[fdo-internals] SVN Repository Merge Issues
Mateusz Loskot
mateusz at loskot.net
Tue Jan 30 16:53:00 EST 2007
Greg Boone wrote:
> Your example is valid but does not answer the question I asked.
> 1) If a user runs the following from the top directory, should
> this action build FDO and all providers?
> automake
> autoconf
> ./configure
> make
Greg,
Have you considered to add some options to ./configure to enable and
disable some providers/features?
In one of providers-based library I work on, I use
./configure --enable-provider-xxx
to request build of provider XXX.
> 2) Another question, should I be able to run ./configure from a
> Provider subdirectory or will we only be able to run ./configure from
> the root directory?
It's also possible to have more than one ./configure script:
- root level ./configure
- subproject level ./configure
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
