[fdo-internals] FDO RFC 16 - FDO Provider for SQLite
Traian Stanev
traian.stanev at autodesk.com
Wed Apr 23 00:09:35 EDT 2008
Yeah so I'm obviously wrong in my guess about the problem being the coord sys. I'd need to go and see what exactly Mapguide is calling to get a data type. So yes, it could be a problem with the schema creation, it just needs some debugging to get to the problem.
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Wednesday, April 23, 2008 12:00 AM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
> Frank's new files are still not working. I don't think that MapGuide
> has a specific requirement for a CS; it works fine with shape files
> that
> don't have projection info.
> This explanation doesn't make a lot of sense given where in the
> MapGuide
> code this is failing.
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Server/src/Services/
> F
> eature/ServerGetFeatures.cpp#l978
> (or thereabouts). I find it amusing that the comment at the default
> condition is "We will probably never hit this code" :)
> My guess would be that the provider is passing a data type that
> MapGuide
> hasn't accounted for or is not a valid FDO type. From the code, it
> looks like MapGuide understands:
> Boolean, Byte, DateTime, Decimal, Double, Int16, Int32, Int64,
> Single,
> String, BLOB and CLOB.
> Traian, in your manual tests of describing the schema of Frank's
> tables,
> what data types are you getting?
> Jason
> From: Traian Stanev
> The data reads fine in my manual tests, but Jason pointed out that it
> errors out in MapGuide. One thing I noticed is that some of the
> geometry
> columns have an SRID equal to 0, meaning they don't have a coord sys.
> Was that intentional? Generally FDO data sources are required to have a
> coordinate system, so this is what could be causing the problem in
> MapGuide.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
