[fdo-internals] TIcket 471: ArcSDE Long Text Fields.. testing
patch
Chris Erickson
chris at cartopac.com
Mon Mar 9 16:06:44 EDT 2009
I'm still pretty stumped here. Does anybody know why an update would work, but an insert on the same table would give ORA-01030?
chris erickson
developer
970.493.9500 x 191
970.482.1485 (fax)
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Chris Erickson
Sent: Monday, March 09, 2009 11:47 AM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] TIcket 471: ArcSDE Long Text Fields.. testing patch
I've completed a round of testing with the attached (updated) version of the patch:
SDE / SQL Server (9.2, 2008)
SQL String Type: Registered As Versioned (ArcCatalog): Read/Updated/Inserted Correctly:
text x x
ntext x x
varchar(4000) x x
varchar(max) /(Unsupported) (Data Corruption)
nvarchar(4000) x x
nvarchar(max) /(Unsupported) (Data Corruption)
Apparently the ArcSDE SDK doesn't work well with varchar(max)/nvarchar(max) fields...
I've also tested against ArcSDE 9.2/Oracle 10g (unknown field type) and can update records, but inserting I'm getting a "Illegal Variable Name/Number" error from Oracle.
Originally, this was thought to be a side-effect of having a field name of 'Text' and this being a reserved word, so I re-created with a field name of "MEMO_FIELD", and it still fails (insert only...) I don't have a clue on the cause of this right now.
chris erickson
developer
970.493.9500 x 191
970.482.1485 (fax)
More information about the fdo-internals
