[fdo-internals] PATCH : PostGIS provider patch 3.4
Bruno Scott
bscott at geomapgis.com
Mon Apr 21 04:34:07 EDT 2008
According to the ticket 314 description "check-out/check-in crashes Autodesk
Map"
Map does not crash anymore so i think we should close that ticket
and create a new ticket
"PostGIS provider does not support Transaction"
Bruno Scott
Bruno Scott wrote:
> Mateusz Loskot wrote:
>> Bruno, do you mind if I'd suggest to remove comments about ticket number,
>> what was fixed, etc. after the patch is applied?
> Of course i have no objection. As this patch concern many tickets, i
> tought it was important to specify all the different ticket for you guys
> to review! Once the are reviewed you could delete them :)
>> AFAIU, the patch for ticket #314 (check-out/check-in crashes Autodesk
>> Map) is a temporary fix. If that's right, I'd suggest to keep the #314
>> open.
> Yes we should keep it open
>> Bruno Scott wrote:
>>> Patches and binaries for Branch\3.3 and for 3.2.3 will follow
>>> Bruno
>>> http://www.nabble.com/file/p16744011/PostGIS_trunk_patch.zip
>>> http://www.nabble.com/file/p16744011/PostGIS_trunk_binaries.zip
>> I've submitted your patch as a Task ticket:
>> http://trac.osgeo.org/fdo/ticket/318
>> I'll put there my review notes as comments.
>> Cheers
>> Mateusz Loskot
>> http://mateusz.loskot.net
>> fdo-internals mailing list
>> fdo-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/PATCH-%3A-PostGIS-provider-patch-3.4-tp16744011s18162p16804884.html
Sent from the fdo-internals mailing list archive at Nabble.com.
More information about the fdo-internals
