[fdo-internals] Fdo/Unittest cppunit modern api patch
    Greg Boone
    greg.boone at autodesk.com
    Tue May 19 16:34:17 EDT 2009
I don’t really know this code all too well, so maybe someone else can comment. However, it generally looks ok.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
Sent: Tuesday, May 19, 2009 4:27 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Fdo/Unittest cppunit modern api patch
Hello again
Here's the patch for test using modern cppunit api.
If a newer api, ( defined CPPUNIT_API ) is found on test, the new code is used,
otherwise old one ( cppunit < 1.11 )  is used.
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the fdo-internals
