_context_def *context,
+ char *cursor,
+ char *sql,
+ int defer, /* not used */
+ char *verb, /* not used */
+ void *ptree, /* not used */
+ char *cursor_coc) /* not used */
- ExecStatusType pgstatus;
- int result = 0;
- else
+ if (NULL == curs)
else
- if (NULL == curs)
- else
- // TODO - mloskot: Finish process of cursor allocation.
+ // TODO - mloskot: Finish process of cursor allocation.
- assert(NULL != curs->stmt_name);
+ assert(NULL != curs->stmt_name);
- postgis_fre_binds (curs);
+ postgis_fre_binds (curs);
- pgresult = PQprepare(postgis, curs->stmt_name,
- sql, curs->bind_count, NULL);
- if (NULL != pgresult)
+ pgresult = PQprepare(postgis, curs->stmt_name,
+ sql, curs->bind_count, NULL);
- // TODO - mloskot: Change to common status function
- pgstatus = PQresultStatus(pgresult);
- if (PGRES_COMMAND_OK != pgstatus)
- postgis_pgresult_error (pgresult, "prepare failed");
- else
- // Successfully prepared statement
- else
- * NULL indicates out-of-memory or inability to send the command at all.
+ else
+ * NULL indicates a fatal error like out-of-memory or
+ * inability to send the command at all.
+ postgis_set_err_msg(context, PQerrorMessage(postgis));
- // Release PostgreSQL resources for query result
+ * Release PostgreSQL resources for query result.
- return (ret);
+ return ret;
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/stdafx.h
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/stdafx.h 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/stdafx.h 2007-01-23 02:08:10 UTC (rev 676)
@@ -1,72 +1,86 @@
-#ifndef POSTGIS_DRIVER_STDAFX_H
-#define POSTGIS_DRIVER_STDAFX_H
-#ifdef _WIN32
-/* Exclude rarely-used stuff from Windows headers. */
-# define WIN32_LEAN_AND_MEAN
-# include <windows.h>
-#endif /* _WIN32 */
-/* Standard library */
-#include <stdio.h>
-/* RDBI interface */
-#include <Inc/rdbi.h>
-/* PostgreSQL client library */
-#include <libpq-fe.h>
- * POSTGISDR_CALL
- * The following macro allowis various calling conventions
- * on the RDBI PostGIS API driver.
-#ifdef _WIN32
-# define POSTGISDR_CALL __declspec(dllexport)
-#else
- * Helper macro that determines the number of elements
- * in a statically-sized array.
- * NOTE: This doesn't work for dynamically-sized arrays.
-#define ELEMENTS(x) (sizeof(x)/sizeof(x[0]))
- * DEF_PGPORT
- * NOTE: This macro has been copied directly from pg_config.h file,
- * from PostgreSQL sources.
- * Define to the default TCP port number on which the server listens and to
- * which clients will try to connect.
-#define DEF_PGPORT 5432
-#define DEF_PGPORT_STR "5432"
-#endif /* POSTGIS_DRIVER_STDAFX_H */
+#ifndef POSTGIS_DRIVER_STDAFX_H
+#define POSTGIS_DRIVER_STDAFX_H
+#ifdef _WIN32
+/* Exclude rarely-used stuff from Windows headers. */
+# define WIN32_LEAN_AND_MEAN
+# include <windows.h>
+#endif /* _WIN32 */
+/* Standard library */
+#include <stdio.h> /* snprintf() */
+/* RDBI interface */
+#include <Inc/rdbi.h>
+/* PostgreSQL client library */
+#include <libpq-fe.h>
+ * POSTGISDR_CALL
+ * The following macro allowis various calling conventions
+ * on the RDBI PostGIS API driver.
+#ifdef _WIN32
+# define POSTGISDR_CALL __declspec(dllexport)
+#else
+ * Helper macro that determines the number of elements
+ * in a statically-sized array.
+ * NOTE: This doesn't work for dynamically-sized arrays.
+#define ELEMENTS(x) (sizeof(x)/sizeof(x[0]))
+ * DEF_PGPORT
+ * NOTE: This macro has been copied directly from pg_config.h file,
+ * from PostgreSQL sources.
+ * Define to the default TCP port number on which the server listens and to
+ * which clients will try to connect.
+#define DEF_PGPORT 5432
+#define DEF_PGPORT_STR "5432"
+ * C/POSIX prototypes
+#ifdef _WIN32
+#define snprintf _snprintf
+#endif
+#ifdef _WIN32
+ typedef __int64 rdbi_int64_t;
+#else
+ typedef long long rdbi_int64_t;
+#endif /* POSTGIS_DRIVER_STDAFX_H */
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.c
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.c 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.c 2007-01-23 02:08:10 UTC (rev 676)
@@ -82,6 +82,10 @@
* Type not recognized.
+ // TODO: mloskot - Should we use OID of UNKNOWN type - 705 - or return Zero?
+ ret = PGSQL_TYPE_UNKNOWN;
ret = 0;
@@ -152,17 +156,25 @@
length = (typemod - PGSQL_VAR_HDRSZ);
if (length > 0)
- ret = RDBI_FIXED_CHAR; /* character varying WITH a length specifier. */
+ // TODO: mloskot - Find a better type for VARCHAR(N)
+ ret = RDBI_STRING; /* character varying WITH a length specifier. */
else
ret = RDBI_STRING; /* character varying WITHOUT a length specifier. */
break;
+ case PGSQL_TYPE_NAME: /* default maximum length is 64 characters. */
+ ret = RDBI_FIXED_CHAR;
+ break;
ret = RDBI_STRING;
break;
case PGSQL_TYPE_BLOB:
ret = RDBI_BLOB;
break;
+ case PGSQL_TYPE_UNKNOWN:
+ // TODO: mloskot - Should we cast to STRING?
+ ret = -1;
+ break;
default:
/* Type not recognized or identifies PostGIS geometry, see below */
ret = -1;
@@ -216,6 +228,42 @@
return oid;
+int postgis_get_name_length(PGconn* conn)
+ int length = 0;
+ const char* query = "SELECT typlen FROM pg_type WHERE typname = 'name'";
+ assert(NULL != conn);
+ pgresult = PQexec(conn, query);
+ if (PGRES_TUPLES_OK == PQresultStatus(pgresult) && PQntuples(pgresult) > 0)
+ length = strtol(PQgetvalue(pgresult, 0, 0), NULL, 10);
+ if (LONG_MIN == length || LONG_MAX == length || 0 == length)
+ /* Report if value overflow occured or no conversion was performed */
+ length = -1;
+ * TODO - print error
+ assert(!"strtol value overflow");
+ PQclear(pgresult);
+ * 0 - failure
+ return length;
int postgis_get_numeric_precision(const PGresult* pqres, int column_number)
int precision = PGSQL_VAR_NOINFO; /* No information available */
@@ -261,7 +309,8 @@
/* Check if given column is of type of fixed-length CHARACTER */
if (PGSQL_TYPE_CHAR == PQftype(pqres, column_number)
- || PGSQL_TYPE_BPCHAR == PQftype(pqres, column_number))
+ || PGSQL_TYPE_BPCHAR == PQftype(pqres, column_number)
+ || PGSQL_TYPE_NAME == PQftype(pqres, column_number))
fmod = PQfmod(pqres, column_number);
if (PGSQL_VAR_NOINFO != fmod)
@@ -280,7 +329,8 @@
if (NULL != pqres)
/* Check if given column is of character varying type */
- if (PGSQL_TYPE_VARCHAR == PQftype(pqres, column_number))
+ if (PGSQL_TYPE_VARCHAR == PQftype(pqres, column_number)
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.h
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.h 2007-01-23 02:06:35 UTC (rev 675)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/PostGIS/Driver/type.h 2007-01-23 02:08:10 UTC (rev 676)
@@ -31,15 +31,31 @@
enum enum_varlena_details
PGSQL_VAR_NOINFO = -1, /**< No information is available */
- PGSQL_VAR_HDRSZ = 4 /**< Represented as sizeof(int) */
+ PGSQL_VAR_HDRSZ = 4, /**< Represented as sizeof(int) */
+ /* Max size of variable unlimited length text is
+ * arbitrarily assumed as 64 KB
+ PGSQL_VARCHAR_MAX_SIZE = 65536
+ * Definition of characteristics of boolean type.
+enum enum_boolean_details
+ PGSQL_BOOLEAN_SIZE = 1,
+ PGSQL_BOOLEAN_RDBI_SIZE = 2
* This enum maps PostgreSQL OIDs to types enumeration.
* Enumerators are assigned with values from PostgreSQL 'pg_type' table.
enum enum_field_types
+ PGSQL_TYPE_UNKNOWN = 705, // UNKNOWN
PGSQL_TYPE_BOOL = 16, // bool
PGSQL_TYPE_INT2 = 21, // int2, smallint
@@ -62,6 +78,7 @@
PGSQL_TYPE_BPCHAR = 1042, // bpchar, the same as char
PGSQL_TYPE_VARCHAR = 1043, // varchar
PGSQL_TYPE_TEXT = 25, // text
+ PGSQL_TYPE_NAME = 19, // name, length 64 characters
PGSQL_TYPE_BLOB = 17, // bytea
@@ -103,6 +120,16 @@
Oid postgis_get_geometry_oid(PGconn* conn);
+ * Retrieves default maximum length of NAME type.
+ * NAME type is used internally by PostgreSQL, in pg_catalog tables and views.
+ * Default length is set in compile time using NAMEDATALEN constant.
+ * @param conn - connection to PostgreSQL database.
+ * @return Value of maximum length for NAME type.
+int postgis_get_name_length(PGconn* conn);
* Retrieves precision component for type of given column.
* The precision is decoded form value returned by PQfmod() function.
More information about the fdo-commits
