[fdo-internals] Disable building managed FDO layer
Greg Boone greg.boone at autodesk.com
Fri May 2 11:51:33 EDT 2008
The .sh scripts will not build any managed components.
As for the .bat scripts, just building the unmanaged components is not supported using command options. Log a Ticket and I will see what I can do. For now, you can hard-code the configuration name specified in the ...\fdo\Fdo\build.bat script to be either "Debug Unmanaged" or "release Unmanaged"
e.g.
msbuild FDO.sln /t:%MSACTIONFDO% /p:Configuration="Release Unmanaged" /p:Platform=%TYPEPLATFORMFDO% /nologo /consoleloggerparameters:NoSummary
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Friday, May 02, 2008 10:40 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Disable building managed FDO layer
How can I tell build{.bat|.sh} script to not to build managed layer
in trunk/Fdo/Manged ?
Greetings
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
