[fdo-internals] FDO OSGeo PostGIS Provider
Greg Boone greg.boone at autodesk.com
Mon Apr 21 10:34:44 EDT 2008
Hi Mat,
If I read your changes to the PostGIS .vsprops file correctly, you inadvertently changed the default value of FDOPOSTGRESQL to a local value instead of the $(FDOTHIRDPARTY)\pgsql. This change should be reverted as the original value is needed for the internal build process.
        <UserMacro
                Name="FDOPOSTGRESQL"
                Value="C:\Program Files\PostgreSQL\8.3"
                PerformEnvironmentSet="true"
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Monday, April 21, 2008 5:36 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] FDO OSGeo PostGIS Provider
Bruno Scott wrote:
> To compile the postgis provider we also need
>   thirdparty\pgsql
> So if we got that repository
> http://svn.osgeo.org/fdo/branches/PostGIS-3.2.x
> Where do we add this thirdparty?
Bruno,
Personally, I prefer to use my own installation of the PostgreSQL stuff.
I set path to the PostgreSQL installation using FDOPOSTGRESQL variable
in the PostGis.vsprops:
http://trac.osgeo.org/fdo/browser/trunk/Providers/PostGIS/Src/PostGis.vsprops
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
