[fdo-internals] SQLite Provider issue
Helio Chissini de Castro helio at kde.org
Fri Jun 5 11:50:56 EDT 2009
Em Sexta-feira 05 de junho 2009, às 11:44:06, Traian Stanev escreveu:
> Hi Helio,
> I still can't get the new cmake files working on my system -- it seems like
> cmake can't find FDO, which I have successfully compiled and installed
> using cmake... I have cmake 2.6.2 if that makes any difference...
> I will keep working on getting cmake to work for the provider, but in the
> meanwhile, one thing I discovered is that for 32 bit builds, you have to
> explicitly tell g++ to enable SSE and SSE2. Some code in the provider uses
> SSE2 so it needs to be turned on, I'm guessing by using --enable-sse and
> --enable-sse2 options. I originally compiled on x64, where SSE is
> automatically always available, so I did not notice that problem.
Hi Traian
My default devel machine is 64 bits, anyway.
I forgot to tell that the provider need to be inside main code yet ( can't be
standalone dor now ).
To make things easier, i will commit the patch now and  we can solving  this
after. So, on the main fdo checkout. just run cmake -DWITH_PROVIDERS="SQLite"
and should be enough. FindFDO.cmake is under cmake/modules and after i have
all providers done, i will make it instalable on global dir
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the fdo-internals mailing list
