[fdo-internals] Problem compiling provider for Autodesk Map 2010
Romica Dascalescu Romica.Dascalescu at autodesk.com
Fri Apr 17 09:58:55 EDT 2009
Hi Bruno,
There was a change of parameter type in function Create Exception (we changed some parameters from wchar_t* to const wchar_t*) and this breaked FDO 3.5 (trunk) with Map2010 compatibility (Map is looking for a different function signature).
Romica.
________________________________________
From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] On Behalf Of Bruno Scott [bscott at geomapgis.com]
Sent: Friday, April 17, 2009 9:54 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Problem compiling provider for Autodesk Map 2010
I've succesfully compile FDO using
  https://svn.osgeo.org/fdo/branches/3.4
and
  https://svn.osgeo.org/fdo/trunk
When i try to load one of these PostGIS provider, Map 2010 can't load the dll
I have the same error if i use my own compilation of the sdf provider.
It must be a version mismatch.
I tought that all 3.4.* dll would be binary compatible, is that true?
or maybe i'm not compiling them right!
Witch version i should use for AutoCAD Map 2010?
Bruno Scott
View this message in context: http://n2.nabble.com/Problem-compiling-provider-for-Autodesk-Map-2010-tp2650844p2650844.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
