[fdo-internals] Repeated header inclusion guards
Greg Boone
greg.boone at autodesk.com
Tue Feb 27 12:15:21 EST 2007
In order to maintain binary compatibility, let's leave 3.2.x as is and
not remove the duplicate class.
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Tuesday, February 27, 2007 11:46 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Repeated header inclusion guards
Brent,
Yes, I revealed it in the 3.2.x.
Anyway, I'll leave it as is, in 3.2.x, unless Greg will suggest to
report a ticket.
Mateusz
Brent Robinson wrote:
> Hi Mateusz,
> This one has been fixed in the trunk but is still present in the 3.2.x
> (3.2.2) branch. Greg would know better, but a trac ticket could likely
> be opened against 3.2.2 and fixed by backporting from the trunk.
> I'm not 100% sure if the fix introduces a binary compatibility change
> (it could only be applied to 3.2.x if it didn't). However, that could
be
> investigated by whoever gets assigned the ticket.
> Brent.
> From: fdo-internals-bounces at lists.osgeo.org
> Loskot
> Sent: Monday, February 26, 2007 10:06 PM
> To: fdo-internals
> Subject: [fdo-internals] Repeated header inclusion guards
> Hi,
> In the FDO Core, there are two headers using the same inclusion
guards.
> It potentially may cause problems and one of these file won't be
> included.
> Here they are:
d:\dev\fdopostgis\_svn\fdocore\Fdo\Unmanaged\Inc\Fdo\Raster\DataValueCol
> lection.h
> #ifndef _DATAVALUECOLLECTION_H_
> #define _DATAVALUECOLLECTION_H_
d:\dev\fdopostgis\_svn\fdocore\Fdo\Unmanaged\Inc\Fdo\Expression\DataValu
> eCollection.h
> Should I report it as a ticked on the FDO Trac?
> Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
