[fdo-internals] RE: [fdo-trac] #516: FDO Core enhancment: support standard ORDER BY expressions
Greg Boone greg.boone at autodesk.com
Wed Apr 29 11:41:32 EDT 2009
Correction...
"If these is an enhancement request, you should write up an RFC."
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Wednesday, April 29, 2009 11:40 AM
To: FDO Internals Mail List
Subject: [fdo-internals] RE: [fdo-trac] #516: FDO Core enhancment: support standard ORDER BY expressions
If these is an cement request, you should write up an RFC.
Greg
From: trac_fdo at osgeo.org [mailto:trac_fdo at osgeo.org]
Sent: Wednesday, April 29, 2009 4:29 AM
Cc: fdo-trac at lists.osgeo.org
Subject: [fdo-trac] #516: FDO Core enhancment: support standard ORDER BY expressions
   Reporter:  mwtoews      |       Owner:  gregboone
       Type:  enhancement  |      Status:  new
   Priority:  minor        |   Milestone:  3.5.0
  Component:  FDO API      |     Version:  3.4.0
   Severity:  3            |    Keywords:
External_id:               |
 Searching through the fdo-user's list, I found some discussion and ticket-
 worthy material on the topic of ordering data from the core API:
 http://lists.osgeo.org/pipermail/fdo-users/2008-May/000943.html
 The primary importance for me is the drawing order of stacked features. At
 present, in AutoCAD Map3D we have no control how overlapping polygons are
 drawn. One workaround is to create a database view on the server-side that
 is linked to FDO/CAD, and the other is to break a single feature layer
 into several layers to get the stacking correct. The preferred method
 would be to use a single ordered feature class that is sored by (e.g.)
 date, status, area, or some other feature attribute.
 From a low-level perspective, it appears this is supported by some
 providers using customized commands. This enhancement is aimed to bring
 soring of data on 1 or more attribute columns to FDO Core, so it can be
 supported by data providers.
 See also, a similar "ORDER BY" enhancement request for QGIS:
 https://trac.osgeo.org/qgis/ticket/1597
Ticket URL: <https://trac.osgeo.org/fdo/ticket/516>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-internals mailing list
