[fdo-internals] automake/autoconf/libtool preferred version?
Greg Boone greg.boone at autodesk.com
Sat Feb 10 23:21:13 EST 2007
I am successfully building on Fedora 5 with the following:
autoconf (GNU Autoconf) 2.59
automake (GNU automake) 1.9.6
ltmain.sh (GNU libtool) 1.5.22 (1.2220.2.365 2005/12/18 22:14:06)
I have not seen any warnings or errors to speak of.
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Saturday, February 10, 2007 10:54 PM
To: FDO Internals Mail List
Subject: [fdo-internals] automake/autoconf/libtool preferred version?
Folks,
What version of automake/autoconf/libtool are being used successfully
when
building FDO "trunk" on Linux?  I just tried building on my 64bit ubuntu
system and got some pretty funky issues.
The Fdo/Unmanaged/Src/Makefile includes this line:
libFDO.la: $(libFDO_la_OBJECTS) $(libFDO_la_DEPENDENCIES)
	$(LINK) -rpath $(libdir) $(libFDO_la_LDFLAGS)
$(libFDO_la_LIBADD) $(LIBS)
But there is no definition of LINK in the Makefile, nor any apparently
definition so the command run start with the -rpath.
Oddly, even if I manually introduce LINK=ld in the file, I still get
a strange complaint about the rpath even though it looks fine.
I'm *assuming* this is some sort of automake, or perhaps libtool related
issue but I'm not exactly sure.  I will say I hate it when building from
source control always means having to run my own versions of automake,
libtool
and autoconf as often there are surprising version dependencies.  But I
do
accept that this is the common approach.
BTW, i'm running:
warmerda at amd64[85]% autoconf --version
warmerda at amd64[86]% automake --version
automake (GNU automake) 1.4-p6
warmerda at amd64[87]% libtool --version
ltmain.sh (GNU libtool) 1.5.6 (1.1220.2.95 2004/04/11 05:50:42) Debian:
224 $
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
