Boost build problem from SVN-head
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 17 10:02:33 EDT 2006
Frank Warmerdam wrote:
> Folks,
> I'm trying to build the third party stuff for FDO from SVN head and I
> get the following:
> Project
> "C:\warmerda\fdocore\Thirdparty\boost_1_32_0\boost_1_32_0.vcproj" (Build
> target(s)):
> Target Build:
> C:\warmerda\fdocore\Thirdparty\boost_1_32_0\boost_1_32_0.vcproj :
> warning MSB4098: MSBuild is invoking VCBuild to build this project.
> Project-to-project references between VC++ projects (.VCPROJ) and
> C#/VB/VJ# projects (.CSPROJ, .VBPROJ, .VJSPROJ) are not supported by the
> command-line build systems when building stand-alone VC++ projects.
> Projects that contain such project-to-project references will fail to
> build. Please build the solution file containing this project instead.
> C:\Program Files\Microsoft Visual Studio
> 8\Common7\IDE\..\..\vc\vcpackages\vcbuild.exe
> "debug|Win32"
> Project : error PRJ0019: A tool returned an error code from
> "Performing Makefile project actions"
> Done building target "Build" in project "boost_1_32_0.vcproj" -- FAILED.
> I tried using visual studio but this didn't seem to work. Does anyone have
> a suggestion on what I need to do?
Folks,
In follow up to my own problem:
o The warning MSB4098 is normal and not really a problem.
o I looked in the boost\BuildLog.htm (with a real browser since it is in
some sort of funky 16bit character set) and saw an "Access Error" though
without any indication of on what. But I also saw that "bjam" was being
executed to do the build.
o I tried running bjam.exe and got an access error. It seems my Cygwin
SVN client extracted the executable without execute permissions for some
reason.
When I set execute permission on the .exe things worked ok.
So lessons:
o If there are things like .exe's in SVN there are some limitations on what
SVN clients will work properly. With MapGuide I found the Cygwin svn was
unable to handle some character set conversion problem on checkout and I
had to upgrade to TortiseSVN. Perhaps we need some note about this
somewhere?
o In MSBUILD problems, do dig into the BuildLog.htm to find out what is going
wrong.
o Perhaps we could have the build scripts include an action to make .exe
files executable to work around this sort of problem.
Now, on to figure out why my actual fdo build isn't working. Somehow I
always pick the wrong way to do things!
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
More information about the Fdo-internals
