Boost build problem from SVN-head
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 4 14:24:02 EDT 2006
Folks,
I'm trying to build the third party stuff for FDO from SVN head and I
get the following:
Project "C:\warmerda\fdocore\Thirdparty\boost_1_32_0\boost_1_32_0.vcproj"
(Build target(s)):
Target Build:
C:\warmerda\fdocore\Thirdparty\boost_1_32_0\boost_1_32_0.vcproj : warning
MSB4098: MSBuild is invoking VCBuild to build this project. Project-to-project
references between VC++ projects (.VCPROJ) and C#/VB/VJ# projects (.CSPROJ,
.VBPROJ, .VJSPROJ) are not supported by the command-line build systems when
building stand-alone VC++ projects. Projects that contain such
project-to-project references will fail to build. Please build the solution
file containing this project instead.
C:\Program Files\Microsoft Visual Studio
8\Common7\IDE\..\..\vc\vcpackages\vcbuild.exe
C:\warmerda\fdocore\Thirdparty\boost_1_32_0\boost_1_32_0.vcproj "debug|Win32"
Project : error PRJ0019: A tool returned an error code from "Performing
Makefile project actions"
Done building target "Build" in project "boost_1_32_0.vcproj" -- FAILED.
I tried using visual studio but this didn't seem to work. Does anyone have
a suggestion on what I need to do?
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
More information about the Fdo-internals
