[fdo-internals] RE: WMS provider issue while consuming 1.3.0
server
Orest Halustchak
orest.halustchak at autodesk.com
Tue Aug 17 11:39:46 EDT 2010
Well, that's part of the problem. From a WMS server, you'd get an EPSG number and would have to look up that definition in a catalog to determine the axis order.
Thanks,
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, August 17, 2010 11:37 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] RE: WMS provider issue while consuming 1.3.0 server
I'd be fine with this approach as long as the only dependency is the logic in
the CS-Map library, and not it's 400+ mb of CS dictionaries.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-provider-issue-while-consuming-1-3-0-server-tp5431259p5432654.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
