[fdo-internals] automake/autoconf/libtool preferred version?
Frank Warmerdam
warmerdam at pobox.com
Sun Feb 11 01:26:14 EST 2007
Greg Boone wrote:
> I am successfully building on Fedora 5 with the following:
> autoconf (GNU Autoconf) 2.59
> automake (GNU automake) 1.9.6
> ltmain.sh (GNU libtool) 1.5.22 (1.2220.2.365 2005/12/18 22:14:06)
> I have not seen any warnings or errors to speak of.
Greg,
I have upgraded to automake 1.9.5 and things are working substantially
better now. At the very least this resolved the makefile problem. Now I'm
running into this:
g++ -DPACKAGE_NAME=\"FDO\" -DPACKAGE_TARNAME=\"fdo\"
-DPACKAGE_VERSION=\"3.2.0\" "-DPACKAGE_STRING=\"FDO 3.2.0\""
-DPACKAGE_BUGREPORT=\"https://fdocore.osgeo.org\" -DPACKAGE=\"fdo\"
-DVERSION=\"3.2.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
-DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
-DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I.
-I. -I../../Inc -I../Nls -I../Common -I../Geometry
-I/home/warmerda/fdobase/Thirdparty/apache/xml-xerces/c/src -MMD -MT
-DFULLPROTO -D__USE_GNU -DLINUX -DENABLE_BINRELOC -MT
FeaturePropertyReaderImpl.lo -MD -MP -MF .deps/FeaturePropertyReaderImpl.Tpo -c
Xml/FeaturePropertyReaderImpl.cpp -fPIC -DPIC -o .libs/FeaturePropertyReaderImpl.o
Xml/FeaturePropertyReaderImpl.cpp: In member function `virtual FdoBoolean
FdoXmlFeaturePropertyReaderImpl::XmlEndElement(FdoXmlSaxContext*, const
FdoString*, const FdoString*, const FdoString*)':
Xml/FeaturePropertyReaderImpl.cpp:536: error: no matching function for call to
`xercesc_2_5::Base64::decode(const XMLByte*, FdoSize*)'
/home/warmerda/fdobase/Thirdparty/apache/xml-xerces/c/src/xercesc/util/Base64.hpp:127:
note: candidates are: static XMLByte* xercesc_2_5::Base64::decode(const
XMLByte*, unsigned int*, xercesc_2_5::MemoryManager*)
/home/warmerda/fdobase/Thirdparty/apache/xml-xerces/c/src/xercesc/util/Base64.hpp:148:
note: static XMLCh* xercesc_2_5::Base64::decode(const XMLCh*,
This patch seems to get things building (cast the FdoSize * "&len"
to be an unsigned int *), but I suspect that this isn't legitimate
if FdoSize is actually 64bits in size on 64bit machines. Is that
the case?
warmerda at amd64$ svn diff Fdo/Xml/FeaturePropertyReaderImpl.cpp
Index: Fdo/Xml/FeaturePropertyReaderImpl.cpp
--- Fdo/Xml/FeaturePropertyReaderImpl.cpp (revision 2498)
+++ Fdo/Xml/FeaturePropertyReaderImpl.cpp (working copy)
@@ -533,7 +533,8 @@
case ParsingState_base64Binary:
FdoSize len;
- XMLByte* decoded = XERCES_CPP_NAMESPACE::Base64::decode((const
XMLByte*)(const char*)m_dataProperty, &len);
+ XMLByte* decoded = XERCES_CPP_NAMESPACE::Base64::decode((const
+ (unsigned
int *) &len);
if (decoded != NULL) {
curFeatureHandler->FeatureBinaryData(m_featureContext,
decoded, len);
XERCES_CPP_NAMESPACE::XMLString::release(&decoded);
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the fdo-internals
