[fdo-internals] Unwinding FDO exceptions
Greg Boone
greg.boone at autodesk.com
Sun Feb 4 16:56:13 EST 2007
You results look accurate. FILO behaviour is as expected.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org on behalf of Mateusz Loskot
Sent: Sun 2/4/2007 2:34 AM
To: fdo-internals
Cc:
Subject: [fdo-internals] Unwinding FDO exceptions
Hello,
I'm not sure I understand how to process the roll of FDO exceptions,
so I'd like to ask for confirmation if I'm correct or not.
Here are blocks of nested try-catch that mimic situation in which an
exception is thrown by a callee and re-thrown by a caller, and so on.
In the catch clause, is presented the idea of unwinding nested
exception, using some pseudo-code to make the example simpler.
try
try
try
throw FdoException::Create(L"First exception");
catch (FdoException* ex)
throw FdoException::Create(L"Second caused by first", ex);
throw FdoException::Create(L"Third caused by second", ex);
// echo is a pseudo-code representing stdout action
echo "*** FDO FAILURE ***\n"
echo ex->GetExceptionMessage()
FdoPtr<FdoException> cause(ex->GetCause());
while(NULL != cause)
echo "*** " + cause->GetExceptionMessage() + "\n"
cause = cause->GetCause();
ex->Release();
And here is the output:
*** FDO FAILURE ***
*** Third caused by second
*** Second caused by first
*** First exception
Is this output correct and as usually expected in FDO?
Is this correct to assume that exceptions are
queued as in FILO, First In - Last Out ?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070204/dd5c2b56/attachment.html
More information about the fdo-internals
