[fdo-internals] Hammerhead with FDO 3.2.x and fdopostgis
Mateusz Loskot
mateusz at loskot.net
Wed Feb 7 23:58:46 EST 2007
Robert Fortin wrote:
> Mateusz,
> I'm not sure that's the issue but it might be caused by the submission
> from Romi which change Idisposable to have virtual functions. I believe
> this is breaking binary compatibility and cause the problem you are
> seeing with Hammerhead.
> I would suggest that you rollback Romi's change in your
> environment and recompile FDO + your provider.
Robert,
Yes, that may be the reason.
Romica applied submitted this change in r678,
http://trac.osgeo.org/trac/fdo/changeset/678
and I use FDO 3.2.x of r719.
I think I'll try to rollback to prior 678, but am I correct I also
need to replace original .NET libraries (MgFdo*.dll) with those from
built together with my compilation of FDO core ?
Thanks for your help
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
