[fdo-internals] Unwinding FDO exceptions
Mateusz Loskot mateusz at loskot.net
Sun Feb 4 02:34:10 EST 2007
Hello,
I'm not sure I understand how to process the roll of FDO exceptions,
so I'd like to ask for confirmation if I'm correct or not.
Here are blocks of nested try-catch that mimic situation in which an
exception is thrown by a callee and re-thrown by a caller, and so on.
In the catch clause, is presented the idea of unwinding nested
exception, using some pseudo-code to make the example simpler.
try
  try
    try
      throw FdoException::Create(L"First exception");
    catch (FdoException* ex)
      throw FdoException::Create(L"Second caused by first", ex);
      throw FdoException::Create(L"Third caused by second", ex);
  // echo is a pseudo-code representing stdout action
  echo "*** FDO FAILURE ***\n"
  echo ex->GetExceptionMessage()
  FdoPtr<FdoException> cause(ex->GetCause());
  while(NULL != cause)
    echo "*** " + cause->GetExceptionMessage() + "\n"
    cause = cause->GetCause();
  ex->Release();
And here is the output:
*** FDO FAILURE ***
  *** Third caused by second
   *** Second caused by first
    *** First exception
Is this output correct and as usually expected in FDO?
Is this correct to assume that exceptions are
queued as in FILO, First In - Last Out ?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
