[fdo-internals] FDO OSGeo PostGIS Provider
Mateusz Loskot mateusz at loskot.net
Mon Apr 21 14:15:07 EDT 2008
Greg Boone wrote:
> Hi Mat,
> If I read your changes to the PostGIS .vsprops file correctly, you
> inadvertently changed the default value of FDOPOSTGRESQL to a local
> value instead of the $(FDOTHIRDPARTY)\pgsql. This change should be
> reverted as the original value is needed for the internal build
> process.
> <UserMacro Name="FDOPOSTGRESQL" Value="C:\Program
> Files\PostgreSQL\8.3" PerformEnvironmentSet="true"
Greg,
You are perfectly right. I appologize, I accidentally submitted my
change to the repo. I've fixed it.
Thanks for pointing that issue.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
