[fdo-internals] fdogdal <Bounds> support for 3.2.x
Jason Birch Jason.Birch at nanaimo.ca
Tue Jun 19 18:00:22 EDT 2007
Can we change the flags for libgeotiff in the ThirdParty area so that
MrSID plugin support will work out of the box with any further releases
of FDO 3.2.x?
Is GDAL used for anything other than the OGR and GDAL providers in FDO?
I think that the OGR providers built by Traian are now coming from trunk
instead of 3.2.x branch, and taking advantage of GDAL 1.4.  I wonder if
there is any way we can do this with the GDAL raster provider too,
either by swapping to 1.4 for further 3.2 builds (bit of a drastic
change) or by creating a 3.2-compatible trunk build for MapGuide users.
Frank, if you've made the latest bounds changes in trunk, maybe I'll try
compiling that and using it against MGOS 1.2 to see if this is feasible?
Jason
(flailing as usual...)
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam
Sent: Monday, June 18, 2007 18:30
To: FDO Internals Mail List
Subject: Re: [fdo-internals] fdogdal <Bounds> support for 3.2.x
Folks,
OK, I have closed:
   http://trac.osgeo.org/fdo/ticket/87
I have committed the changes in the 3.2.x branch *after* the 3.2.2.0
tag. So once we are all ready I can tag fdogdal 3.2.2.1 and prepare
updated provider DLLs.
The changes are also all in trunk.
More information about the fdo-internals mailing list
