[fdo-internals] Problem compiling provider for Autodesk Map 2010
Greg Boone
greg.boone at autodesk.com
Fri Apr 17 10:58:13 EDT 2009
If adding the path works, then we may have to revisit the DELAYLOAD implementation in FDO. FDO was designed so that its path need not be included in the system path. This was done so that side by side execution of applications using FDO can occur.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Friday, April 17, 2009 10:40 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] Problem compiling provider for Autodesk Map 2010
oops, i got you wrong
not adding the fdo in the path for running Map 2010
but for compiling...
I will double check and recompile...
View this message in context: http://n2.nabble.com/Problem-compiling-provider-for-Autodesk-Map-2010-tp2650844p2651085.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
