[fdo-internals] SVN Repository Merge Issues
Traian Stanev
traian.stanev at autodesk.com
Tue Jan 30 11:33:13 EST 2007
OK I understand what you are saying. I think that it's better to have
one configure script that builds all. In general, a developer would then
only need to do a full build once the first time they get the code.
After that, make will do incremental builds of whatever code the
developer changed. I assume a non-developer would not have to build
often enough to save them time by building select things. However,
another option I see possible is some kind of --with option to the
./configure script that configures the makefiles to build only the
providers that one needs.
Traian
_____
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, January 30, 2007 10:50 AM
To: FDO Internals Mail List; Robert Bray
Cc: Shawn Barnes
Subject: RE: [fdo-internals] SVN Repository Merge Issues
Your example is valid but does not answer the question I asked.
1) If a user runs the following from the top directory, should
this action build FDO and all providers?
automake
autoconf
./configure
make
2) Another question, should I be able to run ./configure from a
Provider subdirectory or will we only be able to run ./configure from
the root directory?
Greg
_____
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Tuesday, January 30, 2007 10:29 AM
Cc: Shawn Barnes
If the makefiles are set up right, one should be able to change
directory to where the provider is and run make from in there. This
would make it so that only that provider builds. That's how Mapguide
currently works -- if I change directory to /Server and run make, only
the server components will build.
Traian
_____
Sent: Monday, January 29, 2007 6:36 PM
To: Robert Bray
Cc: FDO Internals Mail List; Shawn Barnes
Hi Bob,
When I merge the Linux build process, do you wish to have a single
'make' request initiated at the top level build FDO and all the
providers under the Providers directory? This may be overhead that is
not required for users who wish to build only a single provider.
Greg
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070130/8530fc2a/attachment-0001.html
More information about the fdo-internals
