[fdo-dev] FDO172 & Warning of "build breaker" changes
Jason Birch
Jason.Birch at nanaimo.ca
Tue Sep 26 11:40:22 EDT 2006
This is the batch file that I've been using...
Jason
-----Original Message-----
From: Greg Boone [mailto:greg.boone at autodesk.com]
Sent: Tuesday, September 26, 2006 08:26
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] FDO172 & Warning of "build breaker" changes
No. There is no update script yet. It is on my list of things to do....
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Tuesday, September 26, 2006 10:28 AM
Subject: Re: [fdo-dev] FDO172 & Warning of "build breaker" changes
Greg Boone wrote:
> Hi Frank,
> I just did a checkout from fdocore.osgeo.org and fdogdal.osgeo.org and
> everything build successfully.
> Did you run the checkoutsvn.bat script to synchronize all fdo osgeo
> folders?
Greg,
Is there any new version of checkoutsvn.bat script?
Have you seen my comments I posted some time ago:
https://fdo.osgeo.org/servlets/ReadMsg?list=dev&msgNo=69
This script won't correctly *merge* new changes into local copy.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
@echo off
SET DEFMODIFYCHK=no
SET FDOCOREENABLECHK=yes
SET THRPENABLECHK=yes
SET FDOENABLECHK=yes
SET UTILENABLECHK=yes
SET SHPENABLECHK=yes
SET SDFENABLECHK=yes
SET WFSENABLECHK=yes
SET WMSENABLECHK=yes
SET ARCENABLECHK=yes
SET RDBMSENABLECHK=yes
SET GDALENABLECHK=yes
if (%FDO_SVN_ROOT%)==() SET FDO_SVN_ROOT=%cd%
:study_params
if (%1)==() goto start_checkout
if "%1"=="-help" goto help_show
if "%1"=="-h" goto help_show
if "%1"=="-o" goto get_path
if "%1"=="-outpath" goto get_path
if "%1"=="-u" goto get_user
if "%1"=="-user" goto get_user
if "%1"=="-p" goto get_password
if "%1"=="-password" goto get_password
if "%1"=="-w" goto get_with
if "%1"=="-with" goto get_with
goto custom_error
:get_password
if (%2)==() goto custom_error
SET FDO_SVN_PASSWORD=%2
goto next_param
:get_user
SET FDO_SVN_USERNAME=%2
goto next_param
:get_with
if "%DEFMODIFYCHK%"=="yes" goto stp0_get_with
SET DEFMODIFYCHK=yes
SET THRPENABLECHK=no
SET FDOCOREENABLECHK=no
SET FDOENABLECHK=no
SET SHPENABLECHK=no
SET SDFENABLECHK=no
SET WFSENABLECHK=no
SET WMSENABLECHK=no
SET ARCENABLECHK=no
SET RDBMSENABLECHK=no
SET UTILENABLECHK=no
SET GDALENABLECHK=no
:stp0_get_with
if not "%2"=="providers" goto stp1_get_with
goto next_param
:stp1_get_with
if not "%2"=="all" goto stp2_get_with
SET FDOENABLECHK=no
goto next_param
:stp2_get_with
if not "%2"=="fdocore" goto stp3_get_with
SET FDOENABLECHK=no
goto next_param
:stp3_get_with
if not "%2"=="thirdparty" goto stp4_get_with
goto next_param
:stp4_get_with
if not "%2"=="utilities" goto stp5_get_with
goto next_param
:stp5_get_with
if not "%2"=="fdo" goto stp6_get_with
goto next_param
:stp6_get_with
if not "%2"=="shp" goto stp7_get_with
goto next_param
:stp7_get_with
if not "%2"=="sdf" goto stp8_get_with
goto next_param
:stp8_get_with
if not "%2"=="wfs" goto stp9_get_with
goto next_param
:stp9_get_with
if not "%2"=="wms" goto stp10_get_with
goto next_param
:stp10_get_with
if not "%2"=="arcsde" goto stp11_get_with
goto next_param
:stp11_get_with
if not "%2"=="rdbms" goto stp12_get_with
goto next_param
:stp12_get_with
if not "%2"=="gdal" goto custom_error
goto next_param
:get_path
if not exist "%~2" mkdir "%~2"
pushd "%~2"
if errorlevel 1 goto error
popd
:next_param
shift
shift
goto study_params
:start_checkout
if "%FDO_SVN_PASSWORD%"=="" goto custom_error
if "%FDO_SVN_USERNAME%"=="" goto custom_error
if not exist "%FDO_SVN_ROOT%" mkdir "%FDO_SVN_ROOT%"
if "%FDOCOREENABLECHK%"=="yes" goto checkout_all
:checkout_fdo
if "%FDOENABLECHK%"=="no" goto checkout_thirdparty
echo Updating Fdo
svn update https://fdocore.osgeo.org/svn/fdocore/trunk/Fdo "%FDO_SVN_ROOT%\Fdo" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_thirdparty
if "%THRPENABLECHK%"=="no" goto checkout_utilities
echo Updating ThirdParty
svn update https://fdocore.osgeo.org/svn/fdocore/trunk/Thirdparty "%FDO_SVN_ROOT%\Thirdparty" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_utilities
if "%UTILENABLECHK%"=="no" goto checkout_shp
echo Updating Utilities
svn update https://fdocore.osgeo.org/svn/fdocore/trunk/Utilities "%FDO_SVN_ROOT%\Utilities" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
goto checkout_shp
:checkout_all
echo Updating FDO
echo Updating www
svn update https://fdocore.osgeo.org/svn/fdocore/trunk/www "%FDO_SVN_ROOT%\www" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
echo Updating Base
svn update https://fdocore.osgeo.org/svn/fdocore/trunk -N "%FDO_SVN_ROOT%" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_shp
if "%SHPENABLECHK%"=="no" goto checkout_sdf
echo Updating provider: SHP
svn update https://fdoshp.osgeo.org/svn/fdoshp/trunk/Providers/SHP "%FDO_SVN_ROOT%\Providers\SHP" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_sdf
if "%SDFENABLECHK%"=="no" goto checkout_wfs
echo Updating provider: SDF
svn update https://fdosdf.osgeo.org/svn/fdosdf/trunk/Providers/SDF "%FDO_SVN_ROOT%\Providers\SDF" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_wfs
if "%WFSENABLECHK%"=="no" goto checkout_wms
echo Updating provider: WFS
svn update https://fdowfs.osgeo.org/svn/fdowfs/trunk/Providers/WFS "%FDO_SVN_ROOT%\Providers\WFS" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_wms
if "%WMSENABLECHK%"=="no" goto checkout_arcsde
echo Updating provider: WMS
svn update https://fdowms.osgeo.org/svn/fdowms/trunk/Providers/WMS "%FDO_SVN_ROOT%\Providers\WMS" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_arcsde
if "%ARCENABLECHK%"=="no" goto checkout_generic
echo Updating provider: ArcSDE
svn update https://fdoarcsde.osgeo.org/svn/fdoarcsde/trunk/Providers/ArcSDE "%FDO_SVN_ROOT%\Providers\ArcSDE" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_generic
if "%RDBMSENABLECHK%"=="no" goto checkout_gdal
echo Updating provider: GenericRDBMS
svn update https://fdordbms.osgeo.org/svn/fdordbms/trunk/Providers/GenericRdbms "%FDO_SVN_ROOT%\Providers\GenericRdbms" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:checkout_gdal
if "%GDALENABLECHK%"=="no" goto end
echo Updating provider: GDAL
svn update https://fdogdal.osgeo.org/svn/fdogdal/trunk/Providers/GDAL "%FDO_SVN_ROOT%\Providers\GDAL" --username %FDO_SVN_USERNAME% --password %FDO_SVN_PASSWORD%
:end
exit /B 0
:error
echo Failed to checkout files.
exit /B 1
:custom_error
echo The command is not recognized.
echo Please use the format:
:help_show
echo **************************************************************
echo checkoutsvn.bat [-h]
echo [-o=OutFolder]
echo [-w=WithModule]
echo -u=UserId
echo -p=UserPassword
echo *
echo Help: -h[elp]
echo OutFolder: -o[utpath]=destination folder for files
echo WithModule: -w[ith]=all(default),
echo fdo,
echo fdocore,
echo thirdparty,
echo providers,
echo utilities,
echo shp,
echo sdf,
echo wfs,
echo wms,
echo arcsde,
echo rdbms,
echo gdal
echo User: -u[ser]=user id
echo Password: -p[assword]=user password
exit /B 0
More information about the Fdo-internals
