[fdo-internals] SQLite Provider issue
Badreddine Karoui badreddine.karoui at autodesk.com
Thu Jun 4 13:04:03 EDT 2009
The thirdparty SQLite library is an older version needed by the SDF provider. The SDF provider needs the older version for binary compatibility reason since the latest version used by the SQLite provider is not backward compatible to the version used by the SDF provider.
Badreddine
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
Sent: Thursday, June 04, 2009 12:38 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] SQLite Provider issue
Em Quinta-feira 04 de junho 2009, às 12:52:54, Traian Stanev escreveu:
> Hi Helio,
> You can replace the existing CMake files.
> Thanks,
> Traian
Traian, i have a few questions about SQLite providers:
- Is it tested on Linux ? Trying to compile SpatialIndex there's windows only
entries. ( HANDLE, explicit <windows.h> )
- Is really needed use a second sqlite copy in a subdir ? Because this lead us
to an not so good situation, since we have two different versions of sqlite in
the fdo code, the ThirdParty one and the one inserted in SQlite provider.
[]'s
KDE Developer
Brasil/South America Primary Contact
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
