[fdo-internals] KingOracle Provider Build Process Update
larry white larz at neomatix.ca
Mon Dec 17 11:52:47 EST 2007
I was able to successfully compile the provider once i removed all the
extra qualifications listed below.
Setting FDOORACLE, manually, didn't seem to help so I used LDFLAGS  and
CPPFLAGS to point to the libs and include files.
As mentioned, compilation was successful. However, I have not tested the
provider yet.
Operating system: CentOS 5
c_FdoOra_API.h:28: error: extra qualification 'c_FdoOra_API::' on member
'DescribeSchema'
c_FdoOra_API.h:30: error: extra qualification 'c_FdoOra_API::' on member
'OraTypeToFdoDataType'
c_FdoOra_API.h:40: error: extra qualification 'c_FdoOra_API::' on member
'DescribeSchemaSQL'
c_OCCI_API.h:42: error: extra qualification 'c_OCCI_API::' on member
'CreateConnection'
c_OCCI_API.h:47: error: extra qualification 'c_OCCI_API::' on member
'CloseConnection'
c_OCCI_API.h:59: error: extra qualification 'c_OCCI_API::' on member
'GetConnPool'
c_Ora_API.h:40: error: extra qualification 'c_Ora_API::' on member
'CreateOptimizedRect'
c_Ora_API.h:49: error: extra qualification 'c_Ora_API::' on member
'GetCoordinateSystemWkt'
c_FdoOra_API.cpp: In static member function 'static bool
c_FdoOra_API::SetOracleStatementData(oracle::occi::Environment*,
oracle::occi::Statement*, int, FdoDataValue*)':
c_FdoOra_API.cpp:213: warning: passing 'float' for argument 7 to
'oracle::occi::Date::Date(const oracle::occi::Environment*, int,
-- larry white
Systems Integrator
neomatix.ca
Greg Boone wrote:
> There seems to be a typo in the setenvironment script. I have submitted a newer version. ** However, you will still have to modify setenvironment.bat and set the correct location of FDOORACLE for your installation of the oracle client.
> As for the link you provided below, it references the installation of the Oracle database. The link I provided references the instant client SDK only.
> Greg
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mange
> Sent: Monday, December 17, 2007 1:57 AM
> To: fdo-internals at lists.osgeo.org
> Subject: Re: [fdo-internals] KingOracle Provider Build Process Update
> I tried to build it and the first thing I discovered was that you have not
> altered setenvironment.sh to contain the env FDOORACLE. (I have trunk build
> 3623)
> And. . .the link to the linux oracle client is:
> http://www.oracle.com/technology/software/products/database/oracle10g/htdocs/10201linuxsoft.html
> Though I could not find the version you suggest.
> And I tried to build the trunk wo oracle client and it did not work.
> probably because I didn't have the env.
> Hope this helps, Mange
> View this message in context: http://www.nabble.com/KingOracle-Provider-Build-Process-Update-tp14263400s18162p14313016.html
> Sent from the fdo-internals mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
