[fdo-internals] Development of FDO provider for OGC SOS
Greg Boone greg.boone at autodesk.com
Fri Dec 14 10:47:32 EST 2007
I would definitely recommend using the wms/wfs providers as a starting point. If you would like, we can collaborate on getting the provider off the ground. I would be able to quickly put together a starting C++ code base that would be the basis of development. We can then start discussing requirements and capabilities.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Pierre-Nicolas.HUTIN at fr.thalesgroup.com
Sent: Wednesday, December 12, 2007 12:22 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Development of FDO provider for OGC SOS
> Good Morning,
> I'm currently studying FDO technology to access some information from an
> OGC service called Sensor Observation Service (SOS).  The Sensor
> Observation Service provides infomation about some sensors and their
> measurements in a standard way defined by OGC
> (http://www.opengeospatial.org/projects/groups/sensorweb). The response
> from the SOS is an XML document.
> The idea would be to display the sensor on a map, according the position
> provided by the SOS, and according the value of its measurements change
> the display of the sensor marker (color or symbol). Another point is that
> a SOS stores data from several measurements; how historical measurements
> can be made accessible via FDO ?
> I wanted to know if anyone is currently developping such a provider or has
> already thought of doing it. What is the starting point and what can be
> reused from the providers for WMS/WFS which are other OGC services?
> Thank you!
> Pierre-Nicolas
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
