[fdo-internals] RE: FDO OSGeo PostGIS Provider
Mateusz Loskot
mateusz at loskot.net
Wed Apr 9 18:55:07 EDT 2008
Bruno,
I'd like to thank You and your Team for the fantastic work you've done!!!
Greg,
I'm available to review but I'm not sure where can I access Bruno's
patches. I don't see them attached to the tickets.
Does Bruno use a dedicated branch?
-- mateo
Greg Boone wrote:
> Hi Bruno,
> Thanks for the update. J
> For 3.3/3.4, Submit your changes into
> 3.4 -- https://svn.osgeo.org/fdo/trunk/Providers/PostGIS
> 3.3 -- https://svn.osgeo.org/fdo/branches/3.3/Providers/PostGIS
> Please have Mateusz review and if needed, submit those submissions
> For 3.2.x
> This is a trickier issue. We do not have a SVN repository available for PostGIS built on 3.2.x. We could create a new SVN repository that follows the existing 3.2.x pattern as described on http://fdo.osgeo.org/roadMap.html
> This repository name would be: http://svn.osgeo.org/fdopostgis/branches/3.2.x
> You would need Jason or Frank to help you with this.
> Once all the submissions are in, we can kick off the respective 3.2.x and 3.3.x builds and post patches on fdo.osgeo.org.
> Greg
> From: Bruno Scott [mailto:Bruno at geomapgis.com]
> Sent: Friday, March 28, 2008 7:30 AM
> To: Greg Boone
> Cc: Gwenael Bachelot
> Subject: RE: FDO OSGeo PostGIS Provider
> Hi Greg
> We have still a couple issues with the PostGIS Driver
> #94<http://trac.osgeo.org/fdo/ticket/94>
> Generate extent for features assigned to default spatial context
> We're going to check that one
> #106<http://trac.osgeo.org/fdo/ticket/106>
> PostGIS provider cannot delete a feature class
> Deleting works with feature class and non feature class
> But the table must be empty
> #117<http://trac.osgeo.org/fdo/ticket/117>
> PostGIS provider does not display attribute names in MapGuide when no PK present
> This is a normal behavior
> #171<http://trac.osgeo.org/fdo/ticket/171>
> Fdo Postgis Autogenated identity property is mandatory
> Not mandatory anymore
> #178<http://trac.osgeo.org/fdo/ticket/178>
> PostGIS : Can't insert in a non-feature class
> Non-feature class works well with insert,delete,update and for displaying with join
> 232<http://trac.osgeo.org/fdo/ticket/232>
> Fdo Postgis null and not null filter does not work
> Not yet implemented, I will add this one in our unit tests
> #233<http://trac.osgeo.org/fdo/ticket/233>
> Fdo Postgis in and not in filter does not work
> fixed
> 234<http://trac.osgeo.org/fdo/ticket/234>
> Fdo Postgis currently does not support anything but lowercase identifiers
> Still some pending problems with that one
> #235<http://trac.osgeo.org/fdo/ticket/235>
> Fdo Postgis Exception with insert
> fixed
> #236<http://trac.osgeo.org/fdo/ticket/236>
> Fdo Postgis does not support non spatial classes
> fixed
> #241<http://trac.osgeo.org/fdo/ticket/241>
> Implement Support for SelectAggregates, SpatialExtents and Count
> Select Count works fine now, so selectAggregates also
> Nothing was implemented
> More testing should be done
> Other things, there was a discussion with the community according to the class naming convention
> So we have fallow the community recommendation and we have replaces the "shema~class" by "class" only.
> We ran our test in different environments
> 100% FDO / C++ program ( without any map or Mapguide)
> Map 2008 / fdo 3.2
> Map 2009 / fdo 3.3
> Mapguide 1.2 / fdo 3.2
> Mapguide 2.0 / fdo 3.3
> Using the same Postgres/PostGIS version as Matheus ( 8.2.4 + 1.2.1)
> We have 3 primary spatial tables with all the same columns (one for point, one for line/multi-line and one for polygon/multi-polygon)
> KEY_1 Int32
> STRING_1 String
> INT32_1 Int32
> DOUBLE_1 Double
> DATE_1 DateTime
> STR_CODE_1 String 64
> INT_CODE_1 Int32
> GEOMETRY_1 GEOMETRY
> plus one primary alpha table (without geometry)
> and one primary X/Y table ( Postgis provider does not support displaying it YET)
> We have one secondary alpha table for 1-1 joining ( KEY_1 = j_KEY_1) with the 5 primary tables
> J_KEY_1 Int32
> J_STRING_1 String
> J_INT32_1 Int32
> J_DOUBLE_1 Double
> J_DATE_1 DateTime
> J_STR_CODE_1 String
> J_INT_CODE_1 Int32
> We have two secondary alpha table for n-1 joining (INT_CODE_1 = INT_CODE_1 / STR_CODE_1 = STR_CODE_1) with the 5 primary tables
> INT_CODE_1 Int32
> DESC_1 String
> And
> STR_CODE_1 String
> DESC_1 String
> Unit test with FDO/C++ ( all test succeed, 0 failed)
> Schema modification
> Drop spatial table ( failed if data in the table)
> Drop non-spatial table ( failed if data in the table)
> Create spatial table
> Create non-spatial table
> All our test table are dropped and recreated using FDO prior doing any other test
> Alpha Filter test
> Using
> FdoCommandType_Select (select column from ... )
> FdoCommandType_SelectAggregates ( select Count(1) from ... )
> FdoCommandType_SQLCommand ( complexe query with 1-1 / n-1 joins )
> Key = 1
> Key In (1,2)
> Key Not In (1,2)
> Key > 99
> Key >= 99
> Key < 2
> Key <= 2
> String = 'Bb'
> String In ('Bb','Dd')
> String Not In ('Bb','Dd')
> String Like 'B%'
> String Not Like 'B%'
> Int = 10010
> Int > 10990
> Int >= 10990
> Int < 10020
> Int <= 10020
> Double = 20010.0000001
> Double > 118010.0097903
> Double >= 118010.0097903
> Double < 21010.0001
> Double <= 21010.0001
> Date = 2007-01-01
> Date > 2007-04-09
> Date >= 2007-04-09
> Date < 2007-01-02
> Date <= 2007-01-02
> DateTime = 2007-01-01 00:00:00
> DateTime > 2007-04-09 00:00:00
> DateTime >= 2007-04-09 00:00:00
> DateTime < 2007-01-02 00:00:00
> DateTime <= 2007-01-02 00:00:00
> Spatial Filter test
> Using
> FdoCommandType_SQLCommand ( complexe query with join )
> geometry ENVELOPEINTERSECTS GeomFromText('POLYGON XY ...')"
> geometry ENVELOPEINTERSECTS GeomFromText(POINT XY ...')"
> we didn't test the LINESTRING ( we should )
> Update test
> Insert simple polygon
> Insert multi polygon
> Insert polygon with hole
> Insert linestring
> Insert multi linestring
> Insert point
> Insert alpha ( no geometry in table)
> Delete polygon
> Delete linestring
> Delete point
> Delete alpha ( no geometry in table)
> Update int32 ( on spatial and non-spatial table)
> Update String ( on spatial and non-spatial table)
> Update double ( on spatial and non-spatial table)
> Update date ( on spatial and non-spatial table)
> Update datetime ( on spatial and non-spatial table)
> Update geometry simple polygon
> Update geometry multi polygon
> Update geometry polygon with hole
> Update geometry linestring
> Update geometry multi linestring
> Update geometry point
> Test with Map 2008
> Connecting OK
> Attaching table with srid OK
> Attaching table without srid -> map display a warning
> Display point ok
> Display linestring ok
> Display polygon ok
> Joining spatial table to non-spatial table ok
> Table view display ok
> Updating in the table view ok but the check-in crashes map
> Check-out crashes map
> Test with Map 2009
> This after noon
> Test with Mapguide 1.2
> Everything seems ok
> But still some testing to do with srid
> Test with Mapguide 2.0
> Everything seems ok
> We are actually investigating on the crash problem within map 2008.
> I don't know exactly what are the process to submit all our code changes with the release 3.2.2 and 3.3.0.
> If you could provide some help on that point it will be appreciated.
> Cheers
> Bruno
> From: Greg Boone [mailto:greg.boone at autodesk.com]
> Sent: jeudi 27 mars 2008 18:29
> To: Bruno Scott (External)
> Subject: FDO OSGeo PostGIS Provider
> Hi Bruno,
> I was wondering if you could provide an update on the status of the FDO OSGeo PostGIS Provider modifications that your team has been working on?
> What changes have been made so far and how do these relate to the FDO Track issues that have been logged?
> What is your plan to submit changes to the FDO OSGeo SVN?
> When can your changes be rolled into our formalized build process and released as an official patch to the FDO 3.3 release?
> Will you changes also support FDO 3.2?
> If so, we need to get that the FDO 3.2 code dropped as well, and an official provider release posted.
> Cheers,
> Greg
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
