[fdo-internals] FW: [mapguide-internals] FW: [SAC] Subversion vhostmigration underway
Greg Boone greg.boone at autodesk.com
Sat Mar 3 20:55:27 EST 2007
FYI...
Here are the commands I ran to switch my local repositories.
Greg
FDO Trunk
cd [FDO_Trunk]
svn switch --relocate https://osgeo.org/svn/fdo/trunk
https://svn.osgeo.org/fdo/trunk
FDO 3.2.x
cd [FDO_3.2.x]
svn switch --relocate https://osgeo.org/svn/fdocore/branches/3.2.x
https://svn.osgeo.org/fdocore/branches/3.2.x
cd [FDO_3.2.x]/Providers/ArcSDE
svn switch --relocate https://osgeo.org/svn/fdoarcsde/branches/3.2.x
https://svn.osgeo.org/fdoarcsde/branches/3.2.x
cd [FDO_3.2.x]/Providers/GDAL
svn switch --relocate https://osgeo.org/svn/fdogdal/branches/3.2.x
https://svn.osgeo.org/fdogdal/branches/3.2.x
cd [FDO_3.2.x]/Providers/GenericRdbms
svn switch --relocate https://osgeo.org/svn/fdordbms/branches/3.2.x
https://svn.osgeo.org/fdordbms/branches/3.2.x
cd [FDO_3.2.x]/Providers/SDF
svn switch --relocate https://osgeo.org/svn/fdosdf/branches/3.2.x
https://svn.osgeo.org/fdosdf/branches/3.2.x
cd [FDO_3.2.x]/Providers/SHP
svn switch --relocate https://osgeo.org/svn/fdoshp/branches/3.2.x
https://svn.osgeo.org/fdoshp/branches/3.2.x
cd [FDO_3.2.x]/Providers/WFS
svn switch --relocate https://osgeo.org/svn/fdowfs/branches/3.2.x
https://svn.osgeo.org/fdowfs/branches/3.2.x
cd [FDO_3.2.x]/Providers/WMS
svn switch --relocate https://osgeo.org/svn/fdowms/branches/3.2.x
https://svn.osgeo.org/fdowms/branches/3.2.x
Marble 3.2.1
cd [FDO_3.2.1]
svn switch --relocate https://osgeo.org/svn/fdocore/branches/3.2.1
<https://osgeo.org/svn/fdocore/branches/3.2.x>
https://svn.osgeo.org/fdocore/branches/3.2.1
cd [FDO_3.2.1]/Providers/ArcSDE
svn switch --relocate https://osgeo.org/svn/fdoarcsde/branches/3.2.1
<https://osgeo.org/svn/fdoarcsde/branches/3.2.x>
https://svn.osgeo.org/fdoarcsde/branches/3.2.1
cd [FDO_3.2.1]/Providers/GDAL
svn switch --relocate https://osgeo.org/svn/fdogdal/branches/3.2.1
<https://osgeo.org/svn/fdogdal/branches/3.2.x>
https://svn.osgeo.org/fdogdal/branches/3.2.1
cd [FDO_3.2.1]/Providers/GenericRdbms
svn switch --relocate https://osgeo.org/svn/fdordbms/branches/3.2.1
<https://osgeo.org/svn/fdordbms/branches/3.2.x>
https://svn.osgeo.org/fdordbms/branches/3.2.1
cd [FDO_3.2.1]/Providers/SDF
svn switch --relocate https://osgeo.org/svn/fdosdf/branches/3.2.1
<https://osgeo.org/svn/fdosdf/branches/3.2.x>
https://svn.osgeo.org/fdosdf/branches/3.2.1
cd [FDO_3.2.1]/Providers/SHP
svn switch --relocate https://osgeo.org/svn/fdoshp/branches/3.2.1
<https://osgeo.org/svn/fdoshp/branches/3.2.x>
https://svn.osgeo.org/fdoshp/branches/3.2.1
cd [FDO_3.2.1]/Providers/WFS
svn switch --relocate https://osgeo.org/svn/fdowfs/branches/3.2.1
<https://osgeo.org/svn/fdowfs/branches/3.2.x>
https://svn.osgeo.org/fdowfs/branches/3.2.1
cd [FDO_3.2.1]/Providers/WMS
svn switch --relocate https://osgeo.org/svn/fdowms/branches/3.2.1
<https://osgeo.org/svn/fdowms/branches/3.2.x>
https://svn.osgeo.org/fdowms/branches/3.2.1
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Saturday, March 03, 2007 3:33 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] FW: [mapguide-internals] FW: [SAC] Subversion
Importance: High
Hi all,
If you are currently using a host other than svn.osgeo.org, please make
sure that you update your local repository to point to the new location
by 5pm CST, Monday.
For instance, if you are using https://osgeo.org/svn/fdo
https://osgeo.org/svn/fdo  (or mapguide), use the following command:
(all on one line, and be careful of the munging that my email client
does.  It's "svn switch --relocate OLDURL NEWURL")
This change is necessary so that we can move away from wildcard DNS,
which is causing considerable problems in managing the website, and to
allow for future separate of SVN and WWW services onto different
servers.  If you require extended time to make this change, please let
the SAC mailing list know by email as soon as possible.
If you are pointing to the svn.osgeo.org host but including /svn/ at the
beginning of your path, you do not have to change immediately, but you
are still encouraged to update to the new canonical URI as soon as
possible.  e.g.:
svn switch --relocate https://svn.osgeo.org/svn/fdo
Jason
From: sac-bounces at lists.osgeo.org on behalf of Howard Butler
Sent: Sat 2007-03-03 6:36 AM
To: System Administration Committee Discussion/OSGeo
Subject: Re: [SAC] Subversion vhost migration underway
I have turned it on long enough for users to do a svn switch.  I
propose that we switch it off Monday at 5 pm CST.  I think it would
be pretty important that they don't *commit* anything to the old URL,
and only commit to the new URL after they issue the switch.  The svn
switch --relocate command below should work fine with the appropriate
substitutions for their URLs.
Howard
On Mar 3, 2007, at 1:49 AM, Jason Birch wrote:
> Howard,
> Several users were/are taking advantage of the wildcard DNS to
> reference the repositories with paths like:
> https://osgeo.org/svn/fdo <https://osgeo.org/svn/fdo>
> Is there any way to re-enable that path on the www vhost until
> these users get switched over?  I misunderstood the impact of the
> changes and indicated in my note that these aliases would continue
> to work until the wildcard DNS was pulled.
> Jason
> Sent: Fri 2007-03-02 8:20 PM
> Subject: [SAC] Subversion vhost migration underway
> Folks,
> I have flipped the switch on the DNS, and the subversion virtual host
> migration is underway.  The TTL was set to 6 hours a couple of days
> ago (after being turned down to 1 day more than a week ago), so the
> new DNS should propagate fairly quickly.  After some time for DNS to
> propagate, we'll flip the switch back on for the repositories.
> Note that it is expected that both http://svn.osgeo.org/gdal and
> http://svn.osgeo.org/svn/gdal will continue to work as repository
> URLs, but the shorter one is the preferred one.  At some indefinite
> point in the future, we will quit answering to /svn/gdal.
> After the repositories are back up, at your leisure you may do:
> svn switch --relocate http://svn.osgeo.org/svn/gdal http:// <http:///>
<http:///>  <http:///>
> svn.osgeo.org/gdal
> and all should be well.
> Howard
> Sac mailing list
> Sac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
> <winmail.dat>
> Sac mailing list
Sac mailing list
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070303/bb60325b/attachment-0001.html
More information about the fdo-internals mailing list
