[fdo-internals] RE: FDO RFC 57 is revised, can you review it.
Cheney Sun
cheney.sun at autodesk.com
Mon Apr 11 03:10:49 EDT 2011
Hi Greg,
I already updated the RFC according to your suggestions. It mainly expand the example to demonstrate the linkage between select and GetFeatureInfo command.
@All, welcome any more feedback.
Thanks,
Cheney
Date: Sat, 2 Apr 2011 03:28:54 +0000
Subject: [fdo-internals] RE: FDO RFC 57 is revised, can you review it.
To: FDO Internals Mail List <fdo-internals at lists.osgeo.org>
Hi Cheney,
In the RFC, can you revisit the example and expand it to demonstrate how a caller would request an initial FdoISelect area(s) with height/width and how an area/resolution would then be reselected/altered by passing values into the GetFeatureInfo command? I think readers needs to see the linkage between an initial set of FdoISelect statements returning tiles of information and the subsequent calls to GetFeatureInfo.
Regards,
Greg
Sent: Friday, April 01, 2011 2:52 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] FDO RFC 57 is revised, can you review it.
Hi all,
I revised the FDO RFC 57 to fix some potential usage issues. Can you review it?
http://trac.osgeo.org/fdo/wiki/FDORfc57
Thanks,
Cheney
More information about the fdo-internals
