[fdo-internals] RE: [mapguide-internals] bad behaviour in low
memory situation build r3838
Traian Stanev
traian.stanev at autodesk.com
Fri Apr 24 10:33:17 EDT 2009
Did you try reducing the number of simultaneous connections or the thread pool size in the serverconfig.ini?
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Thursday, April 23, 2009 9:07 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] RE: [mapguide-internals] bad behaviour in low memory situation build r3838
Hi all,
I rerun the tile generation on my small machine..... and the server
eventually reports FAILURE on the getTile requests...
but still too late.....
the exceptions log look the same as before..... the exception occurs and
some layers dont get rendered...
the tile gets returned without an error message!!
the first thing i missing the labels while the map is till ok.... then
it carries on and on and looses more and more layers....
Sorry but this is not done yet.
Please tell me what else I can do to help.
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
