[fdo-internals] KingOracle Provider Build Process Update
Greg Boone
greg.boone at autodesk.com
Mon Dec 17 10:31:35 EST 2007
There seems to be a typo in the setenvironment script. I have submitted a newer version. ** However, you will still have to modify setenvironment.bat and set the correct location of FDOORACLE for your installation of the oracle client.
As for the link you provided below, it references the installation of the Oracle database. The link I provided references the instant client SDK only.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mange
Sent: Monday, December 17, 2007 1:57 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] KingOracle Provider Build Process Update
I tried to build it and the first thing I discovered was that you have not
altered setenvironment.sh to contain the env FDOORACLE. (I have trunk build
3623)
And. . .the link to the linux oracle client is:
http://www.oracle.com/technology/software/products/database/oracle10g/htdocs/10201linuxsoft.html
Though I could not find the version you suggest.
And I tried to build the trunk wo oracle client and it did not work.
probably because I didn't have the env.
Hope this helps, Mange
View this message in context: http://www.nabble.com/KingOracle-Provider-Build-Process-Update-tp14263400s18162p14313016.html
Sent from the fdo-internals mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
