[fdo-internals] PATCH : PostGIS provider patch 3.4
Mateusz Loskot
mateusz at loskot.net
Mon Apr 21 05:21:31 EDT 2008
Bruno Scott wrote:
> Mateusz Loskot wrote:
>> Bruno, do you mind if I'd suggest to remove comments about ticket number,
>> what was fixed, etc. after the patch is applied?
> Of course i have no objection. As this patch concern many tickets, i tought
> it was important to specify all the different ticket for you guys to review!
> Once the are reviewed you could delete them :)
Bruno,
Sure, these comments are extremely helpful during review. They point
which part of the patch refers to which ticket.
>> AFAIU, the patch for ticket #314 (check-out/check-in crashes Autodesk Map)
>> is a temporary fix. If that's right, I'd suggest to keep the #314 open.
> Yes we should keep it open
OK
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
