[fdo-internals] Unwinding FDO exceptions
Mateusz Loskot
mateusz at loskot.net
Sun Feb 4 17:19:03 EST 2007
Thank you Greg!
Mateusz
Greg Boone wrote:
> You results look accurate. FILO behaviour is as expected.
> -----Original Message-----
> *From:* fdo-internals-bounces at lists.osgeo.org on behalf of Mateusz
> Loskot
> *Sent:* Sun 2/4/2007 2:34 AM
> *To:* fdo-internals
> *Cc:*
> *Subject:* [fdo-internals] Unwinding FDO exceptions
> Hello,
> I'm not sure I understand how to process the roll of FDO exceptions,
> so I'd like to ask for confirmation if I'm correct or not.
> Here are blocks of nested try-catch that mimic situation in which an
> exception is thrown by a callee and re-thrown by a caller, and so on.
> In the catch clause, is presented the idea of unwinding nested
> exception, using some pseudo-code to make the example simpler.
> try
> try
> try
> throw FdoException::Create(L"First exception");
> catch (FdoException* ex)
> throw FdoException::Create(L"Second caused by first", ex);
> throw FdoException::Create(L"Third caused by second", ex);
> // echo is a pseudo-code representing stdout action
> echo "*** FDO FAILURE ***\n"
> echo ex->GetExceptionMessage()
> FdoPtr<FdoException> cause(ex->GetCause());
> while(NULL != cause)
> echo "*** " + cause->GetExceptionMessage() + "\n"
> cause = cause->GetCause();
> ex->Release();
> And here is the output:
> *** FDO FAILURE ***
> *** Third caused by second
> *** Second caused by first
> *** First exception
> Is this output correct and as usually expected in FDO?
> Is this correct to assume that exceptions are
> queued as in FILO, First In - Last Out ?
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Mateusz Loskot
More information about the fdo-internals
