[fdo-internals] FDO env. variables
Mateusz Loskot
mateusz at loskot.net
Wed Apr 11 13:51:55 EDT 2007
Traian Stanev wrote:
> If you run setenvironment and then run devenv from within that command
> window, wouldn't Visual Studio pick up the correct environment vars?
Sure, it will.
BTW, I think in simple cases, when it's only needed to *select* FDO
version to build a provider, VS Prop. Sheets. will help too.
I use it in the fdopostgis:
http://svn.refractions.net/fdopostgis/trunk/Providers/PostGIS/Src/PostGis.vsprops
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
