[fdo-internals] Build warnings - PostGIS and Boost...
Jason Birch Jason.Birch at nanaimo.ca
Sat Nov 10 11:50:04 EST 2007
So, it doesn't affect this install, but... is it something that could or should be changed so that "someone" could more easily package up FDO for various *nix?
Jason
Subject: Re: [fdo-internals] Build warnings - PostGIS and Boost...
IMO it can be safely ignored as you are building FDO yourself
and you will use it on your machine only.
This warning says there are some problems possible if you will use these
binaries on other machines ie. if you are preparing binary packages for
other users.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20071110/d995b33d/attachment.bin
More information about the fdo-internals mailing list
