[fdo-internals] Zero-length Data Properties
Thomas Knoell
thomas.knoell at autodesk.com
Tue Sep 2 09:32:36 EDT 2008
Hi Jackie,
The -1 is an indicator that the exact value cannot be determined. This is especially the case in ODBC that can connect to multiple data store sources, all with different limitations. Because the capability information is available before a connection is actually established more precise information cannot be provided.
Thanks
Thomas
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Tuesday, September 02, 2008 4:47 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Zero-length Data Properties
Hi All,
I have two related questions about Data Properties
A) Why does FDO allow zero-length string/CLOB/BLOB data properties? In my
feeble little mind, zero-length strings/CLOBs/BLOBs makes no sense
whatsoever.
B) I noticed that for some providers, the GetMaximumDataValueLength() method
returns -1 for string/BLOB/CLOB properties. The same goes for
GetMaximumDecimalPrecision() and GetMaximumPrecisionScale(). If I were to do
something like this:
ISchemaCapabilities capabilities;
DataPropertyDefinition def = new DataPropertyDefinition("StringProp", "");
def.Length =
capabilities.GetMaximumDataValueLength(DataType.DataType_String);
It would throw an exception because the Length property of
DataPropertyDefinition can't be negative. So what should this value (-1) be
interpreted as?
- Jackie
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Zero-length-Data-Properties-tp19266363p19266363.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
