[fdo-internals] Ticket #20 Generic RDBMS: fix various SelectAggregates defects
Romica Dascalescu Romica.Dascalescu at autodesk.com
Fri Feb 23 11:46:37 EST 2007
Ticket #20 Generic RDBMS: fix various SelectAggregates defects merged
form branch:
In select aggregates execute is check if functions are supported with
provided parameters (by looking in the extended capabilities). If the
function is not supported an exception is thrown.
Fixed Concat issue on ODBC SQL Server.
Fixed:
796236
MySQL: Select Aggregate function on a DateTime does not return a valid
value.
800672
MySQL: Datatype returned by MySQL Ceil function (Int64) doesn't match
Double returned by SQLServer or Oracle
812702
SqlServer: Select aggregate functions not returning proper return types
796226
MySQL: Select Aggregate Functions on boolean returns 1 or 0
673851.01
ODBC Provider: If one of functions, Lower, Upper and Concat is used in
computed properties of FdoISelectAggragates command for SQL Server, an
exception is thrown. linked
r2610 | romicadascalescu | 2007-02-23 12:39:54 -0500 (Fri, 23 Feb 2007)
| 1 line
Changed paths:
   M
/trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsSelectComm
and.cpp
   M /trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp
   M
/trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcFilterProcessor.c
pp
   M
/trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcFilterProcessor.h
   M
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.
cpp
   M
h
   M /trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcBaseSetup.cpp
   M
/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTes
t.cpp
   M
t.h
   M /trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.h
   M /trunk/Utilities/Common/FdoCommon.vcproj
   A /trunk/Utilities/Common/Inc/FdoCommonExpressionExecutor.h
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070223/52426ccc/attachment.html
More information about the fdo-internals mailing list
