[fdo-internals] Fdo/Unittest cppunit modern api patch
Helio Chissini de Castro helio at kde.org
Tue May 19 16:26:58 EDT 2009
Hello again
Here's the patch for test using modern cppunit api.
If a newer api, ( defined CPPUNIT_API ) is found on test, the new code is used,
otherwise old one ( cppunit < 1.11 )  is used.
[]'s
KDE Developer
Brasil/South America Primary Contact
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090519/b5c442cb/fdo-trunk-unitest-modern-api.patch.zip
More information about the fdo-internals mailing list
