[fdo-internals] Use Sl-King Oracle Provider with Managed Code
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jul 15 02:53:32 EDT 2008
The Sl-King Oracle provider is meant for use through FDO.
FDO has managed wrappers (Windows SDK):
http://fdo.osgeo.org/content/fdo-331-downloads
Using the managed wrappers, you can connect to any FDO provider,
and thus also the Sl-King Oracle provider.
So, you most likely don't want to connect directly to the Sl-King provider.
If you do, AFAIK, there are no wrappers for direct use of this provider.
Regards, Kenneth Skovhede, GEOGRAF A/S
geostarter skrev:
> I want to connect to a Sl-King Oracle Provider. The Code i want to connect
> should be written in managed C# Code, but i can't Find any managed Wrapper
> vor SL-King Oracle Provider. I have only found Provider dlls, wich can be
> only accessed via unmanaged code!
> Does such a managed API (or kind of wrapper) for this Provider exist or must
> i write my own wrapper as mixed mode dll ???
> Thanks for help
> geostarter!
More information about the fdo-internals mailing list
