[fdo-internals] Re: FDO raster image data model does not provide
the actual number
of bits used by certain image data formats (Re: FdoRfc1 & FdoRfc2)
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 22 11:49:24 EDT 2007
Jeff Childers wrote:
> ATIL will report any range information found encoded in Image Format
> files should that information be present. It simply reports this
> differently than the bitsUsed information as having precise range
> information is not common in formats and ATIL does not sample the data
> to determine a range for all image types.
> I do know for certain that if range information is encoded in TIFF that
> it is reported, although that information is not always accurate.
> Perhaps GDAL encodes this faithfully, but I find a majority do not.
Jeff,
GDAL does not currently encode min/max information in TIFF. You are certainly
correct that when available, the information is not always accurate, but I'm
not sure that is a good reason to always disregard it.
It is excellent news that ATIL does support returning min/max metadata for
images.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the fdo-internals
