[fdo-internals] RE: PATCH: Raster stability fixes, ticket #462
Haris Kurtagic haris at sl-king.com
Sat Mar 28 04:45:45 EDT 2009
It is not provider itself. I think I know exactly ( I just posted to MG
internals ) what is going on and where problems are.
Pacth will not make it slower.
And most importantly we will solve it :)
Haris
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, March 27, 2009 7:35 PM
To: 'FDO Internals Mail List'; MapGuideInternals Mail List
Subject: [fdo-internals] RE: PATCH: Raster stability fixes, ticket #462
Is there any way at that point in the code to identify the provider
being used for the Raster operation, and only apply the guard if it's
the GDAL provider?
I believe that there was a fair amount of effort put into guarding all
of the FDO APIs in the GDAL provider already, but perhaps some got
missed.  I'll be interested to hear back from Haris on his
investigations into the connection manager to see if this is a
combination of factors, not just the GDAL provider.
BTW, yes, having the guard in that location is somewhat slow with
multiple layers/users. But it also means that my MapGuide server doesn't
crash after a minute of operation once I get a few concurrent sessions
going.  These patches mean that it takes at least ten minutes (I'm
seeing the problem of exhausting the client connections too )...
In an ideal world, I'd be happier if there was a bare bones,
multithreaded, non-configurable, seat of your pants GDAL provider that
supported VRTs.  However, just being able to publicly launch the City's
new web maps after a year and a half, countless hours of my time, and
over $80k in external development costs would be nice :)  I've
definitely had cause to regret jumping on this bandwagon early.
Jason
Sent: Friday, March 27, 2009 11:45 AM
To: 'MapGuide Internals Mail List'; 'FDO Internals Mail List'
Subject: RE: PATCH: Raster stability fixes, ticket #462
Just to add a little more detail, the guard in question will also impact
WMS consumption in MapGuide.  Querying and rendering of WMS layers from
external data sources will become completely single threaded.
Moving the guard forces most of the stylization/rendering work to be
single threaded.  I suspect these operations are fairly lengthy.  From
what I recall, the Fdo ReadNext() call is also done within
StylizeGridLayer.  If ReadNext() is "slow" for WMS and GDAL then there
will be an even greater performance impact to multi-user performance
when the guard is moved.
The current guard only protects setup and execution of the
MgFeatureService::SelectFeatures call.  From an Fdo perspective, I
believe SelectFeatures is fairly fast so guarding it does not
significantly affect multi-user performance.
In my opinion, moving the guard in MapGuide will impose a heavy price
performance wise.  The best option is to add guards to the GDAL Raster
provider.  However, Jason is bang on with his analysis of the likelihood
of any collaboration happening short term.  One possible solution would
be to put a guard around all of the public Fdo APIs in the GDAL
Provider.  That would not require much collaboration and would be "drop
in" testable.
Thanks,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Friday, March 27, 2009 11:07 AM
Subject: [mapguide-internals] RE: PATCH: Raster stability fixes, ticket
#462
I think that this patch should be implemented for two reasons.
First, I believe that this is no more of a sledgehammer approach than
the existing guard.
Second, getting coordination between a skilled MapGuide developers that
can work though the threading issues and the GDAL Provider developer has
been attempted in the past and failed because nobody stepped up to the
plate from the MapGuide community.
Checking this in as a temporary stability measure allows us to have a
reasonable (if slow) raster story for the 2.1 release.
Of course, if there are developers from both the FDO and MapGuide
communities that are able to work together to properly resolve this
issue before the FDO 3.4 release (it's at RC3) and the MapGuide 2.1
release, then that would be ideal.
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: March-27-09 8:55 AM
To: MapGuide Internals Mail List
#462
I totally agree - the locking needs to be in the provider.
Thanks,
Bruce
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Friday, March 27, 2009 9:40 AM
#462
It does look like a sledgehammer approach -- what if some day there is a
raster provider that works ok and doesn't need the locks? If anything,
the lock should be in the FDO provider.
Traian
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Friday, March 27, 2009 11:11 AM
#462
The memory patch (mapguide_raster_unalloc.5.patch) looks good, and I'll
submit that.
The stability patch (mapguide_raster_stability.patch) looks reasonable,
but I'd like another 1 or 2 people to also look at it.  It's significant
since it limits MapGuide to processing one raster stylization request at
a time, but I guess that's better than having a dead lock.  Anyone know
where the thread-unsafe code actually is?  Is it in the provider itself?
Can the mutex be moved closer to the actual thread-unsafe code?
Walt
Birch
Sent: Friday, March 27, 2009 3:10 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] PATCH: Raster stability fixes, ticket #462
Haris has been working on the raster stability problem against MapGuide
2.0.2.  I was having the same problems, and was able to duplicate on
2.1.  I have worked with Haris to create patches against trunk that
address a couple of the problems and increase stability immensely.
Could someone please review the patches attached to:
http://trac.osgeo.org/mapguide/ticket/462
and commit them to trunk if appropriate?
My feeling is that the connection management stuff may need some
additional work, since limiting the connection pool to 1 for
single-threaded providers doesn't appear to have the desired effect.
However, getting both of these patches into 2.1 would at least improve
stability for Raster users.
Jason
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
