[fdo-internals] PATCH : PostGIS provider patch 3.4
Bruno Scott
bscott at geomapgis.com
Sun Apr 20 03:29:04 EDT 2008
Mateusz Loskot wrote:
> Bruno, do you mind if I'd suggest to remove comments about ticket number,
> what was fixed, etc. after the patch is applied?
Of course i have no objection. As this patch concern many tickets, i tought
it was important to specify all the different ticket for you guys to review!
Once the are reviewed you could delete them :)
> AFAIU, the patch for ticket #314 (check-out/check-in crashes Autodesk Map)
> is a temporary fix. If that's right, I'd suggest to keep the #314 open.
Yes we should keep it open
> Bruno Scott wrote:
>> Patches and binaries for Branch\3.3 and for 3.2.3 will follow
>> Bruno
>> http://www.nabble.com/file/p16744011/PostGIS_trunk_patch.zip
>> http://www.nabble.com/file/p16744011/PostGIS_trunk_binaries.zip
> I've submitted your patch as a Task ticket:
> http://trac.osgeo.org/fdo/ticket/318
> I'll put there my review notes as comments.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/PATCH-%3A-PostGIS-provider-patch-3.4-tp16744011s18162p16790648.html
Sent from the fdo-internals mailing list archive at Nabble.com.
More information about the fdo-internals
