[fdo-internals] [Fwd: Re: [SAC] Subversion vhost
migration underway]
Robert Bray
rbray at robertbray.net
Sat Mar 3 15:23:25 EST 2007
Yes. Note that nothing is physically moving or being changed. They are
just defining virtual hosts for the svn services. The work is already
done, but the DNS changes have to propagate (which should also be done
by now). I used the new URLs to access the MG vaults this morning.
Bob
Greg Boone wrote:
> Bob,
> What about the FDO branched code located in
> https://osgeo.org/svn/fdocore/branches/3.2.x
> https://osgeo.org/svn/fdogdal/branches/3.2.x
> etc..
> Are these being migrated as well?
> Greg
> -----Original Message-----
> From: Greg Boone
> Sent: Saturday, March 03, 2007 1:30 PM
> To: 'FDO Internals Mail List'
> Subject: RE: [fdo-internals] [Fwd: Re: [SAC] Subversion vhost migration
> underway]
> Bob,
> What about the branches located in
> From: fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Bray
> Sent: Saturday, March 03, 2007 12:09 PM
> To: MapGuide Internals Mail List; FDO Internals Mail List
> Subject: [fdo-internals] [Fwd: Re: [SAC] Subversion vhost migration
> underway]
> FYI - See below. This affects all OSGEO SVN repositories.
> -------- Original Message --------
> Subject: Re: [SAC] Subversion vhost migration underway
> Date: Sat, 3 Mar 2007 08:36:41 -0600
> From: Howard Butler <hobu at iastate.edu>
> Reply-To: System Administration Committee Discussion/OSGeo
> <sac at lists.osgeo.org>
> References: <523155B1-BBA9-425C-BDDD-B7E0FA6D654E at hobu.net>
> <8E468917B01800408B91984428BE03DD05C56840 at starfish.nanaimo.ca>
> I have turned it on long enough for users to do a svn switch. I
> propose that we switch it off Monday at 5 pm CST. I think it would
> be pretty important that they don't *commit* anything to the old URL,
> and only commit to the new URL after they issue the switch. The svn
> switch --relocate command below should work fine with the appropriate
> substitutions for their URLs.
> Howard
> On Mar 3, 2007, at 1:49 AM, Jason Birch wrote:
>> Howard,
>> Several users were/are taking advantage of the wildcard DNS to
>> reference the repositories with paths like:
>> https://osgeo.org/svn/fdo <https://osgeo.org/svn/fdo>
>> Is there any way to re-enable that path on the www vhost until
>> these users get switched over? I misunderstood the impact of the
>> changes and indicated in my note that these aliases would continue
>> to work until the wildcard DNS was pulled.
>> Jason
>> ________________________________
>> From: sac-bounces at lists.osgeo.org on behalf of Howard Butler
>> Sent: Fri 2007-03-02 8:20 PM
>> Subject: [SAC] Subversion vhost migration underway
>> Folks,
>> I have flipped the switch on the DNS, and the subversion virtual host
>> migration is underway. The TTL was set to 6 hours a couple of days
>> ago (after being turned down to 1 day more than a week ago), so the
>> new DNS should propagate fairly quickly. After some time for DNS to
>> propagate, we'll flip the switch back on for the repositories.
>> Note that it is expected that both http://svn.osgeo.org/gdal and
>> http://svn.osgeo.org/svn/gdal will continue to work as repository
>> URLs, but the shorter one is the preferred one. At some indefinite
>> point in the future, we will quit answering to /svn/gdal.
>> After the repositories are back up, at your leisure you may do:
>> svn switch --relocate http://svn.osgeo.org/svn/gdal http:// <http:///>
>> svn.osgeo.org/gdal
>> and all should be well.
>> Howard
>> Sac mailing list
>> Sac at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/sac
>> <winmail.dat>
>> Sac mailing list
> Sac mailing list
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
