[fdo-internals] SQLite Provider issue
Traian Stanev
traian.stanev at autodesk.com
Fri Jun 5 10:44:06 EDT 2009
Hi Helio,
I still can't get the new cmake files working on my system -- it seems like cmake can't find FDO, which I have successfully compiled and installed using cmake... I have cmake 2.6.2 if that makes any difference...
I will keep working on getting cmake to work for the provider, but in the meanwhile, one thing I discovered is that for 32 bit builds, you have to explicitly tell g++ to enable SSE and SSE2. Some code in the provider uses SSE2 so it needs to be turned on, I'm guessing by using --enable-sse and --enable-sse2 options. I originally compiled on x64, where SSE is automatically always available, so I did not notice that problem.
Traian
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
Sent: Thursday, June 04, 2009 3:01 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] SQLite Provider issue
Em Quinta-feira 04 de junho 2009, às 13:39:50, Traian Stanev escreveu:
> Hi Helio,
> For Linux, you need to compile the SpatialIndex.cpp, rather than
> DiskSpatialIndex.cpp. They both have the same API, but only the first
> one compiles on Linux.
> Traian
Hello again Traian.
I was unable to make a full compilation on this provider. I'm attaching the diff for SQLite provider and maybe you can point me where i get wrong.
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the fdo-internals
