[fdo-internals] Problem compiling provider for Autodesk Map 2010
Bruno Scott
bscott at geomapgis.com
Fri Apr 17 09:54:03 EDT 2009
I've succesfully compile FDO using
https://svn.osgeo.org/fdo/branches/3.4
and
https://svn.osgeo.org/fdo/trunk
When i try to load one of these PostGIS provider, Map 2010 can't load the dll
I have the same error if i use my own compilation of the sdf provider.
It must be a version mismatch.
I tought that all 3.4.* dll would be binary compatible, is that true?
or maybe i'm not compiling them right!
Witch version i should use for AutoCAD Map 2010?
Bruno Scott
View this message in context: http://n2.nabble.com/Problem-compiling-provider-for-Autodesk-Map-2010-tp2650844p2650844.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
