[fdo-internals] automake/autoconf/libtool preferred version?
Frank Warmerdam
warmerdam at pobox.com
Sat Feb 10 22:54:10 EST 2007
Folks,
What version of automake/autoconf/libtool are being used successfully when
building FDO "trunk" on Linux? I just tried building on my 64bit ubuntu
system and got some pretty funky issues.
The Fdo/Unmanaged/Src/Makefile includes this line:
libFDO.la: $(libFDO_la_OBJECTS) $(libFDO_la_DEPENDENCIES)
$(LINK) -rpath $(libdir) $(libFDO_la_LDFLAGS) $(libFDO_la_OBJECTS)
$(libFDO_la_LIBADD) $(LIBS)
But there is no definition of LINK in the Makefile, nor any apparently
definition so the command run start with the -rpath.
Oddly, even if I manually introduce LINK=ld in the file, I still get
a strange complaint about the rpath even though it looks fine.
I'm *assuming* this is some sort of automake, or perhaps libtool related
issue but I'm not exactly sure. I will say I hate it when building from
source control always means having to run my own versions of automake, libtool
and autoconf as often there are surprising version dependencies. But I do
accept that this is the common approach.
BTW, i'm running:
warmerda at amd64[85]% autoconf --version
autoconf (GNU Autoconf) 2.59
warmerda at amd64[86]% automake --version
automake (GNU automake) 1.4-p6
warmerda at amd64[87]% libtool --version
ltmain.sh (GNU libtool) 1.5.6 (1.1220.2.95 2004/04/11 05:50:42) Debian: 224 $
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the fdo-internals
